Forum » Pomoč in nasveti » MS Windows Vista Sidebar za XP
prehlajeni ::
Oj,
se dobi uradni mikrosoftov windows vista sidebar ki poganja gadgete tudi za xp-je?
hvala!
hvala!
StratOS ::
Vista transformation pack 6 final + še veliko ostalih vista like opcij
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
- spremenila: StratOS ()
| » | Vista transform packOddelek: Operacijski sistemi | 1608 (1394) | RejZoR |
| ⊘ | finteOddelek: Operacijski sistemi | 1177 (1177) | OmegaBlue |
| » | kako se naštima to v XP windows??Oddelek: Operacijski sistemi | 1520 (1410) | ta_pravi |
| » | Kako sprmeniti gumb start - menujaOddelek: Pomoč in nasveti | 1325 (1236) | Anze92 |
| » | teme za xpOddelek: Pomoč in nasveti | 1521 (1478) | BluPhenix |
