Forum » Pomoč in nasveti » Problemi s truevectorjem
atair ::
Torej, ko sem pred kratkim hotel instalirati ZA internet Security Suite, mi je pred koncem instalacije zablokiral računalnik, tako da sedaj ne morem uporabljati tega programa in ne unistalirati. Če pa ga hočem ponovno instalirati, pa se mi pokaže tole:
Setup is unable to log into the TrueVector service. Install cannot countine without logging into TrueVector service.
Please use the service manager to shut down the TrueVector service and then restart the installer program.
OK Cancel
Kaj naj naredim?
OK Cancel
Kaj naj naredim?
StratOS ::
Ravno tisto, kar ti piše :
V run vpiši "services.msc" in ga zaženi
Izberi "TrueVector service" in ga ustavi (Desni klik z miško "Stop")
Ponovno reinštaliraj.
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | Kateri firewall? (strani: 1 2 3 4 5 6 7 8 9 )Oddelek: Informacijska varnost | 136435 (25922) | Qushaak |
| » | [Java] Urejanje baze z JTableOddelek: Programiranje | 1427 (1211) | vonNeumann |
| » | Internet connection --- ON/OFF stikalo - kako?Oddelek: Pomoč in nasveti | 1510 (1389) | trnvpeti |
| » | Tocka in trikotnik + 3DOddelek: Programiranje | 1981 (1826) | tomblord |
| » | Par problemov z XPjiOddelek: Operacijski sistemi | 3087 (2333) | Mercier |
