yum update
yum update
Klenobo ::
Ko hočem narediti upgrade iz FC 4 na CentOS 4 yum, dobim tole napako ven.
Repository base is listed more than once in the configuration
Repository extras is listed more than once in the configuration
Setting up Update Process
Setting up repositories
updates-released [1/5]
update [2/5]
extras [3/5]
base [4/5]
addons [5/5]
Reading repository metadata in from local files
Traceback (most recent call last):
File "/usr/bin/yum", line 29, in ?
yummain.main(sys.argv[1:])
File "/usr/share/yum-cli/yummain.py", line 97, in main
result, resultmsgs = do()
File "/usr/share/yum-cli/cli.py", line 481, in doCommands
return self.updatePkgs()
File "/usr/share/yum-cli/cli.py", line 957, in updatePkgs
self.doRepoSetup()
File "/usr/share/yum-cli/cli.py", line 82, in doRepoSetup
self.doSackSetup(thisrepo=thisrepo)
File "/usr/lib/python2.4/site-packages/yum/__init__.py", line 291, in doSackSetup
self.repos.populateSack(which=repos)
File "/usr/lib/python2.4/site-packages/yum/repos.py", line 289, in populateSack
dobj = repo.cacheHandler.getPrimary(xml, csum)
File "/usr/lib/python2.4/site-packages/yum/sqlitecache.py", line 96, in getPrimary
return self._getbase(location, checksum, 'primary')
File "/usr/lib/python2.4/site-packages/yum/sqlitecache.py", line 83, in _getbase
(db, dbchecksum) = self.getDatabase(location, metadatatype)
File "/usr/lib/python2.4/site-packages/yum/sqlitecache.py", line 79, in getDatabase
db = self.makeSqliteCacheFile(filename,cachetype)
File "/usr/lib/python2.4/site-packages/yum/sqlitecache.py", line 239, in makeSqliteCacheFile
self.createTablesPrimary(db)
File "/usr/lib/python2.4/site-packages/yum/sqlitecache.py", line 181, in createTablesPrimary
cur.execute("CREATE INDEX packagename ON packages (name)")
File "/usr/src/build/539311-i386/install//usr/lib/python2.4/site-packages/sqlite/main.py", line 244, in execute
_sqlite.DatabaseError: unable to open database file
Sem že gledal z googlom, pa nisem dobil nobenega pametnega odgovora.
Pajek.Net, (http://www.pajek.net)
Brezplačna MojaPosta.Com (http://www.MojaPosta.Com)
416c6573a ::
mogoce zato ker lahko iz fc nardis upgrade samo na fc?
ze res da tut centos uporablja yum, zato pa paketi niso isti. centos ma mal starejse pakete, ker sledi redhatu in je mozno da tut yum sam po seb ni kompatibilen.
Nalozi centos na novo, pa naredi samo backup /home pa /etc pa dej v centos.
Lastnorocno.
Klenobo ::
Bi že naredil to, če nebi imel samo remote dostop do serverja.
skripta za pošiljanje brezplačnih sms sporočil (strani: 1 2 3 4 )
Oddelek: Programiranje
19550419 (15659) AštiriL
[Python] HTTPS na desktopu dela, na Arduinu ne
91969 (1582) N4g4c3N
Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )
Oddelek: Operacijski sistemi
1960128045 (43719) RedDrake
Pomoc pri linuxu
Oddelek: Programska oprema
131493 (1333) Blazs
Linux internet povezava problem
442515 (2130) dr.J
