slack 10.2 -> 11.0
slack 10.2 -> 11.0
'FireSTORM' ::
se da kak to upgrejdat?
ali moram ves 11.0 downloadat in ponovno inštalirat?
Those penguins.... They sure aint normal....
ank ::
Je možno. Poglej si UPGRADE.TXT
Slackware 10.2 to 11.0 Upgrade HOWTO
This document explains how to upgrade from Slackware 10.2 to Slackware 11.0
Before you begin, I would strongly recommend making a backup of your
system, or, if not the entire system, at least the /etc directory. You
might find that you need to refer to a few things after the upgrade
process is complete. Back it up, or take your chances.
OK, now that everything is safely backed up, let's proceed. :-)
To do this, you'll need the Slackware 11.0 packages. If these are on a CD,
create a new directory to mount the CD on so that it doesn't get in the
way during the upgrade:
mkdir /packages
mount /dev/cdrom /packages
The packages don't have to be on a CD-ROM, as an alternative you could
copy the slackware directory (the one with the various package
subdirectories in it, basically the "slackware" directory from the install
CD) to someplace like /root/slackware/. The important thing is that you
know where the slackware packages directory is. We'll use /root/slackware
in the following examples.
0. Put your machine in single-user mode:
telinit 1
1. Upgrade your glibc shared libraries. This is important, or things
might go haywire during the first part of the upgrade:
upgradepkg /root/slackware/a/glibc-solibs-*.tgz
2. Upgrade your package utilities:
upgradepkg /root/slackware/a/pkgtools-*.tgz
3. Install sed. You should already have this, but since it's used by
the package utilities it is best to be sure:
upgradepkg --install-new /root/slackware/a/sed-*.tgz
4. Upgrade everything else (and install new packages):
upgradepkg --install-new /root/slackware/*/*.tgz
5. Make sure your system will boot. If you use LILO, make sure the
paths in /etc/lilo.conf point to a valid kernel and then type 'lilo'
to reinstall LILO. If you use a bootdisk, you'll need to use
makebootdisk to make a new bootdisk using the kernel in /boot.
6. Fix your config files. Some of the config files in /etc are going to
need your attention. You'll find the new incoming config files on
your system with the ".new" extension. You may need to fill these in
with information from your old config files and then move them over.
Feel brave? You can use this little script to install all of the
.new config files in /etc. If you've made any local changes you'll
need to add them to the newly installed files. Your old config files
will be copied to *.bak. Anyway, it might be an easier starting
point. Here it is:
#!/bin/sh
cd /etc
find . -name "*.new" | while read configfile ; do
if [ ! "$configfile" = "./rc.d/rc.inet1.conf.new" \
-a ! "$configfile" = "./group.new" \
-a ! "$configfile" = "./passwd.new" \
-a ! "$configfile" = "./shadow.new" ]; then
cp -a $(echo $configfile | rev | cut -f 2- -d . | rev) \
$(echo $configfile | rev | cut -f 2- -d . | rev).bak 2> /dev/null
mv $configfile $(echo $configfile | rev | cut -f 2- -d . | rev)
fi
done
You'll probably also need to edit your /etc/X11/xorg.conf to change
the name of the keyboard driver from "Keyboard" to "kbd". I don't
know why this changed, but it did.
7. Return to multi-user mode:
telinit 3
8. Remove obsolete packages.
If you go into /var/log/packages and take a look at the package list:
ls -lt | less
You may spot some old, obsolete, or discontinued packages. If so,
you can remove these using 'removepkg'.
9. Remove KDE language bloat. By upgrading all packages using
--install-new you've probably installed all of the KDE language
translations from the KDEI series, which will use up about
500MB. If you need only US English, you may remove the KDE
language packs like this:
cd /var/log/packages
removepkg kde-i18n* koffice-l10n*
Even if you need one of these, it might be best to start by
removing them all, and then go back and install the ones you
need with installpkg.
At this point you should be running Slackware 11.0. :-)
I wish everyone good luck with this!
OC GURU bios update
82757 (2624) 4ever
Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )
Oddelek: Operacijski sistemi
1960128046 (43720) RedDrake
Win XP SP2 in Blutooth
82442 (2287) jast
Iščem alternativo vuduju
122441 (2205) Arthur
Kaj za vraga je to RAID?
142827 (2492) krucymucy
