Forum » Operacijski sistemi » linux firewall
linux firewall
root ::
Imam problem kako bi lahko aplikaciji onemogočil dostop do interneta. Mogoče kdo ve s čim si bi lahko pomagal?
man iptables
Tazadna pride v poštev, ker se navezuje na ime programa. Vendar to več ne dela v kernelih nad 2.6.13. So onemogočli, ker baje povzroča napake, pri uporabi dveh ali več procesorjev. Na 2.6.13 še dela normalno.
owner
This module attempts to match various characteristics of the packet creator, for locally-generated packets. It is only
valid in the OUTPUT chain, and even this some packets (such as ICMP ping responses) may have no owner, and hence never
match.
--uid-owner userid
Matches if the packet was created by a process with the given effective user id.
--gid-owner groupid
Matches if the packet was created by a process with the given effective group id.
--pid-owner processid
Matches if the packet was created by a process with the given process id.
--sid-owner sessionid
Matches if the packet was created by a process in the given session group.
--cmd-owner name
Matches if the packet was created by a process with the given command name. (this option is present only if
iptables was compiled under a kernel supporting this feature)
NOTE: pid, sid and command matching are broken on SMP
| » | Apache virtualhostOddelek: Omrežja in internet | 2121 (1850) | pegasus |
| » | Win 7 blue screen in restartOddelek: Operacijski sistemi | 2914 (2653) | Duhec |
| » | Madžarska uzakonila cenzuro medijev (strani: 1 2 )Oddelek: Novice / NWO | 24280 (20129) | Mr.B |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20256 (17096) | arrigo |
| » | Pomoč pri MySQL in PHP...Oddelek: Programiranje | 2380 (2248) | darh |
