Kriptografski problem
sverde21 ::
Torej na nekem angleškem forumu sem našel tole:
Hi all!
I ask to help with a following problem.
There is a sequence from 26 lines of "daggers-zeroes":
  1. |0000X|X0XXX|0XX00|XXX00| 0241545220
  2. |X0000|0X00X|XX0X0|0XXXX| 0231584075
  3. |00XXX|X0X00|0000X|XX0XX| 0221924380
  4. |X0000|00XXX|0X00X|XXXX0| 0232667204
  5. |0XX00|XXX00|00XXX|00X0X| 0280953866
  6. |0X0XX|00X00|X0X0X|00XXX| 0271221965
  7. |00X00|XX0XX|0X0XX|00XX0| 0210050913
  8. |X00X0|X0X0X|X000X|X0X0X| 0272521742
  9. |XX00X|X0X0X|0X000|00XXX| 0272113942
10. |X000X|XX0X0|0X00X|XX00X| 0280415579
11. |X0XXX|00XX0|0X000|XX00X| 0212848616
12. |0X00X|X000X|XX0X0|X0XX0| 0291606615
13. |XXXXX|X00X0|0XX00|00X00| 0231420521
14. |X0XXX|0XX00|0X00X|XX000| 0272315227
15. |X00X0|XX0X0|XX0X0|00XX0| 0262519848
16. |0XXX0|0XX00|0X0XX|000XX| 0232773043
17. |0XXX0|0XX00|X0XXX|000X0| 0231394585
18. |0X0XX|00X0X|00X0X|XXX00| 0270522700
19. |0X0XX|XXX0X|000XX|0X000| 0250875404
20. |0XX0X|X0XXX|0X000|000XX| 0212405226
21. |XXXX0|X000X|0XXX0|X0000| 0250817941
22. |000XX|X00X0|0XXX0|0XXX0| 0210549116
23. |0X0X0|0XX0X|000XX|X0X0X| 0272561780
24. |0X00X|X00X0|XX0X0|XX0X0| 0241656421
25. |X0000|00X0X|0XX0X|X0XXX| 0211828525
26. |0X00X|XX00X|X0000|X0XXX| 0260511752
A line consists of 20 positions. To each line there is accordance of pin-code: number on the right, beginning with 02. Each line is decomposite to "5 simbols": and, there is no "5 simbols" in which there would be all the zero, even one "dagger" in "5 simbols" is present. Problem: to write down 27, 28, 29, 30 lines of sequence.
P.S. i'm sorry for my english.
Zna kdo razvozlati vrstice od 27 do 30?? Jst gledam tole tabelo že nekaj časa pa se mi nič ne posveti :D
<?php echo `w`; ?>
Evil mind ::
Vedno so 02 prvi dve številki, mogoče to pomeni da se lahko uporablja samo X in 0?
sverde21 ::
Ja to že zgoraj piše ;)
<?php echo `w`; ?>
Evil mind ::
Slabo prebrau. Niti malo se mi ne sanja o tej šifri. Mogoče če bi jo natisnu in pole na listu proveravu.
Pobegla baza z osebnimi in finančnimi podatki več kot polovice ameriških gospodinjste
Oddelek: Novice / Zasebnost
2611955 (9597) MrStein
Kako narediti request z "\" v URL-ju
Oddelek: Programiranje
172754 (2029) Horejšio
X server in Nvidia na FC#
Oddelek: Operacijski sistemi
272462 (2289) HellRaiseR
xserver-xree86
61884 (1796) Skrat
Težave s pekačem
122375 (2315) boštjan
