X server in Nvidia na FC#
mov ax 0x7c0 ::
Zdravo!
Naložil sem si Nvidia gonilnike na linux FC3... vse lepo in prav... skunfiguriral datoteko xorg.conf kot je v navodilih... Tu pa se pojavi problem ko hočem s tako konfigurirano datoteko xorg.conf pognati X server se le-ta noče zagnat... Javi mi neko napako ki pa je ne razumem... kao da je najdlo screen ampak noben od screenov nima pravilnih nastavitev... Fora je pa v tem da jaz v xorg.conf pod Section "screen" nisem spreminjal čisto nič... Torej kaj bi lahko bilo narobe? Vnaprej, hvala za odgovore!
Vsak dan nekaj novega :)
CCfly ::
Prilepi vsebino datoteke /etc/X11/xorg.conf.
"My goodness, we forgot generics!" -- Danny Kalev
mov ax 0x7c0 ::
# Xorg configuration created by system-config-display
Section "ServerLayout"
Identifier "single head configuration"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
# RgbPath is the location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
RgbPath "/usr/X11R6/lib/X11/rgb"
FontPath "unix/:7100"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "fbdevhw"
Load "glx"
Load "record"
Load "freetype"
Load "type1"
Load "dri"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
# Option "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# Option "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a non-U.S.
# keyboard, you will probably want to use:
# Option "XkbModel" "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "de"
# or:
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:swapcaps"
# Or if you just want both to be control, use:
# Option "XkbOptions" "ctrl:nocaps"
Identifier "Keyboard0"
Driver "kbd"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "IMPS/2"
Option "Device" "/dev/input/mice"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "yes"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Unknown monitor"
HorizSync 31.5 - 37.9
VertRefresh 50.0 - 70.0
Option "dpms"
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nv"
VendorName "Videocard vendor"
BoardName "NVIDIA GeForce 4 (generic)"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 16
Modes "800x600" "640x480"
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Group 0
Mode 0666
EndSection
to zgoraj je vsebina original xorg.conf...
v navodilih pa piše da moram menjati v Section"Device" vrstico Driver "nv" z Driver "nvidia"... in da moram v Section"Module" zbrisati vrstico Load "dri"... vse to naredim in mi javi:
Screen(s) found but none have a usable configuration, potem oa fatal server error: no screen found...
borchi ::
Load "dri"
#Load "dri"
Driver "nv"
Driver "nvidia"
ejejej, nekdo ni prebral README.TXT?
l'jga
CCfly ::
Spremembe:
#Load "dri"
Popravi specifikacije od monitorja (zelo verjetno vzrok za napako):
Driver "nvidia"
Dodaj še kakšno višjo ločljivost:
Modes "1024x786" "800x600" "640x480"
CCfly ::
Saj ga je prebral samo verjetno dobiva izpis, da je frekvenca izven obsega, zaradi generičnih specifikacij za monitor, ki veljajo za nek predpotopni model.
borchi ::
res? sprašujem zato, ker še vedno kadar sem narobe nastavu frekvence se je xorg lepo zagnal. na monitorju je pa seveda bil zmazek ali pa "freq. out of range". kako lahko x server ve, da je poslal "out of range" modeline? večina monitorjev to napiše na zaslon. kako pa komunicira nazaj z x serverjem?
drugače pa, slava, zakaj postaš originalni xorg.conf, če veš, da ga moraš popravit?
l'jga
mov ax 0x7c0 ::
README.txt sem prebral!!!!!!!!!!!
Pa saj ko popravim xorg.conf tako kot piše v navodilih mi javi napako!!!! Tako da X server zaganjam z original xorg.cong kljub novim gonilnikom...
borchi ::
lih danes sem se s FC3 igral. nvidia driverje sem mel up&running v 30 sec.
mislim, da je čas, hiphiphip strašni trik, da postaš error, ki ti ga vrže vn oz. log X serverja.
l'jga
mov ax 0x7c0 ::
Upam da bo kaj pomagalo log file od X serverja:
X Window System Version 6.8.1
Release Date: 17 September 2004
X Protocol Version 11, Revision 0, Release 6.8.1
Build Operating System: Linux 2.6.9-1.751_ELsmp i686 [ELF]
Current Operating System: Linux Slavc 2.6.9-1.667 #1 Tue Nov 2 14:41:25 EST 2004 i686
Build Date: 01 December 2004
Build Host: tweety.build.redhat.com
Before reporting problems, check http://wiki.X.Org
to make sure that you have the latest version.
Module Loader present
OS Kernel: Linux version 2.6.9-1.667 (bhcompile@tweety.build.redhat.com) (gcc version 3.4.2 20041017 (Red Hat 3.4.2-6.fc3)) #1 Tue Nov 2 14:41:25 EST 2004
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Feb 21 18:53:30 2005
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "single head configuration"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Videocard0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(**) FontPath set to "unix/:7100"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(WW) Open APM failed (/dev/apm_bios) (No such file or directory)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.7
X.Org XInput driver : 0.4
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 6.8.1, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 0.7
(--) using VT number 7
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x800000fc, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,1a30 card 1849,1a30 rev 11 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,1a31 card 0000,0000 rev 11 class 06,04,00 hdr 01
(II) PCI: 00:1d:0: chip 8086,24c2 card 1849,24c0 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,24c4 card 1849,24c0 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,24c7 card 1849,24c0 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,24cd card 1849,24c0 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev 82 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,24c0 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,24cb card 1849,24c0 rev 02 class 01,01,8a hdr 00
(II) PCI: 00:1f:5: chip 8086,24c5 card 1849,4961 rev 02 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0171 card 107d,2870 rev a3 class 03,00,00 hdr 00
(II) PCI: 03:05:0: chip 14f1,2f00 card 14f1,2004 rev 01 class 07,80,00 hdr 00
(II) PCI: 03:0a:0: chip 10ec,8139 card 1849,8139 rev 10 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,3), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,2), BCTRL: 0x000f (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xddd00000 - 0xdfdfffff (0x2100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xcdb00000 - 0xddbfffff (0x10100000) MX[B]
(II) Bus 3: bridge is at (0:30:0), (0,3,3), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 3 I/O range:
[0] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[1] -1 0 0x0000c400 - 0x0000c4ff (0x100) IX[B]
[2] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[3] -1 0 0x0000cc00 - 0x0000ccff (0x100) IX[B]
(II) Bus 3 non-prefetchable memory range:
[0] -1 0 0xdfe00000 - 0xdfefffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation NV17 [GeForce4 MX 440] rev 163, Mem @ 0xde000000/24, 0xd0000000/27, 0xddb80000/19, BIOS @ 0xdfde0000/17
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xe3ffffff to 0xdfffffff
(II) Active PCI resource ranges:
[0] -1 0 0xdfeeff00 - 0xdfeeffff (0x100) MX[B]
[1] -1 0 0xdfef0000 - 0xdfefffff (0x10000) MX[B]
[2] -1 0 0xdffff900 - 0xdffff9ff (0x100) MX[B]
[3] -1 0 0xdffffa00 - 0xdffffbff (0x200) MX[B]
[4] -1 0 0x10000000 - 0x100003ff (0x400) MX[B]
[5] -1 0 0xdffffc00 - 0xdfffffff (0x400) MX[B]
[6] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[7] -1 0 0xdfde0000 - 0xdfdfffff (0x20000) MX[B](B)
[8] -1 0 0xddb80000 - 0xddbfffff (0x80000) MX[B](B)
[9] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
[10] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B)
[11] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[12] -1 0 0x0000cc00 - 0x0000cc07 (0x8) IX[B]
[13] -1 0 0x0000dc00 - 0x0000dc3f (0x40) IX[B]
[14] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[15] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[16] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX[B]
[17] -1 0 0x0000e800 - 0x0000e81f (0x20) IX[B]
[18] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
[1] -1 0 0x00100000 - 0x0fffffff (0xff00000) MX[B]E(B)
(II) All system resource ranges:
[5] -1 0 0xdfeeff00 - 0xdfeeffff (0x100) MX[B]
[6] -1 0 0xdfef0000 - 0xdfefffff (0x10000) MX[B]
[7] -1 0 0xdffff900 - 0xdffff9ff (0x100) MX[B]
[8] -1 0 0xdffffa00 - 0xdffffbff (0x200) MX[B]
[9] -1 0 0x10000000 - 0x100003ff (0x400) MX[B]
[10] -1 0 0xdffffc00 - 0xdfffffff (0x400) MX[B]
[11] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[12] -1 0 0xdfde0000 - 0xdfdfffff (0x20000) MX[B](B)
[13] -1 0 0xddb80000 - 0xddbfffff (0x80000) MX[B](B)
[14] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
[15] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B)
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[18] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[19] -1 0 0x0000cc00 - 0x0000cc07 (0x8) IX[B]
[20] -1 0 0x0000dc00 - 0x0000dc3f (0x40) IX[B]
[21] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[22] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[23] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX[B]
[24] -1 0 0x0000e800 - 0x0000e81f (0x20) IX[B]
[25] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "fbdevhw"
(II) Loading /usr/X11R6/lib/modules/linux/libfbdevhw.a
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 6.8.1, module version = 0.0.2
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.6629
Module class: XFree86 Server Extension
ABI class: XFree86 Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="X.Org Foundation"
compiled for 6.8.1, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 6.8.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="X.Org Foundation"
compiled for 6.8.1, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "nvidia"
(II) Loading /usr/X11R6/lib/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.4
(II) LoadModule: "kbd"
(II) Loading /usr/X11R6/lib/modules/input/kbd_drv.o
(II) Module kbd: vendor="X.Org Foundation"
(II) NVIDIA X Driver 1.0-6629 Wed Nov 3 13:14:07 PST 2004
(II) NVIDIA Unified Driver for all NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset NVIDIA GPU found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[16] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[17] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[18] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[22] -1 0 0x0000cc00 - 0x0000cc07 (0x8) IX[B]
[23] -1 0 0x0000dc00 - 0x0000dc3f (0x40) IX[B]
[24] -1 0 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[25] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[26] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX[B]
[27] -1 0 0x0000e800 - 0x0000e81f (0x20) IX[B]
[28] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
[29] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[30] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(--) NVIDIA(0): Linear framebuffer at 0xD0000000
(--) NVIDIA(0): MMIO registers at 0xDE000000
(EE) NVIDIA(0): Failed to initialize the NVIDIA kernel module!
(EE) NVIDIA(0): *** Aborting ***
(II) UnloadModule: "nvidia"
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.X.Org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
CCfly ::
Kaj ti napiše modprobe nvidia ?
mov ax 0x7c0 ::
modprobe nvidia mi da tole:
[root@Slavc ~]# modprobe nvidia
NVRM: loading NVIDIA Linux x86 NVIDIA Kernel Module 1.0-6629 Wed Nov 3 13:12:51 PST 2004
sem bolj začetnik kot ne v linux-u tako da moram vprašat... A je to vredi ali ne?
CCfly ::
Poskusi zdaj zagnati X-e.
mov ax 0x7c0 ::
Ko naredim modprobe nvidia, gre X server zagnat! Vse lepo in prav... sam to moram vsakič delat ko znova zaganjam sistem... to pa je malo nerodno... Kje lahko nastavim da se bo modul nvidia naložil v jedro med zagonom? Aja pa kaj se tiče ločljivosti, zgleda da ne gre več kot 800x600... kajti če dodam pod Mods še 1024x786 to enostavno prezre oz. ne upošteva, ali kako naj prav to povem... če dam pod Mods še 1024x786 in dam zaženem Xserver se mi ta zažene v ločljivosti 640x480 in ko želim spremeniti ločljivost lahko največjo izberem 800x600... prosim pomagajte, kajti počasi me že malo v glavi pika :) no ja, še sreča da samo malo :)
CCfly ::
Ko boš popravil specifikacije od monitorja boš imel na voljo tudi višjo ločljivost. Pogooglaj za specifkacijami tvojega monitorja.
Dodaj vrstico:
nvidia
v datoteko /etc/modules.autoload.d/kernel-2.6
  • spremenilo: CCfly ()
mov ax 0x7c0 ::
Ok, resolucija je sedaj prava! Problem pa je da pri meni ne obstaja /etc/modules.autoload.d/kernel-2.6!!!
CCfly ::
Poglej če imaš datoteko /etc/rc.modules in vpiši
/sbin/modprobe nvidia
mov ax 0x7c0 ::
Tudi te datoteke ni v mapi /etc/... je pa:
-rc.sysinit
-rc.local
-in mapa rc.d/
a tu kam napišem?
CCfly ::
Poglej v poddirektoriju rc.d.
borchi ::
mogoče /etc/modules.conf in vpišeš not nvidia?
l'jga
CCfly ::
V modules.conf so ponavadi aliasi.
mov ax 0x7c0 ::
V poddirektoriju rc.d/ ni nič vezi moduli.... v modules.conf pa so samo aliasi! Pa kje se nastavijo avtoload modulov? Arghh to je za znoret!
CCfly ::
Potem pa vpiši kar v rc.local.
moj_nick ::
/etc/modprobe.conf bi pa moral imeti.
110111001001010001010000
borchi ::
ja, mislu sem modprobe.conf (kot je moj_nick povedal). sori.
l'jga
mov ax 0x7c0 ::
Vsebina modprobe.conf:
alias eth0 8139too
alias snd-card-0 snd-intel8x0
options snd-card-0 index=0
install snd-intel8x0 /sbin/modprobe --ignore-install snd-intel8x0 && /usr/sbin/alsactl restore >/dev/null 2>&1 || :
remove snd-intel8x0 { /usr/sbin/alsactl store >/dev/null 2>&1 || : ; }; /sbin/modprobe -r --ignore-remove snd-intel8x0
alias usb-controller ehci-hcd
alias usb-controller1 uhci-hcd
alias char-major-195* nvidia
a tu v zadnjo vrstico napišem:
CCfly ::
Vpiši v /etc/rc.local pa bo.
HellRaiseR ::
A mogoče kdo ve zakaj se modul ne naloži avtomatično čeprav bi se po useh nastavitvah sodeč(usaj pr men) mogu. Zadevo sm tud jst rešu tko da sem dal stvar kar u rc.local, vseen pa me zanima če je kdo že rešu ta problem drugač.
Ubuntu vprašanja
Oddelek: Operacijski sistemi
483382 (2131) roksson
Linux Read only file system ??
91983 (1942) 2g00d4u
Gentoo Xorg.conf LCD - sistem se obesi
362116 (1909) Mr.B
kde in resolucija
101995 (1863) moj_nick
xserver-xree86
61882 (1794) Skrat
