xserver-xree86
xserver-xree86
vojkoz ::
Hay!
mam eden problem namestisl sem si x windows na Linux. pa mi javi napako ko ga poženem z startx :
Fatal server error:
Module load failure
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to submit@bugs.debian.org.
XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"
after 0 requests (0 known processed) with 0 events remaining.
Imam pa 3Dfx Voodoo 3 2000
če ve kdo kaj je narobe prosim naj pove..
probal sem že z dpkg-reconfigure xserver-xfree86
aja tam navem kaj moram napisat ko sprašuje za PCI:nn:nn:nn
Sicer je ta voodoo grafična na AGP..
L.p.
  • spremenil: vojkoz ()
Skrat ::
Dej postaj vsebino loga /var/log/XFree86.0.log
Tm not pise, zakaj se ti Xi sesujejo >:D
Free software is a matter of liberty, not price.
vojkoz ::
This is a pre-release version of XFree86, and is not supported in any
way. Bugs may be reported to XFree86@XFree86.Org and patches submitted
to fixes@XFree86.Org. Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs)
XFree86 Version 4.1.0.1 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 21 December 2001
If the server is older than 6-12 months, or if your card is
newer than the above date, look for a newer version before
reporting problems. (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.6.3-bk2 i686 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Sun Jul 11 12:39:47 2004
(==) Using config file: "/etc/X11/XF86Config-4"
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Generic Monitor"
(**) | |-->Device "Micro"
(**) |-->Input Device "Generic Keyboard"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc102"
(**) XKB: model: "pc102"
(**) Option "XkbLayout" "us"
(**) XKB: layout: "us"
(**) Option "XkbVariant" "us"
(**) XKB: variant: "us"
(==) Keyboard: CustomKeycode disabled
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "Generic Mouse"
(WW) The directory "/usr/lib/X11/fonts/cyrillic" does not exist.
Entry deleted from font path.
(**) FontPath set to "unix/:7100,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/100dpi/:unscaled,/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/$
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 8
(WW) Cannot open APM
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.1
XFree86 Video Driver: 0.4
XFree86 XInput driver : 0.2
XFree86 Server Extension : 0.1
XFree86 Font Renderer : 0.2
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.2
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 0.1.0
ABI class: XFree86 Video Driver, version 0.4
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,0691 card 0000,0000 rev 44 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,8598 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:07:0: chip 1106,0686 card 1106,0000 rev 1b class 06,01,00 hdr 80
(II) PCI: 00:07:1: chip 1106,0571 card 0000,0000 rev 06 class 01,01,8a hdr 00
(II) PCI: 00:07:2: chip 1106,3038 card 0925,1234 rev 0e class 0c,03,00 hdr 00
(II) PCI: 00:07:3: chip 1106,3038 card 0925,1234 rev 0e class 0c,03,00 hdr 00
(II) PCI: 00:07:4: chip 1106,3057 card 0000,0000 rev 20 class 06,00,00 hdr 00
(II) PCI: 00:07:5: chip 1106,3058 card 1106,3058 rev 21 class 04,01,00 hdr 00
(II) PCI: 00:0f:0: chip 10ec,8139 card 1113,ec01 rev 10 class 02,00,00 hdr 00
(II) PCI: 00:10:0: chip 10ec,8139 card 11f6,8139 rev 10 class 02,00,00 hdr 00
(II) PCI: 01:01:0: chip 1023,9750 card 1023,9750 rev f3 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) PCI-to-ISA bridge:
(II) PCI-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0c (VGA_EN is set)
(II) Bus 1 I/O range:
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xd4000000 - 0xd5ffffff (0x2000000) MX[B]
(II) Bus 1 prefetchable memory range:
(II) Bus -1: bridge is at (0:7:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(II) Bus -1: bridge is at (0:0:0), (-1,-1,0), BCTRL: 0x08 (VGA_EN is set)
(--) PCI:*(1:1:0) Trident 3DImage975 rev 243, Mem @ 0xd5400000/22, 0xd5800000/17, 0xd5000000/22
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xd7001000 - 0xd70010ff (0x100) MX[B]
[1] -1 0 0xd7000000 - 0xd70000ff (0x100) MX[B]
[2] -1 0 0xd0000000 - 0xd3ffffff (0x4000000) MX[B]
[3] -1 0 0xd5000000 - 0xd53fffff (0x400000) MX[B](B)
[4] -1 0 0xd5800000 - 0xd581ffff (0x20000) MX[B](B)
[5] -1 0 0xd5400000 - 0xd57fffff (0x400000) MX[B](B)
[6] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[7] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[8] -1 0 0x0000e400 - 0x0000e403 (0x4) IX[B]
[9] -1 0 0x0000e000 - 0x0000e003 (0x4) IX[B]
[10] -1 0 0x0000dc00 - 0x0000dcff (0x100) IX[B]
[11] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[12] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[13] -1 0 0x0000d000 - 0x0000d00f (0x10) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xd7001000 - 0xd70010ff (0x100) MX[B]
[6] -1 0 0xd7000000 - 0xd70000ff (0x100) MX[B]
[7] -1 0 0xd0000000 - 0xd3ffffff (0x4000000) MX[B]
[8] -1 0 0xd5000000 - 0xd53fffff (0x400000) MX[B](B)
[9] -1 0 0xd5800000 - 0xd581ffff (0x20000) MX[B](B)
[10] -1 0 0xd5400000 - 0xd57fffff (0x400000) MX[B](B)
[11] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[12] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[13] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[14] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[15] -1 0 0x0000e400 - 0x0000e403 (0x4) IX[B]
[16] -1 0 0x0000e000 - 0x0000e003 (0x4) IX[B]
[17] -1 0 0x0000dc00 - 0x0000dcff (0x100) IX[B]
[18] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[19] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[20] -1 0 0x0000d000 - 0x0000d00f (0x10) IX[B]
(II) LoadModule: "GLcore"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
ABI class: XFree86 Server Extension, version 0.1
(II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
Module class: XFree86 Server Extension
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.1.9
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading sub module "GLcore"
(II) Reloading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) LoadModule: "pex5"
(II) Loading /usr/X11R6/lib/modules/extensions/libpex5.a
(II) Module pex5: vendor="The XFree86 Project"
(II) Loading extension X3D-PEX
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "speedo"
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
(II) Module speedo: vendor="The XFree86 Project"
(II) Loading font Speedo
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "vbe"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="The XFree86 Project"
(II) LoadModule: "xie"
(II) Loading /usr/X11R6/lib/modules/extensions/libxie.a
(II) Module xie: vendor="The XFree86 Project"
(II) Loading extension XIE
(II) LoadModule: "xtt"
(II) Loading /usr/X11R6/lib/modules/fonts/libxtt.a
Duplicate symbol TT_FreeType_Version in /usr/X11R6/lib/modules/fonts/libxtt.a:xttmodule.o
Also defined in /usr/X11R6/lib/modules/fonts/libfreetype.a
Fatal server error:
Module load failure
Skrat ::
V datoteki /etc/X11/XF86Config-4 zakomentiraj vrstico v sekciji Modul, kjer je Load "xtt".
In potem startx
vojkoz ::
isto mi napise ne gree.. sam zdej sem dal grafično drugo noter D
01:01.0 VGA compatible controller: Trident Microsystems 3DIm`age 975 (rev f3)
tudi je na AGP
moj_nick ::
Zakaj imaš verzijo 4.1? Zadnja verzija s spejemljivo licenco je 4.3
110111001001010001010000
Skrat ::
Katero distribucijo uporabljas? Predvidevam da Debiana, glede na to da si v prvem postu rekel, da si probal dpkg-reconfigure. Kateri paket si namestil, ko si namescal Xe?
Glede graficne kartice: glede na tvoj XFree86.log ti zadeva niti ne pride do loadanja modula za graficno kartico, tako da to ne vem ce bo pomagalo. Drugace je driver, ki ga uporablja graficna kartica prav tako dolocen v /etc/X11/XF86Config-4 pod Section "Device", parameter Driver "nekaj". Ta 'nekaj' je ime modula - v tvojem primeru verjetno trident, drugace pa lahko poskusis z vesa (kar bi moralo delati skoraj povsod).
Spremljaj, kaj ti napise v log in poskusi ugotovit, katera stvar ti povzroca probleme. V log se zapise, kaj se zgodi, ko se startajo Xi (glede na config datoteko) in lahko vidis, do kam zadeva pride oz. kje se sesuje.
X server in Nvidia na FC#
Oddelek: Operacijski sistemi
272461 (2288) HellRaiseR
Gentoo Xorg.conf LCD - sistem se obesi
362116 (1909) Mr.B
Gentoo setup problem
252210 (2034) G2
kde in resolucija
101995 (1863) moj_nick
Linux / ATI Radeon / problem z driverji
132224 (2041) ahac
