Prenova spletnega mesta Slo-Tech
1 2
3
BluPhenix ::
Sej ne piše, da root nima DOSTOPA do vsega, piše le, da NIMA PRAVICE za pisanje po disku. Meni se to sliši precej različno >:D Je pa dobra varjanta. Ampak če nič nima pravic za pisanje po disku, kaj pa piše po disku?
Podpisa ni več, ker so me poskušali asimilirati.
CaqKa ::
predvsem se naj porihta da taki linki kot so tale delujejo.. ne pa da dobiš en polinkan presledek:
(st.povezava http://videos.timekiller.com/index~show...
poweroff ::
Ni nujno, da ima root dostop do vsega. Recimo: Hardened Debian, NSA's SE Linux, oziroma išči pod "mandatory access controls".
SELinux is Linux security suite relying on the Linux Security Modules framework which includes Mandatory Access Control and Role-Based Access Control (with Type Enforcement (r) ), in detriment of the old Discretionary Access Control used by standard *nix systems (Linux as well), and bringing advanced & complex permissions and access control over files, sockets, devices... In short, with SELinux you can define explicit rules about what subjects ( users, programs ) can access which objects ( files, sockets, devices ) and in what conditions depending on fine-grained settings (macros, types, roles...) provided within a compiled, binary policy file with a complex and flexible configuration language.
It gives you the ability to separate programs and thereby ensuring a high level of security within the operating system by selecting what information can explicitly be accessed and the conditions it could do so, in other words, it will control programs and users so they could access, manipulate and use the information they need explicitly to work, and not anymore until you explicitly set it.
BTW: zadeva obstaja tudi za Ubuntuja... če ravno koga zanima.
sudo poweroff
sverde21 ::
OK obstaja ampak ST IMO nima tega :D
<?php echo `w`; ?>
poweroff ::
In YOUR opinion, da.
sudo poweroff
1 2
3
Sodobni moški
Oddelek: Problemi človeštva
202581 (1859) Saladin
Anketno - Raziskovalna skripta
Oddelek: Izdelava spletišč
71574 (1466) Zeberdee
Prenova spletnega mesta Slo-Tech (strani: 1 2 3 )
Oddelek: Novice / Obvestila
10414805 (12013) poweroff
Slo-tech kot empirični primer v doktorski
Oddelek: Slo-Tech
121681 (1501) delfinus
Nova anketa
Oddelek: Novice / Ankete
72730 (2730) undefined
