Forum » Pomoč in nasveti » Kje se skrivajo TV kanali pri TV tunerju
Šimpanz ::
Imam TV tuner Leadtek TV2000 XP Xpert. Zdaj moram na novo naložiti Windowse in ne bi spet rad na novo nastavljal 40 TV kanalov. Ali kdo v kje se nahajajo nastavitve za TV kanale, tako da bi datoteko z nastavitvami samo skopiral na novi disk.
Vikking ::
How can I save the current channel settings and profiles in order to re-load them after installation of Windows is completed?
Before you installing new Windows, reserve the files and all configurations in the Registry.
Reserve the following files in the PVR folder:
WFPRFL.cfg (Capture profile settings)
WFSCHDL.dat (Schedule settings)
Winfq.cfg (Frequency table)
Wincdl.cfg (Customized frequency table)
Run "regedit.exe" from the Windows "Start" menu, and then export the content in "HKEY_CURRENT_USER\SOFTWARE\Leadtek\video (refer to graphic)" to a Registry file, for example, export the "winfast_pvr.reg".
After you re-intall the new Windows system, just copy and replace these files into a PVR's folder, and execute the Regitry file "winfast_pvr.reg". You can get the same configuration settings as before.
| » | Po 20 letih se poslavlja stari logotip Windows (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 24077 (19622) | dope1337 |
| » | A je to virus?Oddelek: Pomoč in nasveti | 2822 (2475) | fulgur |
| » | Katero TV Katico(tuner)? (strani: 1 2 3 4 )Oddelek: Kaj kupiti | 21830 (14870) | Izi |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2542 (2508) | Mercier |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2611 (2207) | Swiwer |
