Navijanje Pentiuma 4
2
Do koliko MHz se lahko P4 3.20E (478) "Prescott" navije?
Imam pa:
Hladilnik original Intel
ASUS P4C800-E Deluxe
2x 512 Infineon RAMa
  • spremenil: mtosev ()
5er--> ::
Tega ti noben ne more povedati. Probaj. Navijaj postopoma in preverjaj stabilnost s Prime95. Po možnosti ga inštaliraj 2X v različni mapi in daj "Affinity" v 1. na CPU0 in CPU1 v drugem.
(seveda lahko stabilnost testiraš tudi s kakšnim drugim programom)
billy ::
Kakšne ime S-spec ???
Če je SL7E5, potem lahko z zračnim do 4.2Ghz, z vodnim do 4.5 z vapo pa blizu 5 :)
General Information :
Internal Specification : Intel(R) Pentium(R) 4 CPU 3.20GHz
Codename : Prescott
Revision : D0
Technology : 0.09µ
CPU ID : F.3.4
Microcode : MU0F34014
Number of Logical Processors : 2
Features :
VME - Virtual Mode Ext. : Yes
DE - Debugging Extension : Yes
PSE - Page Size Extension : Yes
TSC - Time Stamp Counter : Yes
MSR - Model Specific Registers : Yes
PAE - Physical Address Extension : Yes
MCE - Machine Check Exception : Yes
APIC - Local APIC Built-in : Yes
SEP - Fast System Call : Yes
MTRR - Memory Type Range Reg. : Yes
PGE - Page Global Enable : Yes
MCA - Machine Check Architecture : Yes
PAT - Page Attribute Table : Yes
PSE36 - 36-bit Page Size Extension : Yes
PSN - Unique Serial Number : No
DS - Debug Trace & EMON Store : Yes
ACPI - Software Clock Control : Yes
SS - Self Snoop : Yes
TM - Thermal Monitor : Yes
HTT - Hyper-Threading : Yes
SBF - Signal Break on FERR : Yes
MON - Monitor/Mwait : Yes
DSCPL - CPL qualified Debug Store : Yes
TM2 - Thermal Monitor 2 : No
CID - Context ID : Yes
EST - Enhanced SpeedStep Tec... No
NX Bit - No-execute Page Protec... No
VMX - Vanderpool Technology : Yes
Miscellaneous :
FPU - Co-processor Built-in : Yes
CX8 - CMPXCHG8B : Yes
CX16 - CMPXCHG16B : No
CMOV - Conditionnal Move Inst. : Yes
CLF - Cache Line Flush : Yes
FXSR - Fast Float Save & Restore : Yes
DAZ - Denormals Are Zero : Yes
MMX Technology : Yes
SSE Technology : Yes
SSE2 Technology : Yes
SSE3 Technology : Yes
EM64T Technology : No
IA-64 Technology : No
PBE - Pend. Brk. EN. : Yes
Features Hyper-Threading :
Technology : Yes
APIC ID #1 : 0
APIC ID #2 : 1
Addressing Information :
Physical Addressing max. : 36-bit
Linear Addressing max. : 32-bit
Advanced Settings :
In Order Queue Depth : 12
Fast-Strings : Yes
x87 FPU Opcode : No
Thermal Monitor : No
Split-Lock : Yes
Performance Monitoring : Yes
Prefetch Queue : Yes
Branch Trace Storage : Yes
PRB - Performance Requirement Bit : 0
Mainboard Upgradebility :
Socket/Slot : CPU 1
Upgrade interface : Socket 478
Supported Speed : 3600 MHz (or more)
Supported Voltage : 3.3V
billy ::
s-spec bos nasel samo na procesorju napisano :)
billy ::
Danes sem dobil robo končno (preko ebaya sem nabavljal). Po prvih porodnih krčih sem končno spravil do bootanja :) Zaenkrat imam gori samo navaden hladilnik od 2.6C northoowda, potem veste kako slabo hladi. Gor je tudi samo 256 corsair 3200LL(winbond UTT še čakajo v tejle mašini na svojo šanso) ramov ter PCI grafa, to pa tudi vse :) napajalnik je čist navaden 300W. Uspel sem navit na 3.8 brez problema, pri 4ghz pa so se že v biosu začele pojavljati kvake namesto znakov/črk. Temp proca bila celo 60°C.
No..jutri pride vodno hlajenje pa lepo v kišto zmečem vse da še priklopim disk in ostalo potem pa gremo na 4.5ghz :)
Legoless ::
Malo mi vidva povejta kakšne imata kaj temp in ker proc imaš ti billy? Jaz sem s 3.4 GHz LGA775 Prescottom dosegel z box hladilnikom 4.1 GHz, ampak mi je malo upočasnjevalo proc zaradi temp. Na 3.4 GHz sem imel z box hladilnikom idle okol 49 °C, full load 58 °C, 1.36 V, na 4.1 GHz, sem mel idle 56 °C, full load 72 °C, 1.4 V. Zdaj imam na vodnem na 3.4 GHz, 1.36 V, idle 30 °C, full load 40 °C, na 4.1 GHz, 1.52 V, idle 40 °C, full load 49 °C. Prosim če malo napišeta te stvari, z voltažo, fsbjem in vsem, ker me zanima če bi lahko mojega še bolj navil.
billy ::
Po par dnevih testiranja.
3.2 navit na 4.06 (254 fsb) pri 1.52 voltaži idle 40, load 50, vodno hlajenje.
Pravijo, da ni zdravo it prek 1.52 za 24/7 uporabo, tako da sem trenutno na teh hercih. Bom probal nabaviti ddr booster, da bom rame spravil v 1:1, zdaj mi gredo samo do 248. Mogoče še bom s tem pridobil par mhz, ker bi naj navijanje bilo nekoliko slabše na 5:4 ali 3:2 (IC7 max3 plata), tako da upam da bom dosegel 260.
Drugače pa gre proc pri 1.61 volta na 260, kaj več bom pa še danes sprobal...
Sem pa bral da so eni z vapochill dosegli 4.4ghz in celo 4.8 GHZ s tem procesorjem...škoda, da je tako drago to, bo treba doma narediti nekaj ;)
billy ::
update.
Na 1.65 voltazi sem spravil na 265FSB. super pi rezultat 31sec (navadni) in 28sec (z prescott patchom)
Bomo še probali kaj več pozneje ;)
Legoless ::
Hmm, bom še jaz probal bolj navit, a če ni za 24/7 pol brezveze.. Kater maš pa ram? Jaz imam DDR2 VS Corsair, 1x512, gor sem dal revoltecove hladilnike. Pa mi laufa sinhrono 240x17. Mogoče bi lahko dal 250x17 ali več na isti voltaži? S tistimi z vapochillom se pa tako ne morem primerjati :) Mogoče bi enkrat probal laufat na 266x14.
Kaj je prescott patch?
billy ::
Hehe, saj za vsakodneno uporabo je frekvenca nad 4Ghz tako brezveze ;)
To je zgolj za podiranje rekordov :)
Rame pa imam Twinmos UTT, ampak imam max voltažo samo do 3.2volta, kar pomeni da jih ne morem navit nad 248 (toliko je trenutno max), tako da lufam 5:4.
Upam, da čimprej dobim ddr booster da bom laufal sinhrono :)
za prescott patch pa poglej pod Super PI temo, je dal sharp link do njega.
Legoless ::
Hehe, seveda. Sej ko bo laufal 24/7 bo itaq stock, ampak če že mam vodno, bom se pač malo igral. :) Ti imaš DDR ali DDR2 ram? Katero imaš pa plato?
  • spremenil: Legoless ()
billy ::
twinmost speedpremiun DDR400, trenutno na 246mhz 2-2-2-5 pri 3.2V (čakam še na ddr booster) 2x512MB dual seveda :)
plata je pa abit ic7-max3, zaenkrat še nič moddana...še razmišljam če bi jo :)
kakšno maš pa vodno? ker mava zelo podobne temperature :) jaz imam od edija blok, L30 pumpo ter od jugiča radiator :)
kakšno pa maš ti plato? ker nekatere malo čudno merijo temperaturo...
  • spremenilo: billy ()
Legoless ::
Hehe, timingi so tvoji precej boljši :) Seveda pa imaš DDR, ne DDR2 :) Aja, imam tudi Eddyjev blok na CPUju in NBju, L30 pumpo, radiator se pa ne more primerjat s tvojim :D Plato mam pa Asus P5AD2-E Premium, temp pa merim z Asus Probe :)
billy ::
hehe..DDR pač ;)
Aha, imaš asus, kako sem le uganil? ;) torej asus kaze kaksnih 5-10stopinj baje manj. Če je še to res pri novih platah ne vem...
Mam pa slabo hlajenje radiatorja, ker čakam na 2x120mm pa mam kr tisti sobni ventilator ki te poleti hladi...pa je bolj bogi..mislim da slabše piha kot 80mm ki jih mam za hlajenje plate :) bomo vidli kako bo ko dobim 120mm
Temperaturo vode kaj meriš ?
PS, superpi?
Legoless ::
SuperPi izmerim takoj, ko porihtam (zdejle še nekaj delam). Temp vode pa ne merim, oz. bi jo, če bi vedu kak :) Jaz pa mislim, da je izmerjena temperatura plate in proca kar pravšnja.. :) Drugače bom pa bios nanovo updejtal, pa bojo že porihtal.
billy ::
Vodo izmeriš enostavno ;)
Če imaš multimeter, ki ima tudi "sondo" za merit temperaturo jo pač potopiš v posodico...tak multimeter mora imeti skoraj vsaj overclocker :)
Legoless ::
Imam več multimetrov, a nobeden nima sonde za temp :) Kaj če bi kar senzor za temp od regulatorja za vente notri potopil? :)
billy ::
hehe, probaj v glavnem nekak izmerit ;)
al pa kupis tisto napravico ki meri temp po sobah, pa še ima sondo za zunanjo temp, pa si daš na mizo pa meriš temperaturo okolice in temperaturo vode. mislim da je to par jurijev.
Legoless ::
Bo že. Najprej moram druge probleme uredit :)
billy ::
kakšne probleme pa?
Legoless ::
Imam probleme z pritrditvijo Chipset bloka, ker sem en clip iz plate vtrgal.
Legoless ::
Odpravil probleme. :) Zdaj sem navil na 4.25 GHz, 1.525 V, SuperPi:
SuperPi Result (P4 Prescott 4.25 GHz - 250.3x17 - voltage 1.5250 V):
16s 512K
35s 1M
SuperPi Result (P4 Prescott 4.25 GHz - 250.3x17 - voltage 1.5250 V) - Prescott patch:
13s 512K
32s 1M
Imam precej višje kot ti. :s To zaradi FSB-ja mogoče? Sicer pa nevem, na kakšni frekvenci si ti laufal in kater proc sploh maš? 3.4 GHz ? Kje pa vidiš ta S-Spec?
billy ::
Jaz imam 3.2D0 SL7E5 s-spec.
Višji fsb ima nekaj vpliva ja, pa tudi če imajo rami zategnjene timingse pa če so sinhrono ali ne :)
Sem pa mel takrat 265 FSB...probaj še malo več. Do 1.61V lahko greš komot, ampak samo tolko da nardiš benche, potem pa spusti...
s-spec pa se žal vidi samo na procesorju :)
Legoless ::
Ja itaq laufam sinhrono. So pa timingi bol tak tak zaradi DDR2 rama ;) pri 266 imajo 4-4-4-11 ali 5-4-4-11, čeprav se mi zdi, da mi laufa na 5-5-5-15 :S Nevem kako naj spremenim. Za S-Spec pa nevem, če bom še kdaj blok menjal, bom pa pogledal :) Če se res ne da na škatli alpa nekej
LittleDevil ::
Da se tudi na škatli pogledat za stepping.... ProductCode, zadnjih nekaj številk in črk.
Legoless ::
Aha, torej je v mojem primeru SL7J8. Dober stepping? Čeprav proc leti, da je hudič. :)
billy ::
Nimam pojma glede steppinga. Vem samo za 3.2 ;)
Danes sem dobil asus p4c800-e dlx s katero sem lahko procesor še navil dlje kot z abitko. Trenutno sem na 260fsb, z 1.53 voltaže, kar je za 10mhz več kot na abitki in občutetk imam da bo šlo še dlje ;) samo droop mod trimer morm pravilno nastavit...
ŠE zanimivost, o kateri sem že govoril nekaj postov zgoraj. Na asuski imam idel temp 30, load temp 38....koliko sem imel na abitki lahko vidite zgoraj, skoraj 15°C več. Katera leža pa se odločite sami ;)
Zdaj pa iščem rame ki bodo zmožni laufat 1:1 z 2-2-2-5 timingsi...
Good Guy ::
ej dej mi na pm pošl kako si naviju vse postopek kva maš skloplen/vkloplen...
TNX!
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
billy ::
Maš isti procesor kot jaz ?
Good Guy ::
Ja če maš 3.2 prescotta ej ker hladilnik pa maš?
billy ::
Različnih modelov 3.2 prescotov je kar nekaj. In samo nekateri se navijajo dobro.
Hlajenje pa mam vodno...
No do kod si zaenkrat uspel prit? pa napiši kak maš nastavleno pa to, pa ti povem kaj spremeni.
piki64 ::
Hi!
Če uporabljate rezervarje za vodo, morate napisati tudi volumen le teh, kajti od tega je tudi odvisna temperatura procesorja. Kajti če ima nekdo 200 litrski rezervar, bo toplotni tok odvajanja iz tega rezervarja bil večji kot pa ga dovaja sam procesor. V takšnem primeru ne bi potrebovali niti radiatorja, niti ventijev, pa bi vse skupaj laufalo na sobni temperaturi (morda kaki 2 stopinji več).
LP, Piki64
Good Guy ::
zaenkrat sm pršu do 240 fsb-aj ker če dam več se mi komp resetira!
billy ::
Na koliko pa imaš rame? Ter voltažo procesorja?
Good Guy ::
voltaža procesorja je 1.53 rami so 2.5-4-4-8 voltaže teh je 2.85v če bo to kej pomagal aja a maš msn?
billy ::
Razmerje rami in FSB ?
Voltažo imaš čist dovolj, ne dajat več...še to je malce preveč za zračno hlajenje, ampak za navijanje bo ql.
Good Guy ::
razmerje je 5:4
billy ::
Hm...spread spectrum diseblaj.
Rame daj na auto...drugo pa ne vem, mogoče imaš kakšen procesor ki se ne da navijat tako dobro...
Good Guy ::
spectrum mam disalban ramei pa ne vem če mi bojo lavfal na auto
billy ::
Zgleda da je potem to to...
Čeprav ti pomoje dobro laufa procesor, pač hlajenje je velik problem. Probaj nabavit kakšno vodno.
A s-spec koda pa ne veš kakšna je?
Good Guy ::
Hlajenje mam Thermalright XP-90
tisto drugo pa ne razumem!?!
billy ::
s-spec koda!
Najdeš jo na procesorju in na škatlici od procesorja.
Good Guy ::
kej na škatli kaj morm pogledat?
LittleDevil ::
Product Code. Zadnjih 5 znakov napiši, pa ti povemo kater stepping imaš.
Good Guy ::
ESL7E5
billy ::
Pol imaš procesor, ki se zelo dobro navija.
Verjetno te nazaj drži zračno hlajenje.
Na kolko FSB imaš stabilno še? Torej da lahko recimo par ur iigraš igre, al pa je "prime" stable?
Good Guy ::
dons sm cel dan špilu pa mam fsb 240
billy ::
Good Guy ::
ZDej me pa zanima pe neki:
Recimo za moj procesor kašne latence ramov so bolše nizke al visoke?
2
Kateri CPU mate in utemeljite zakaj? (strani: 1 2 3 4 5 )
23929892 (21672) 54j0
ali imam quad q9300?
122535 (2164) gendale
CORE I7- 920 D0 revizija :) (strani: 1 2 3 )
Oddelek: Navijanje
11913678 (8799) blockhd
Navijanje E6400 (strani: 1 2 )
Oddelek: Navijanje
557063 (5880) >>><<<
superPI lestvica (strani: 1 2 3 4 5 6 7 8 9 )
Oddelek: Navijanje
40136286 (21750) gfighter
