Forum » Strojna oprema » GF 6800 GT (Point Of View) --> jajca?
lopov ::
Ziv!
Kolegu sem sestavil racunalo in med drugim ima omenjeno grafiko.
Vse lepo in prav, dokler nisem pognal Doom3 in s presenecenjem vidim, da sproducira 60 fps, in to na medium.
Zal trenutno nimam nalozenega nobenega drugega bench proggyja, tko da sem vtaknil grafo v mojo kisto in pognal SpecView 8.0.1. Rezultati so cisto podobno moji FX 5900 128Mb, medtem ko po drugih forumih vidim, da bi morali biti bistveno boljsi.
RivaTuner pravi:
--> kar je OK
In se SpecView rezultati:
Oboje merjeno v moji kisti (AXP 2500@3200+, det. 66.81).
Preprican sem (sploh po izkusnji z Doom3) da tudi kaksen drug bencmark ne bi pokazal bistvenih odstopanj.
Ideja, kaj narediti? Grafa je nova, prakticno stara 1 teden. Dela, tko da ne vem, kaj narediti, ce bi uveljavljal(i) reklamacijo.
b.
RivaTuner pravi:
$ffffffffff ---------------------------------------------------
$ffffffffff Display adapter information
$0000000000 Description : NVIDIA GeForce 6800 GT
$0000000001 Vendor ID : 10de (NVIDIA)
$0000000002 Device ID : 0045
$0000000003 Location : bus 2, device 0, function 0
$0000000004 Bus type : AGP revision 3.0
$0000000005 AGP status : enabled
$0000000006 AGP rate : 4x 8x supported, 8x selected
$0000000007 AGP SBA : hardwired, enabled
$0000000008 AGP FW : supported, enabled
$0000000009 Base address 0 : e4000000 (memory range)
$000000000a Base address 1 : d0000000 (memory range)
$000000000b Base address 2 : e5000000 (memory range)
$000000000c Base address 3 : none
$000000000d Base address 4 : none
$000000000e Base address 5 : none
$ffffffffff OpenGL driver information
$0f00000000 Vendor : NVIDIA Corporation
$0f00000001 Renderer : GeForce 6800 GT/AGP/SSE/3DNOW!
$0f00000002 Version : 1.5.2
$ffffffffff NVIDIA specific display adapter information
$0100000000 Graphics core : NV40 revision A1 (16x1,6vp)
$0100000001 Hardwired ID : 0045 (ROM strapped to 0045)
$0100000002 Memory bus : 256-bit
$0100000003 Memory type : DDR (RAM configuration 07)
$0100000004 Memory amount : 262144KB
$0100000005 Core clock : 351.000MHz
$0100000006 Memory clock : 501.188MHz (1002.375MHz effecti...
$0100000007 Reference clock : 27.000MHz
$010000000b HW masked units : none
$ffffffffff NVIDIA VGA BIOS information
$1100000000 Title : GeForce 6800 GT BIOS
$1100000002 Version : 5.40.02.15.02
$1100000001 BMP version : 5.28
$1100000100 BIT version : 1.00
$1100010000 Perf. level 0 : 350MHz/500MHz/1.30V
$1100020000 VID bitmask : 00000011b
$1100020100 Voltage level 0 : 1.10V, VID 00000000b
$1100020101 Voltage level 1 : 1.30V, VID 00000010b
$1100020102 Voltage level 2 : 1.40V, VID 00000001b
$1100000003 SW masked units : none
--> kar je OK
FX 5900 GT my rig
3dsmax-03 Weighted Geometric Mean = 14.51 16.17
catia-01 Weighted Geometric Mean = 10.38 10.44
ensight-01 Weighted Geometric Mean = 7.770 11.21
light-07 Weighted Geometric Mean = 9.578 9.757
maya-01 Weighted Geometric Mean = 18.03 18.53
proe-03 Weighted Geometric Mean = 13.25 13.25
sw-01 Weighted Geometric Mean = 10.35 12.25
ugs-04 Weighted Geometric Mean = 4.718 4.288
b.
- premaknil iz Pomoč in nasveti: gkovac ()
Primoz78 ::
Meni pri D3 tudi ne da nevem kako veliko FPS-jev probi kake druge driverje dol pobrat na tejle strani probi. V kakih 3dmark programih se precej pozna, D3 pa nisem probal se kako se pozna...Imam pa podobno konfiguracijo kot ti. Prej sem mel R9800 PRO pa v D3 nisem opazil pretiranih sprememb. Poznalo pa bi se ce bi mel mocnejsi procesor...kak Athlon 64, ker je D3 precej odvisen od CPU-ja.
Lp Primoz C.
Lp Primoz C.
Caligula ::
Doom ima omejitev na 60. Kar nekaj iger ima tako omejitev. Pac povecuj sedaj nastavitve dokler na zacne padati framerate pod 60 in bos videl kaj je sposobna poganjati pri 60 FPSjih. Kar daj na high ampak ne na najvisjo. Pol pa se vklapljaj AA in AF.
lopov ::
Aquamark: 51431
3Dmark 03: 10544
3Dmark 05 na moji masini ne dela, javi napako in sicer "Direct3DCreate9 failed" -- lahko samo kliknem OK.
Imam nalozen DX 9.0c, tko da mi ni cisto jasno, kaj ga muci.
Ja hm, kksen komentar? Na Arc Orb je to 2 reultat s taksno konfiguracijo (se pravi isti proc, enako rama in nic navito). 3Dmarko pa je pa za 50% boljsi kot moja GF, tko da kle napredek je. Vseeno me matra tako majhn napreden (ali celo nazadovanje) pri SpecView ... s tako slabim rezultaom nimam izgovora da sam nadgradim grafiko
3Dmark 03: 10544
| » | GF6800GT --> NvidiaQuadro firmware (strani: 1 2 )Oddelek: Navijanje | 8074 (6895) | MarkoV |
| » | Problem z GF 6800 - POV/AsusOddelek: Zvok in slika | 1913 (1644) | bajsibajsi |
| » | Koliko uporabnikov Slo-tech-a..uporablja Profesionalne CAD/CAM programe tipa SolidworOddelek: Strojna oprema | 3391 (2931) | HyperGL |
| » | Računalnik za Catio (strani: 1 2 )Oddelek: Kaj kupiti | 8453 (6673) | barbarpapa1 |
| » | Hardware mod fx5950 ultraOddelek: Navijanje | 3138 (2689) | lopov |
