Forum » Pomoč in nasveti » Blueooth SE610 - računalnik problem
Tomson ::
Problem je torej sledeč:
Ko hočem posnet slike iz telefona na računalnik, gre vse lepo po vrsti, telefon in računalnik se najdeta, lepo predstavita, na telefonu se mi izpiše ime računalnika, ko pa dam pošlji mi telefon javi: Povezava bluetooth ni uspela. Poizkusim znova?
Če pa npr. pošljem nekaj iz računalnika na telefon pa normalno dela.
Kaj bi lahko bil problem?
car ::
To bi tudi jaz rad vedel, ker imam čist isti problem z T610. po vsej verjetnosti je software od telefona u k.... (beta). Vsaj tak sem slisal ko sem se mal pozanimal. Kok bi se pa dal to zrihtat pa ne vem, mogoce nov software nalozit na telefon?
Tomson ::
hmm... zanimivo!
Bo treba Sveo poklicat, pa da malo raztolmačijo zadevo ...
Tomson ::
Za prvo silo:
I found a note on the D-Link support web site that talked about problems
caused by the XP SP2 bluetooth driver replacing the D-Link driver. I
followed the instructions on removing the Microsoft Driver and replacing it
with the D-Link driver, and now everything is working great. (Note: I
ended up deleting the Sony Ericsson modem driver, and using the generic
modem driver supplied by D-Link).
Mike Schumann
Well the solution that worked for me was to install SP2, delete all the
manufacturer supplied bluetooth drivers and rely totally on Windows to
handle bluetooth.
Synchronising is much faster now and it ALWAYS works.
I had to delete the old dialup connection for the phone and create a new
one, including re-discovering the phone, which was painless enough as a
wizard did the job.
In general the laptop is much more well behaved with respect to bluetooth
and wifi after having installed SP2.
Jan Schledermann
Mike Schumann
handle bluetooth.
wizard did the job.
Jan Schledermann
| » | Geekbuying garancijaOddelek: Loža | 6695 (5047) | N0t0ri0us |
| » | Samsung Omnia problemčki in nasveti?!? (strani: 1 2 3 4 … 22 23 24 25 )Oddelek: Mobilne tehnologije | 129810 (38636) | Kunte |
| » | hp 6715b free dos – vrstni red inštaliranja driverjevOddelek: Pomoč in nasveti | 3957 (3638) | Constantine |
| » | Win XP SP2 in BlutoothOddelek: Pomoč in nasveti | 2452 (2297) | jast |
| » | Wireless 2.4GHz preko hribčka ali ovire!!Oddelek: Omrežja in internet | 2190 (1995) | pujsek_ |
