Forum » Pomoč in nasveti » odpiranje porta na ruterju
rlipan ::
Lep pozdrav!
Pri e-muli imam low id, zato bi moral odpreti nekatere porte na ruterju, kar pa mi dela tezave, nevem točno kateri port, in kako ga nastavim. nevem kaj je treba narediti ce imas dinamicni ip (na no-ip sem si ze naredil domeno). pa se eno vprasanje ce kdo ve katrei so porti za ABC torrent.
se opravicujem ker tezim, samo dosti mi je ze iskanja po angleskih in nemskih straneh ker pol stvari ne razumem.
Hvala LP
Rok
Hvala LP
Rok
OldSkul ::
Poišči v nastavitvah routerja port forwarding in vpiši sledeče porte:
The following list shows the ports used by eMule when using it's default settings. If you change anything in Preferences -> Connection you will have to take the changes into account when configuring your firewall or router.
1) Local Port: 4662
Remote Port: any
Protocol: TCP
Direction: incoming
Purpose:
Client Port / Connections from other clients, Client to Client Source Exchange
Note:
You can change this port in Preferences -> Connection -> Client Port
This port has to be forwarded in a router. Changing this port in Preferences you must also change the forwarding in the router
2) Local Port: any
Remote Port: 4662
Protocol: TCP
Direction: outgoing
Purpose:
Client Port / Connections to other clients, Client to Client Source Exchange
Note:
4662 is the default port, but other clients may have different settings. Change the remote port to any when configuring a firewall
3) Local Port: 4672
Remote Port: any
Protocol: UDP
Direction: incoming
Purpose:
Clients source asking / extended eMule protocol, Queue Rating, File Reask Ping
Note:
This port has to be forwarded in a router. Changing this port in Preferences you must also change the forwarding in the router.
If you are not able to forward this port check the disable box in Preferences -> Connection -> UDP Port
4) Local Port: any
Remote Port: 4672
Protocol: UDP
Direction: outgoing
Purpose:
Note:
4672 is the default port, but other clients may have different settings. Change the remote port to any when configuring a firewall
5) Local Port: any
Remote Port: 4661
Protocol: TCP
Direction: outgoing
Purpose:
Connection to server
Note:
4661 is the default port of a server. Many server use different ports. Configuring a firewall the remote port again changes to any.
6) Local Port: any
Remote Port: 4665
Protocol: UDP
Direction: outgoing
Purpose: Source asking on servers
Note:
Servers using the default port 4661 TCP (see #5) automatically set their port for source asking to 4665 UDP. If a server uses a different port in #5 the corresponding UDP port is set to [Connection Port + 4]. For firewalls the remote port here is any.
7) Local Port: 4711
Remote Port: any
Protocol: TCP
Direction: incoming
Purpose: Webserver
Note: This is the default port for the web interface. When using a router this port has to be forwarded or no connection to the webserver will be possible.
1) Local Port: 4662
Remote Port: any
Protocol: TCP
Direction: incoming
Purpose:
Note:
2) Local Port: any
Remote Port: 4662
Protocol: TCP
Direction: outgoing
Purpose:
Note:
3) Local Port: 4672
Remote Port: any
Protocol: UDP
Direction: incoming
Purpose:
Note:
4) Local Port: any
Remote Port: 4672
Protocol: UDP
Direction: outgoing
Purpose:
Note:
5) Local Port: any
Remote Port: 4661
Protocol: TCP
Direction: outgoing
Purpose:
Note:
6) Local Port: any
Remote Port: 4665
Protocol: UDP
Direction: outgoing
Note:
7) Local Port: 4711
Remote Port: any
Protocol: TCP
Direction: incoming
Purpose: Webserver
rlipan ::
Hvala!
Ali je potrebno otpreti vse te porte, in kako je stem ce imas dinamičen IP?
In kaj je "privat port" in kaj "public port".
(Moj ruter je : D-link DI-604) ali obstaja kaksen screan shot?
Se enkrat hvala.
Se enkrat hvala.
OldSkul ::
Jaz mam odprte vse te porte in mi dela brez problema.Dinamični IP sploh ni pomemben.Jaz ga imam tudi pa nimam nobenih problemov?
rlipan ::
Hvala za pomoc.
Za vse ki uporabljate D-Link Routerje je tole zelo uredu stran za konfiguriranje forvardiranja :
http://support.dlink.com/faq/view.asp?p...
OK se enkrat hvala za pomoč
Lep pozdrav
Lep pozdrav
| » | [P2P]eMule , eDonkey, Overnet, DC++ & co. (strani: 1 2 3 4 … 69 70 71 72 )Oddelek: Omrežja in internet | 441159 (24443) | Freakylion |
| » | Port Forwarding nikakor noče delovati?Oddelek: Pomoč in nasveti | 9012 (8152) | AC_DC |
| » | VsftpOddelek: Operacijski sistemi | 1779 (1686) | trnvpeti |
| » | Agnitum Outpost Firewall => TEŽAVAOddelek: Omrežja in internet | 2084 (1795) | simnov |
| » | VB in kk dobit Ip od račnalnikaOddelek: Programiranje | 1551 (1385) | alesrosina |
