Forum » Programiranje » Problem z MS ACCESOM 2000
alesko05 ::
Ok...naredil sem en macro..lost focus..in ko lost focus naredim mi javi tole..
The expression on Lost focus you entered as the event property setting produced the following error: A problem occured while PROGRAM IP was communicating with the OLE server or ActiveX Control.
*the expression may not result in the name of a macro, the name of a user defined function, or [Event procedure].
*there may have been an error evaluating the function, event, or macro
Pa kwa je to fora? File sem razdelil na dva dela in sicer uprabniški vmesnik in na bazo. baza je na serverju, uporabniški program je pa na različnih postajah. A obstaja kakšna druga varianta?
Fim ::
V makroju imaš napako, oz. makroja program ne najde, oz imaš napako v VB modulu.
Pa napiši malo več o makroju, če ne najdeš napake.
alesko05 ::
Ma jest ne najdem napake..javi mi tudi to napako, ko hočem vnesti neko cifro v drugo polje..
a problem occurred while PROGRAM IP was communicating with the OLE server or ActiveX Control.
Close the OLE server and restart it outside of PROGRAM IP. Then try the original operation again in PROGRAM IP.
Fim ::
Ali je polje iz baze ali je unbound?
Kako si pa naredil dostop do tabel oz podatkov, ali so tabele linkane?
Morda ni pravi dostop do podatkov (ODBC, link,....), malo več napiši.
- spremenil: Fim ()
| » | Kontakt obrazecOddelek: Izdelava spletišč | 2576 (2421) | betmen |
| » | Internet explorer se ugasa - sam od sebe... HELP !Oddelek: Pomoč in nasveti | 2090 (1978) | jarni2 |
| » | ipv6 for g33k`s (strani: 1 2 )Oddelek: Omrežja in internet | 15202 (11758) | Kami |
| » | Problem v accessuOddelek: Pomoč in nasveti | 1782 (1661) | Mercier |
| » | pomoc pri accessuOddelek: Programiranje | 1302 (1199) | icecube |
