Forum » Izdelava spletišč » Kontakt obrazec
Kontakt obrazec
betmen ::
Ne razumem zakaj ne dela. Na strani mam kontaktni obrazec. Zraven imam še php in dva js filea.
Prvo index.html, kontaktni ki je na strani:
Spodaj v indexu je še:
Potem je tu še contact_me.php
Še:
jqBootstrapValidation.js
contact_me.js
<section id="contact">
<div class="container">
<div class="row">
<div class="col-lg-12 text-center">
<h2 class="section-heading">Contact Us</h2>
<h3 class="section-subheading text-muted">Lorem ipsum dolor sit amet consectetur.</h3>
</div>
</div>
<div class="row">
<div class="col-lg-12">
<form name="sentMessage" id="contactForm" novalidate>
<div class="row">
<div class="col-md-6">
<div class="form-group">
<input type="text" class="form-control" placeholder="Your Name *" id="name" required data-validation-required-message="Please enter your name.">
<p class="help-block text-danger"></p>
</div>
<input type="email" class="form-control" placeholder="Your Email *" id="email" required data-validation-required-message="Please enter your email address.">
</div>
<input type="tel" class="form-control" placeholder="Your Phone *" id="phone" required data-validation-required-message="Please enter your phone number.">
</div>
</div>
<textarea class="form-control" placeholder="Your Message *" id="message" required data-validation-required-message="Please enter a message."></textarea>
</div>
</div>
<div class="clearfix"></div>
<div id="success"></div>
<button type="submit" class="btn btn-xl">Send Message</button>
</div>
</div>
</form>
</div>
</div>
</div>
</section>Spodaj v indexu je še:
<!-- Contact Form JavaScript -->
<script src="js/jqBootstrapValidation.js"></script>
<script src="js/contact_me.js"></script>Potem je tu še contact_me.php
<?php
// Check for empty fields
if(empty($_POST['name']) ||
empty($_POST['email']) ||
empty($_POST['phone']) ||
empty($_POST['message']) ||
!filter_var($_POST['email'],FILTER_VALIDATE_EMAIL))
echo "No arguments Provided!";
return false;
$name = $_POST['name'];
$email_address = $_POST['email'];
$phone = $_POST['phone'];
$message = $_POST['message'];
// Create the email and send the message
$to = 'info@mojmail.si'; // Add your email address inbetween the '' replacing yourname@yourdomain.com - This is where the form will send a message to.
$email_subject = "Website Contact Form: $name";
$email_body = "You have received a new message from your website contact form.\n\n"."Here are the details:\n\nName: $name\n\nEmail: $email_address\n\nPhone: $phone\n\nMessage:\n$message";
$headers = "From: noreply@mojmail.si\n"; // This is the email address the generated message will be from. We recommend using something like noreply@yourdomain.com.
$headers .= "Reply-To: $email_address";
mail($to,$email_subject,$email_body,$headers);
return true;
?>Še:
/* jqBootstrapValidation
* A plugin for automating validation on Twitter Bootstrap formatted forms.
* v1.3.6
* License: MIT <http://opensource.org/licenses/mit-license.php> - see LICENSE file
* http://ReactiveRaven.github.com/jqBootstrapValidation/
(function( $ ){
var createdElements = [];
var defaults = {
options: {
prependExistingHelpBlock: false,
sniffHtml: true, // sniff for 'required', 'maxlength', etc
preventSubmit: true, // stop the form submit event from firing if validation fails
submitError: false, // function called if there is an error when trying to submit
submitSuccess: false, // function called just before a successful submit event is sent to the server
semanticallyStrict: false, // set to true to tidy up generated HTML output
autoAdd: {
helpBlocks: true
filter: function () {
// return $(this).is(":visible"); // only validate elements you can see
return true; // validate everything
methods: {
init : function( options ) {
var settings = $.extend(true, {}, defaults);
settings.options = $.extend(true, settings.options, options);
var $siblingElements = this;
var uniqueForms = $.unique(
$siblingElements.map( function () {
return $(this).parents("form")[0];
}).toArray()
$(uniqueForms).bind("submit", function (e) {
var $form = $(this);
var warningsFound = 0;
var $inputs = $form.find("input,textarea,select").not("[type=submit],[type=image]").filter(settings.options.filter);
$inputs.trigger("submit.validation").trigger("validationLostFocus.validation");
$inputs.each(function (i, el) {
var $this = $(el),
$controlGroup = $this.parents(".form-group").first();
if (
$controlGroup.hasClass("warning")
$controlGroup.removeClass("warning").addClass("error");
warningsFound++;
$inputs.trigger("validationLostFocus.validation");
if (warningsFound) {
if (settings.options.preventSubmit) {
e.preventDefault();
$form.addClass("error");
if ($.isFunction(settings.options.submitError)) {
settings.options.submitError($form, e, $inputs.jqBootstrapValidation("collectErrors", true));
} else {
$form.removeClass("error");
if ($.isFunction(settings.options.submitSuccess)) {
settings.options.submitSuccess($form, e);
return this.each(function(){
// Get references to everything we're interested in
var $this = $(this),
$controlGroup = $this.parents(".form-group").first(),
$helpBlock = $controlGroup.find(".help-block").first(),
$form = $this.parents("form").first(),
validatorNames = [];
// create message container if not exists
if (!$helpBlock.length && settings.options.autoAdd && settings.options.autoAdd.helpBlocks) {
$helpBlock = $('<div class="help-block" />');
$controlGroup.find('.controls').append($helpBlock);
createdElements.push($helpBlock[0]);
// SNIFF HTML FOR VALIDATORS
// *snort sniff snuffle*
if (settings.options.sniffHtml) {
var message = "";
// PATTERN
if ($this.attr("pattern") !== undefined) {
message = "Not in the expected format<!-- data-validation-pattern-message to override -->";
if ($this.data("validationPatternMessage")) {
message = $this.data("validationPatternMessage");
$this.data("validationPatternMessage", message);
$this.data("validationPatternRegex", $this.attr("pattern"));
// MAX
if ($this.attr("max") !== undefined || $this.attr("aria-valuemax") !== undefined) {
var max = ($this.attr("max") !== undefined ? $this.attr("max") : $this.attr("aria-valuemax"));
message = "Too high: Maximum of '" + max + "'<!-- data-validation-max-message to override -->";
if ($this.data("validationMaxMessage")) {
message = $this.data("validationMaxMessage");
$this.data("validationMaxMessage", message);
$this.data("validationMaxMax", max);
// MIN
if ($this.attr("min") !== undefined || $this.attr("aria-valuemin") !== undefined) {
var min = ($this.attr("min") !== undefined ? $this.attr("min") : $this.attr("aria-valuemin"));
message = "Too low: Minimum of '" + min + "'<!-- data-validation-min-message to override -->";
if ($this.data("validationMinMessage")) {
message = $this.data("validationMinMessage");
$this.data("validationMinMessage", message);
$this.data("validationMinMin", min);
// MAXLENGTH
if ($this.attr("maxlength") !== undefined) {
message = "Too long: Maximum of '" + $this.attr("maxlength") + "' characters<!-- data-validation-maxlength-message to override -->";
if ($this.data("validationMaxlengthMessage")) {
message = $this.data("validationMaxlengthMessage");
$this.data("validationMaxlengthMessage", message);
$this.data("validationMaxlengthMaxlength", $this.attr("maxlength"));
// MINLENGTH
if ($this.attr("minlength") !== undefined) {
message = "Too short: Minimum of '" + $this.attr("minlength") + "' characters<!-- data-validation-minlength-message to override -->";
if ($this.data("validationMinlengthMessage")) {
message = $this.data("validationMinlengthMessage");
$this.data("validationMinlengthMessage", message);
$this.data("validationMinlengthMinlength", $this.attr("minlength"));
// REQUIRED
if ($this.attr("required") !== undefined || $this.attr("aria-required") !== undefined) {
message = settings.builtInValidators.required.message;
if ($this.data("validationRequiredMessage")) {
message = $this.data("validationRequiredMessage");
$this.data("validationRequiredMessage", message);
// NUMBER
if ($this.attr("type") !== undefined && $this.attr("type").toLowerCase() === "number") {
message = settings.builtInValidators.number.message;
if ($this.data("validationNumberMessage")) {
message = $this.data("validationNumberMessage");
$this.data("validationNumberMessage", message);
// EMAIL
if ($this.attr("type") !== undefined && $this.attr("type").toLowerCase() === "email") {
message = "Not a valid email address<!-- data-validator-validemail-message to override -->";
if ($this.data("validationValidemailMessage")) {
message = $this.data("validationValidemailMessage");
} else if ($this.data("validationEmailMessage")) {
message = $this.data("validationEmailMessage");
$this.data("validationValidemailMessage", message);
// MINCHECKED
if ($this.attr("minchecked") !== undefined) {
message = "Not enough options checked; Minimum of '" + $this.attr("minchecked") + "' required<!-- data-validation-minchecked-message to override -->";
if ($this.data("validationMincheckedMessage")) {
message = $this.data("validationMincheckedMessage");
$this.data("validationMincheckedMessage", message);
$this.data("validationMincheckedMinchecked", $this.attr("minchecked"));
// MAXCHECKED
if ($this.attr("maxchecked") !== undefined) {
message = "Too many options checked; Maximum of '" + $this.attr("maxchecked") + "' required<!-- data-validation-maxchecked-message to override -->";
if ($this.data("validationMaxcheckedMessage")) {
message = $this.data("validationMaxcheckedMessage");
$this.data("validationMaxcheckedMessage", message);
$this.data("validationMaxcheckedMaxchecked", $this.attr("maxchecked"));
// COLLECT VALIDATOR NAMES
// Get named validators
if ($this.data("validation") !== undefined) {
validatorNames = $this.data("validation").split(",");
// Get extra ones defined on the element's data attributes
$.each($this.data(), function (i, el) {
var parts = i.replace(/([A-Z])/g, ",$1").split(",");
if (parts[0] === "validation" && parts[1]) {
validatorNames.push(parts[1]);
// NORMALISE VALIDATOR NAMES
var validatorNamesToInspect = validatorNames;
var newValidatorNamesToInspect = [];
do // repeatedly expand 'shortcut' validators into their real validators
// Uppercase only the first letter of each name
$.each(validatorNames, function (i, el) {
validatorNames[i] = formatValidatorName(el);
// Remove duplicate validator names
validatorNames = $.unique(validatorNames);
// Pull out the new validator names from each shortcut
$.each(validatorNamesToInspect, function(i, el) {
if ($this.data("validation" + el + "Shortcut") !== undefined) {
// Are these custom validators?
// Pull them out!
$.each($this.data("validation" + el + "Shortcut").split(","), function(i2, el2) {
newValidatorNamesToInspect.push(el2);
} else if (settings.builtInValidators[el.toLowerCase()]) {
// Is this a recognised built-in?
// Pull it out!
var validator = settings.builtInValidators[el.toLowerCase()];
if (validator.type.toLowerCase() === "shortcut") {
$.each(validator.shortcut.split(","), function (i, el) {
el = formatValidatorName(el);
newValidatorNamesToInspect.push(el);
validatorNames.push(el);
validatorNamesToInspect = newValidatorNamesToInspect;
} while (validatorNamesToInspect.length > 0)
// SET UP VALIDATOR ARRAYS
var validators = {};
// Set up the 'override' message
var message = $this.data("validation" + el + "Message");
var hasOverrideMessage = (message !== undefined);
var foundValidator = false;
message =
message
? message
: "'" + el + "' validation failed <!-- Add attribute 'data-validation-" + el.toLowerCase() + "-message' to input to change this message -->"
$.each(
settings.validatorTypes,
function (validatorType, validatorTemplate) {
if (validators[validatorType] === undefined) {
validators[validatorType] = [];
if (!foundValidator && $this.data("validation" + el + formatValidatorName(validatorTemplate.name)) !== undefined) {
validators[validatorType].push(
$.extend(
true,
message: message
validatorTemplate.init($this, el)
foundValidator = true;
if (!foundValidator && settings.builtInValidators[el.toLowerCase()]) {
var validator = $.extend(true, {}, settings.builtInValidators[el.toLowerCase()]);
if (hasOverrideMessage) {
validator.message = message;
var validatorType = validator.type.toLowerCase();
if (validatorType === "shortcut") {
} else {
$.each(
function (validatorTemplateType, validatorTemplate) {
if (validators[validatorTemplateType] === undefined) {
validators[validatorTemplateType] = [];
if (!foundValidator && validatorType === validatorTemplateType.toLowerCase()) {
$this.data("validation" + el + formatValidatorName(validatorTemplate.name), validator[validatorTemplate.name.toLowerCase()]);
$.extend(
validator,
if (! foundValidator) {
$.error("Cannot find validation info for '" + el + "'");
// STORE FALLBACK VALUES
$helpBlock.data(
"original-contents",
$helpBlock.data("original-contents")
? $helpBlock.data("original-contents")
: $helpBlock.html()
$helpBlock.data(
"original-role",
$helpBlock.data("original-role")
? $helpBlock.data("original-role")
: $helpBlock.attr("role")
$controlGroup.data(
"original-classes",
$controlGroup.data("original-clases")
? $controlGroup.data("original-classes")
: $controlGroup.attr("class")
$this.data(
"original-aria-invalid",
$this.data("original-aria-invalid")
? $this.data("original-aria-invalid")
: $this.attr("aria-invalid")
// VALIDATION
$this.bind(
"validation.validation",
function (event, params) {
var value = getValue($this);
// Get a list of the errors to apply
var errorsFound = [];
$.each(validators, function (validatorType, validatorTypeArray) {
if (value || value.length || (params && params.includeEmpty) || (!!settings.validatorTypes[validatorType].blockSubmit && params && !!params.submitting)) {
$.each(validatorTypeArray, function (i, validator) {
if (settings.validatorTypes[validatorType].validate($this, value, validator)) {
errorsFound.push(validator.message);
return errorsFound;
$this.bind(
"getValidators.validation",
function () {
return validators;
// WATCH FOR CHANGES
$this.bind(
"submit.validation",
function () {
return $this.triggerHandler("change.validation", {submitting: true});
$this.bind(
"keyup",
"focus",
"blur",
"click",
"keydown",
"keypress",
"change"
].join(".validation ") + ".validation",
function (e, params) {
$controlGroup.find("input,textarea,select").each(function (i, el) {
var oldCount = errorsFound.length;
$.each($(el).triggerHandler("validation.validation", params), function (j, message) {
errorsFound.push(message);
if (errorsFound.length > oldCount) {
$(el).attr("aria-invalid", "true");
} else {
var original = $this.data("original-aria-invalid");
$(el).attr("aria-invalid", (original !== undefined ? original : false));
$form.find("input,select,textarea").not($this).not("[name=\"" + $this.attr("name") + "\"]").trigger("validationLostFocus.validation");
errorsFound = $.unique(errorsFound.sort());
// Were there any errors?
if (errorsFound.length) {
// Better flag it up as a warning.
$controlGroup.removeClass("success error").addClass("warning");
// How many errors did we find?
if (settings.options.semanticallyStrict && errorsFound.length === 1) {
// Only one? Being strict? Just output it.
$helpBlock.html(errorsFound[0] +
( settings.options.prependExistingHelpBlock ? $helpBlock.data("original-contents") : "" ));
} else {
// Multiple? Being sloppy? Glue them together into an UL.
$helpBlock.html("<ul role=\"alert\"><li>" + errorsFound.join("</li><li>") + "</li></ul>" +
} else {
$controlGroup.removeClass("warning error success");
if (value.length > 0) {
$controlGroup.addClass("success");
$helpBlock.html($helpBlock.data("original-contents"));
if (e.type === "blur") {
$controlGroup.removeClass("success");
$this.bind("validationLostFocus.validation", function () {
destroy : function( ) {
return this.each(
function() {
var
$this = $(this),
$helpBlock = $controlGroup.find(".help-block").first();
// remove our events
$this.unbind('.validation'); // events are namespaced.
// reset help text
// reset classes
$controlGroup.attr("class", $controlGroup.data("original-classes"));
// reset aria
$this.attr("aria-invalid", $this.data("original-aria-invalid"));
// reset role
$helpBlock.attr("role", $this.data("original-role"));
// remove all elements we created
if (createdElements.indexOf($helpBlock[0]) > -1) {
$helpBlock.remove();
collectErrors : function(includeEmpty) {
var errorMessages = {};
this.each(function (i, el) {
var $el = $(el);
var name = $el.attr("name");
var errors = $el.triggerHandler("validation.validation", {includeEmpty: true});
errorMessages[name] = $.extend(true, errors, errorMessages[name]);
$.each(errorMessages, function (i, el) {
if (el.length === 0) {
delete errorMessages[i];
return errorMessages;
hasErrors: function() {
var errorMessages = [];
errorMessages = errorMessages.concat(
$(el).triggerHandler("getValidators.validation") ? $(el).triggerHandler("validation.validation", {submitting: true}) : []
return (errorMessages.length > 0);
override : function (newDefaults) {
defaults = $.extend(true, defaults, newDefaults);
validatorTypes: {
callback: {
init: function ($this, name) {
return {
validatorName: name,
callback: $this.data("validation" + name + "Callback"),
lastValue: $this.val(),
lastValid: true,
lastFinished: true
validate: function ($this, value, validator) {
if (validator.lastValue === value && validator.lastFinished) {
return !validator.lastValid;
if (validator.lastFinished === true)
validator.lastValue = value;
validator.lastValid = true;
validator.lastFinished = false;
var rrjqbvValidator = validator;
var rrjqbvThis = $this;
executeFunctionByName(
validator.callback,
window,
$this,
value,
function (data) {
if (rrjqbvValidator.lastValue === data.value) {
rrjqbvValidator.lastValid = data.valid;
if (data.message) {
rrjqbvValidator.message = data.message;
rrjqbvValidator.lastFinished = true;
rrjqbvThis.data("validation" + rrjqbvValidator.validatorName + "Message", rrjqbvValidator.message);
// Timeout is set to avoid problems with the events being considered 'already fired'
setTimeout(function () {
rrjqbvThis.trigger("change.validation");
}, 1); // doesn't need a long timeout, just long enough for the event bubble to burst
return false;
ajax: {
return {
url: $this.data("validation" + name + "Ajax"),
lastValid: true,
lastFinished: true
if (""+validator.lastValue === ""+value && validator.lastFinished === true) {
return validator.lastValid === false;
$.ajax({
url: validator.url,
data: "value=" + value + "&field=" + $this.attr("name"),
dataType: "json",
success: function (data) {
if (""+validator.lastValue === ""+data.value) {
validator.lastValid = !!(data.valid);
if (data.message) {
validator.message = data.message;
validator.lastFinished = true;
$this.data("validation" + validator.validatorName + "Message", validator.message);
$this.trigger("change.validation");
failure: function () {
validator.message = "ajax call failed";
return false;
regex: {
return {regex: regexFromString($this.data("validation" + name + "Regex"))};
return (!validator.regex.test(value) && ! validator.negative)
|| (validator.regex.test(value) && validator.negative);
required: {
return {};
return !!(value.length === 0 && ! validator.negative)
|| !!(value.length > 0 && validator.negative);
blockSubmit: true
match: {
var element = $this.parents("form").first().find("[name=\"" + $this.data("validation" + name + "Match") + "\"]").first();
element.bind("validation.validation", function () {
$this.trigger("change.validation", {submitting: true});
return {"element": element};
return (value !== validator.element.val() && ! validator.negative)
|| (value === validator.element.val() && validator.negative);
blockSubmit: true
max: {
return {max: $this.data("validation" + name + "Max")};
return (parseFloat(value, 10) > parseFloat(validator.max, 10) && ! validator.negative)
|| (parseFloat(value, 10) <= parseFloat(validator.max, 10) && validator.negative);
min: {
return {min: $this.data("validation" + name + "Min")};
return (parseFloat(value) < parseFloat(validator.min) && ! validator.negative)
|| (parseFloat(value) >= parseFloat(validator.min) && validator.negative);
maxlength: {
return {maxlength: $this.data("validation" + name + "Maxlength")};
return ((value.length > validator.maxlength) && ! validator.negative)
|| ((value.length <= validator.maxlength) && validator.negative);
minlength: {
return {minlength: $this.data("validation" + name + "Minlength")};
return ((value.length < validator.minlength) && ! validator.negative)
|| ((value.length >= validator.minlength) && validator.negative);
maxchecked: {
var elements = $this.parents("form").first().find("[name=\"" + $this.attr("name") + "\"]");
elements.bind("click.validation", function () {
$this.trigger("change.validation", {includeEmpty: true});
return {maxchecked: $this.data("validation" + name + "Maxchecked"), elements: elements};
return (validator.elements.filter(":checked").length > validator.maxchecked && ! validator.negative)
|| (validator.elements.filter(":checked").length <= validator.maxchecked && validator.negative);
blockSubmit: true
minchecked: {
return {minchecked: $this.data("validation" + name + "Minchecked"), elements: elements};
return (validator.elements.filter(":checked").length < validator.minchecked && ! validator.negative)
|| (validator.elements.filter(":checked").length >= validator.minchecked && validator.negative);
blockSubmit: true
builtInValidators: {
email: {
type: "shortcut",
shortcut: "validemail"
validemail: {
type: "regex",
regex: "[A-Za-z0-9._%+-]+@[A-Za-z0-9.-]+\\\.[A-Za-z]{2,4}",
message: "Not a valid email address<!-- data-validator-validemail-message to override -->"
passwordagain: {
type: "match",
match: "password",
message: "Does not match the given password<!-- data-validator-paswordagain-message to override -->"
positive: {
type: "shortcut",
shortcut: "number,positivenumber"
negative: {
type: "shortcut",
shortcut: "number,negativenumber"
number: {
type: "regex",
regex: "([+-]?\\\d+(\\\.\\\d*)?([eE][+-]?[0-9]+)?)?",
message: "Must be a number<!-- data-validator-number-message to override -->"
integer: {
type: "regex",
regex: "[+-]?\\\d+",
message: "No decimal places allowed<!-- data-validator-integer-message to override -->"
positivenumber: {
type: "min",
min: 0,
message: "Must be a positive number<!-- data-validator-positivenumber-message to override -->"
negativenumber: {
type: "max",
max: 0,
message: "Must be a negative number<!-- data-validator-negativenumber-message to override -->"
required: {
type: "required",
message: "This is required<!-- data-validator-required-message to override -->"
checkone: {
type: "minchecked",
minchecked: 1,
message: "Check at least one option<!-- data-validation-checkone-message to override -->"
var formatValidatorName = function (name) {
return name
.toLowerCase()
.replace(
/(^|\s)([a-z])/g ,
function(m,p1,p2) {
return p1+p2.toUpperCase();
var getValue = function ($this) {
// Extract the value we're talking about
var value = $this.val();
var type = $this.attr("type");
if (type === "checkbox") {
value = ($this.is(":checked") ? value : "");
if (type === "radio") {
value = ($('input[name="' + $this.attr("name") + '"]:checked').length > 0 ? value : "");
return value;
function regexFromString(inputstring) {
return new RegExp("^" + inputstring + "$");
* Thanks to Jason Bunting via StackOverflow.com
* http://stackoverflow.com/questions/359788/how-to-execute-a-javascript-function-when-i-have-its-name-as-a-string#answer-359910
* Short link: http://tinyurl.com/executeFunctionByName
function executeFunctionByName(functionName, context /*, args*/) {
var args = Array.prototype.slice.call(arguments).splice(2);
var namespaces = functionName.split(".");
var func = namespaces.pop();
for(var i = 0; i < namespaces.length; i++) {
context = context[namespaces[i]];
return context[func].apply(this, args);
$.fn.jqBootstrapValidation = function( method ) {
if ( defaults.methods[method] ) {
return defaults.methods[method].apply( this, Array.prototype.slice.call( arguments, 1 ));
} else if ( typeof method === 'object' || ! method ) {
return defaults.methods.init.apply( this, arguments );
} else {
$.error( 'Method ' + method + ' does not exist on jQuery.jqBootstrapValidation' );
return null;
$.jqBootstrapValidation = function (options) {
$(":input").not("[type=image],[type=submit]").jqBootstrapValidation.apply(this,arguments);
})( jQuery );
contact_me.js
$(function() {
$("input,textarea").jqBootstrapValidation({
submitError: function($form, event, errors) {
// additional error messages or events
submitSuccess: function($form, event) {
event.preventDefault(); // prevent default submit behaviour
// get values from FORM
var name = $("input#name").val();
var email = $("input#email").val();
var phone = $("input#phone").val();
var message = $("textarea#message").val();
var firstName = name; // For Success/Failure Message
// Check for white space in name for Success/Fail message
if (firstName.indexOf(' ') >= 0) {
firstName = name.split(' ').slice(0, -1).join(' ');
$.ajax({
url: "././mail/contact_me.php",
type: "POST",
data: {
phone: phone,
email: email,
message: message
cache: false,
success: function() {
// Success message
$('#success').html("<div class='alert alert-success'>");
$('#success > .alert-success').html("<button type='button' class='close' data-dismiss='alert' aria-hidden='true'>×")
.append("</button>");
.append("<strong>Your message has been sent. </strong>");
.append('</div>');
//clear all fields
$('#contactForm').trigger("reset");
error: function() {
// Fail message
$('#success').html("<div class='alert alert-danger'>");
$('#success > .alert-danger').html("<button type='button' class='close' data-dismiss='alert' aria-hidden='true'>×")
$('#success > .alert-danger').append("<strong>Sorry " + firstName + ", it seems that my mail server is not responding. Please try again later!");
$('#success > .alert-danger').append('</div>');
//clear all fields
filter: function() {
$("a[data-toggle=\"tab\"]").click(function(e) {
e.preventDefault();
$(this).tab("show");
/*When clicking on Full hide fail/success boxes */
$('#name').focus(function() {
$('#success').html('');
alexa-lol ::
testiraj vsak del posebej...
za začetek preveri če ti php skripta pošilja maile s tem da zakomentiraš nekatere vrstice, potem preveri če se vsi podatki sploh pošljejo do strežnika ($_POST), preveri da ni v JS kake napake in kakšna spremenljivka ni definirana pravilno oz. je undefined.
PS pa poglej pod success kaj ti vrne strežnik - true ali false, ker tudi če vrne false (napaka pri $_POST spremenljivkah) je zahtevek še vedno successful.
- spremenil: alexa-lol ()
betmen ::
a je to previlen url?
php je res v mapi "mail" ampak te dve piki in črte ne vem a res pomenijo index.html/mail/contact_me.php
| » | Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )Oddelek: Programiranje | 390195 (130198) | Macketina |
| » | JqueryOddelek: Izdelava spletišč | 2203 (1927) | mk818764 |
| » | jquery in div-i (strani: 1 2 )Oddelek: Izdelava spletišč | 14457 (13195) | lisjak |
| » | [JavaScript] Validacija e-mail naslovaOddelek: Izdelava spletišč | 1264 (1116) | KaiSmith |
| » | jQuery loadOddelek: Izdelava spletišč | 2031 (1948) | MrBrdo |
