Forum » Pomoč in nasveti » ctr+alt+del pomoč.
ctr+alt+del pomoč.
BaToCarx ::
ko pritisnem ctr+alt+del mi napiše da je bil task maneger disejblan od admina, ki sem jaz, pa nisem nič disejblu. pomoč prosim.
p.s. ni virusa,spama,...
Lith ::
Windows 98? , ME ?, 2000 ?, XP ?, 2003 server ?
točno kako napiše napako ?
===::::: support.microsoft.com :::::===
¤ black holes rule; I like the speed, speed kills ¤
BaToCarx ::
Windows XP professional
Napaka se glasi tako:"Task Maneger has ben disabled by your administrator."
Mercier ::
Poglej local computer policy - user configuration>admnistrative templates>system>ctrl+alt+del options>remove task manager in stvar disableaj
Lith ::
zanimivo, ampak na M$ support ne najde nobene info o tem sporočilu,
(mogoče bo Sašin odgovor najboljša rešitev)
BaToCarx ::
Jst ne najdem. :(
šaša opiši mi navodila za windows XP, prosim ker tistih tvojih ne razumem.
Mercier ::
1. Click Start, click Run, type mmc, and then click OK.
2. On the File menu, click Add/Remove Snap-in, and then click Add.
3. Under Add Standalone Snap-in, click Group Policy, and then click Add.
4. Under Group Policy Object, make sure that Local Computer is displayed, click Finish.
5. Click Close, and then click OK.
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3725 (3115) | fr!Xy |
| » | Zagon programa pred logiranjem v WindowsOddelek: Operacijski sistemi | 1361 (1196) | snus |
| » | windows media player 10 mi ne dela !?!?Oddelek: Pomoč in nasveti | 1945 (1893) | bunnyrabit |
| » | Nad32 problem?Oddelek: Programska oprema | 1403 (1205) | Spajky |
| » | WIN 2000 BOOT ?Oddelek: Programska oprema | 1857 (1722) | rookie |
