ctr+alt+del pomoč.
ctr+alt+del pomoč.
BaToCarx ::
ko pritisnem ctr+alt+del mi napiše da je bil task maneger disejblan od admina, ki sem jaz, pa nisem nič disejblu. pomoč prosim.
p.s. ni virusa,spama,...
Lith ::
Windows 98? , ME ?, 2000 ?, XP ?, 2003 server ?
točno kako napiše napako ?
===::::: support.microsoft.com :::::===
¤ black holes rule; I like the speed, speed kills ¤
BaToCarx ::
Windows XP professional
Napaka se glasi tako:"Task Maneger has ben disabled by your administrator."
Mercier ::
Poglej local computer policy - user configuration>admnistrative templates>system>ctrl+alt+del options>remove task manager in stvar disableaj
Lith ::
zanimivo, ampak na M$ support ne najde nobene info o tem sporočilu,
(mogoče bo Sašin odgovor najboljša rešitev)
BaToCarx ::
Jst ne najdem. :(
šaša opiši mi navodila za windows XP, prosim ker tistih tvojih ne razumem.
Mercier ::
1. Click Start, click Run, type mmc, and then click OK.
2. On the File menu, click Add/Remove Snap-in, and then click Add.
3. Under Add Standalone Snap-in, click Group Policy, and then click Add.
4. Under Group Policy Object, make sure that Local Computer is displayed, click Finish.
5. Click Close, and then click OK.
BaToCarx ::
Hvala hvala ti si največji car/carka na forumu!!!
Mercier ::
Največji car na forumu. :)
BTW, kako pa je bilo nastavljeno?
Windows 7 Installer (64-bit) - težave
Oddelek: Programska oprema
153725 (3115) fr!Xy
Zagon programa pred logiranjem v Windows
Oddelek: Operacijski sistemi
71359 (1194) snus
windows media player 10 mi ne dela !?!?
81944 (1892) bunnyrabit
Nad32 problem?
91402 (1204) Spajky
WIN 2000 BOOT ?
131857 (1722) rookie
