Visual basic Progress bar
strel ::
Lep pozdrav ! Spet rabim malo pomoči ...
Rad bi spravu PROGRESS Bar v eno od polj STATUS BAR-a
, kadar se kaj dalj časa dogaja( berem neke EXCELOVE tabele, ali prenos podatkov med mdb .....
A se to spolh da PROSIM ....:D:D
strel ::
A ja še to, fajn bi blo če bi progress bar zgledal nekako tako kot v internet explorerju, sploh lahko čist tak.
Lunik ::
Zveš v četrtek... ko pridem domov
Monster ::
maš eno finto dej vse statuse v picturebox, pol pa delaj normalno!!
PS. ne pozab na doevent komando:\
strel ::
Če koga to zanima sem našu točno to kar rabim sam mi ni jasn tole z hwnd pa še kej.Zna gdo tole mal bol razložit.
This tip was written by Chris Eastwood (www.codeguru.com/vb/) To use this tip add a form with a progress bar, a status bar and a command button on. Copy the following code into the form's General Declarations procedure:
'Declarations
' API Declarations
Private Declare Function SetParent Lib "user32" (ByVal hWndChild As _
Long, ByVal hWndNewParent As Long) As Long
Private Declare Function SendMessageAny Lib "user32" Alias "SendMessageA" _
(ByVal hwnd As Long, ByVal msg As Long, ByVal wParam As Long, lParam _
As Any) As Long
' API Types
' RECT is used to get the size of the panel we're inserting into
Private Type RECT
Left As Long
Top As Long
Right As Long
Bottom As Long
End Type
' API Messages
Private Const WM_USER As Long = &H400
Private Const SB_GETRECT As Long = (WM_USER + 10)
Private Sub ShowProgressInStatusBar(ByVal bShowProgressBar As Boolean)
Dim tRC As RECT
If bShowProgressBar Then
' Get the size of the Panel (2) Rectangle from the status bar
' remember that Indexes in the API are always 0 based (well,
' nearly always) - therefore Panel(2) = Panel(1) to the api
SendMessageAny StatusBar1.hwnd, SB_GETRECT, 1, tRC
' and convert it to twips....
With tRC
.Top = (.Top * Screen.TwipsPerPixelY)
.Left = (.Left * Screen.TwipsPerPixelX)
.Bottom = (.Bottom * Screen.TwipsPerPixelY) - .Top
.Right = (.Right * Screen.TwipsPerPixelX) - .Left
End With
' Now Reparent the ProgressBar to the statusbar
With ProgressBar1
SetParent .hwnd, StatusBar1.hwnd
.Move tRC.Left, tRC.Top, tRC.Right, tRC.Bottom
.Visible = True
.Value = 0
End With
Else
' Reparent the progress bar back to the form and hide it
SetParent ProgressBar1.hwnd, Me.hwnd
ProgressBar1.Visible = False
End If
End Sub
Private Sub Command1_Click()
'Call the function
Call ShowProgressInStatusBar(True)
'Do something in the progress bar
For i = 1 To ProgressBar1.Max
ProgressBar1.Value = i
Next i
End Sub
8-O8-O8-O8-O
Lunik ::
jah tole so pa API funkcije. o tem (ža) nimam pojma :)
C# Pomoč
Oddelek: Programiranje
131830 (1655) jizzer
VB6 - ne zaključi proces programa - pomoč !!!
131726 (1567) Mavrik
VB6 kako uporabiti
81331 (1193) Area_51
Vb6
101818 (1681) StratOS
Odpiranje dat.exe v VB
123852 (3645) webblod
