2x256 ali 1x512 rama
jero_no1 ::
sm mau gledau po forumu, pa sm vidu zelo različna mnenja glede tega. mam amdja pa 2x256MB rama v dvokanalnem načinu. a bi se mi splačal zamenat za 1x512MB? a sploh kaj pridobim na hitrosti?
Yohan del Sud ::
na hitrosti ne, na prostih režah pa ja... :\
boštjan ::
jero če ti zdaj deluje vse dobro,raje ne meči denarja proč in kupi dodatnih 512MB KO JIH BOŠ RABIL.
mloncar ::
po novem letu bom kupu novo plato (abit nf7) in rame (tiste ko jih ma jae v akciji - če še bojo na zalogi, drugače pa twinmos-ove)... ...pa me zanima, kaj bo hitrejše ali 2*256 v dual načinu al 1*512?
se da npr. v dual načinu bol navit rame, ko pa če maš sam v eni reži ali velja obratno?
boštjan ::
1.nf7 nima ultra chipseta,tako da nima dual ddr podpore
2.pri amd systemih ti dual ddr ne pospeši sistema kot pri intel 865/875 sistemih
gamer ::
od kdaj pa nf7 nima ultra čipseta? pa da ne podpira dual chanela???
iz abitove strani... predvsem prvi odstavek je zanimiv, kjer lepo piše da podpira dual chanel...
The NF7 series models, based on nForce2 chipset, supports the latest AMD Athlon XP processors with 200/266/333/400 FSB, and features new dual 400MHz DDR memory controllers that deliver up to a 50% increase in bandwidth. Three DDR DIMM slots support up to 3GB of DDR memory, and optimized 128-bit architecture reduces memory latency. The advanced memory architecture means that the latest 3D games and multimedia applications are able to run smoother and faster than ever before, giving you unparalleled system performance. With the nForce2 MCP2-T, the APU (Audio Processing Unit) delivers Dolby Digital 5.1 cinematic-quality sound and 3D positional audio to your home PC. By SoundstormTM technology, the NF7-S supports Real-time audio encoding delivering up to 256 simultaneous audio streams makes games and applications come to life. With cutting-edge features and ABIT Engineering, the NF7 series is the ultimate multimedia platform for the world.
Features
AGP 8X
AGP 3.0 8X spec supports high performance graphics processing at a peak bandwidth of 2.1 GB/s.
Serial ATA 150
Serial ATA is an evolutionary replacement for the Parallel ATA storage interface. This new high-speed interface burst data transfer rate up to 150 Mbytes/sec and more flexible power tolerances, cables can be smaller and more efficient
Dual DDR 400
Dual DDR combines the power of DDR400 with two 64-bit independent memory controllers, the 128-bit memory controller integrated on chip provides up to 6.4 GB/sec bandwidth for system memory, and gives you highest performance and cost-effective platform.
5bit FID (Frequency ID)
By ABIT 5-bits FID Override technology, users can get variety of CPU over-clocking sets.
ABIT CPU H.T.P (Hardware Thermal Protection)
ABIT CPU H.T.P. uses pure hardware detection, which not like others use software detection to prevent CPU overheating. ABIT CPU H.T.P provides more reliable result for customers' investment.
ABIT SoftMenu™
The overclocking function includes CPU frequency, Vcore, multiplier, chipset & DDR voltage and AGP VDDQ voltage adjustment available to maximize your system performance.
SoundStorm™ Technology
Real-time Dolby Digital 5.1 audio encoding delivering up to 256 simultaneous audio streams
6-Channel Audio and Optical S/PDIF Out
Lets you enjoy 6-channel audio without having to buy advanced sound cards.
Order Information
Model Chipset Features
NF7-S nForce2 SPP + MCP2-T SATA, IEEE1394
NF7 nForce2 SPP + MCP2
NF7-M nForce2 IGP + MCP2 Integrated GeForce4 MX
boštjan ::
NF7-S in NF7,kjer je razvidno,da ima nf7 samo dual chanel,soundstorm in sata in firewire,pa ne.
Katero matično
191860 (1601) Grim
kaj moram pazit pri nakupu nforce2 plat
242112 (1750) smirnof
Katero nForce2 plato (strani: 1 2 3 4 … 7 8 9 10 )
47937314 (23909) Jaffa
Radeon 9800 128 Sapphire
422343 (1760) cajne
Katero plato-NUJNO
231775 (1442) boštjan
