hitachi diski?
hitachi diski?
Golden eye ::
A so že v sloveniji tanovi hitači trdi diski?
boštjan ::
kako to misliš novi?hitahci diske so že kar nekaj cajta dobavljivi.
TribesMan ::
A misliš 7k250 serija? Ne te še ni pri nas... to so res zakon diski... Se pa da dobit starejše serije, ki pravtako niso slabe... prav nasprotno so med boljšimi. Za 7k250 bo pa treba še malo počakat. Tud v tujini jih še nimajo povsod.
TribesMan
Golden eye ::
JA to serijo 7k250 sem mislil!! Kdaj pa kaj pridejo in kakšna bo cena?
BaRtMaN ::
V Sloveniji so že, samo zgleda da želijo razprodati firme ostanke IBMovih GXP serij.
Imajo jih pri distributerju Asbis. Vendar rabiš nekako dobiti kakšno njihovo stranko, ker prodajajo samo pravnim osebam.
7K250 120GB SATA, here I come! >:D
boštjan ::
malo sem šel poizvedovat za tem diskom in najdo tole in tole-v raidu
BaRtMaN ::
Diski iz serije 7K250 naj bi na vsakih 10 minut rekalibrilali glave, kar naj bi bilo zelo glasno - tule je email Hitachi supporta:
Dear Mr. Csaba, thank you for your email.
Regarding your enquiry relating to the brief sound that emanates from our
drives.
I suspect that the occasional 'sound' you are hearing is the Idle Time
Function that has been introduced on our latest drive designs as a
reliability enhancement. You need not be alarmed by this,
This "sound" is due to a brief but deliberate head arm movement every so
often. This has been added to maximise the reliability of our disk drive
products.
This function is invoked if an extended period of inactivity is detected,
so has no impact on active performance. [It is bad to leave the heads
hovering over the same data track unnecessarily].
Even after a period of time of activity the Idle Time Function can be
implemented as the Idle Time Function is a cumulative function.
The level of sound emitted may vary from one drive to another and as such
this should not give rise to concern or be considered an impending failure.
Please be assured that this drive design is one of the quietest drives, at
this data density, in the industry.
I trust this information will be of use and help you to resolve your
problem.
Regards, Catrin Schoening
Hitachi Global Storage Technologies
TribesMan: a si ti slišal kaj takega iz tvojega primerka?
  • spremenil: BaRtMaN ()
morphling1 ::
Če ga imajo pri Asbisu bo kmalu tudi nasproti kinoteke :)
TribesMan ::
Ja BaRtMaN tudi moj se rekalibrira vsake toliko časa. Se sliši sam je daleč od glasnega. V tem da se rekalibrira jest ne vidim nič slabega, kvečjem dobro. Si vsaj malo bolj siguren... Je pa res da nekatere ljudi to moti, frend ga je kupil in me že 20 minut za tem ko ga je priklopil kliče kaj to vsake toliko časa zašumi... Pač eni so mal bl občutljivi. Kalibracija pa traja nekje 2 sekunde in odda rahlo šumeč/brneč zvok, kot hummmmmmm. Nič kritičnega. Se pa dobro sliši če maš tiho mašino, ker je veliko glasneje kot sam disk v idle.
morphling:
Tako se govori, sam poskrbi da bom zvedel ko jih dobijo :D
TribesMan
Fury ::
jest se tut zanimam za tele diske. prosim da takoj ko jih kdo vidi sporoci. hvala! :D
jest10 ::
Bodo tudi na ATA vodilu?
Fury ::
morphling1 ::
Če koga še zanima Hitachi 7k250 so nasproti kinoteke v btc-ju 40,120,160,200 GB PATA ter zaenkrat 120 GB SATA
TribesMan ::
Bravo naši! Tile diski so definitivno best buy... jest mam doma 40GB PATA in že močno razmišljam da bi investiral v še enega pa gremo na RAID 0.>:D Sam vprašanje ali sem pripravljen poleg zdajšnjega diska poslušat še dva vrteča stvora.
TribesMan
spenstar ::
Kje je ta kinoteka v BTC-ju?! In katera trgovina prodaja tanove Hitachi diske?
Spenstar
SPENSTAR--builder
boštjan ::
BOF,če se ne motim
JohnyB ::
Jest sm svojga kupu v SunRise je pa PATA 160GB.
Un zvok kukr da bi en mačk zamjavkov pa tud jest slišm na vsake tolk cajta! Je pa to točn to kukr je napisov BaRtMaN!
Preden sm kupu disk sm bral poste v forumu od StorageReview
Tm je glih največ govora glede tega zvoka, ki ga oddaja disk!
Drugače je pa disk res tih!
Apple iMac
Hans_the_butcher ::
Mene pa zanima če kdo ve kolk pride tale Hitachi 7k250 120gb ATA 8MB v bofu?
JohnyB ::
Ja 160GB je bil 34.700 se prav ene par jurjev mn!
Apple iMac
para-site ::
nasproti kinoteke:D
hehe, si dobro to skril, morphling...
samo, da folk potem ne bo prpešaču do BBM.
jutri al pa v četrtek bom tudi jst šel do kinoteke in potem nasproti.
kako je pa kaj z zanesljivostjo teh diskov, so še prenovi, da bi ocenil? seagate se baje najmanj kvarijo, niso pa najhitrejši...
TribesMan ::
nasproti kinoteke
To ni fer! ;(( Pa to sem se jest spomnil ... Zgleda da bom moral začeti uveljavljati TM na moje fraze... :D
Drgač so pa tile Hitachiji pravi cukerčki. Zadeva je prav nemarno tiha. Še seek noise je od prejšnje že tako tihe serije GXP180, pri 7K250 postal še tišji. Sploh ni več tistega trdega zvoka ob random iskanju, zdej je bolj nekakšen šum... Prow navadiš se tega. Milina, tišina...
TribesMan
kok pride 160-200gb?
WhiteWolf ::
Te diske majo tud v JAE v Celju (Kolosej). Ga je ravno kolega zadnjic kupil.
odklop ::
Ja to je pa prvi dober disk ki sem ga kdaj koli mel! Tista kalibracija je skor neslišna, drgač pa ta disk na SATI dela super!
Po mojem je najboljši SATA disk do slej! (hitrost, tiho delovanje, ...) !
Golden eye ::
A pol so tisti diski Hitachi ki jih prodajajo v JAE tapravi? Jest bi kupu "IC GXP 120GB ATA100 7200 obr" < - ta disk. A je kaj dost razlike med ata in sata?
e-marko ::
Priporočam, da še enkrat pregledaš nekaj objav više...
Kolikor vidim, to ni isto (GXP ni 7k250). GXP je druga serija.
E-marko
...somebody, somewhere...
BaRtMaN ::
Res je, GXP serije so še od IBMa. Serija 7K250 je pa prva izpod združenih rok inžinirjev IBMa in Hitachija. Omeniti velja, da so 75GXP ter nekoliko tudi 60GXP diski znani kot Deathstarji. Kdor je imel kakšnega, bo že vedel zakaj.
Golden eye ::
Kje pa pol prodajajo Hitachi 7k250 v Sloveniji?? A jih sploh že?
boštjan ::
sem slišal,da jih majo v BOF-u
EjTi ::
Kaj pa 80GB. Tega naj namreč v BOFu nebi imel. 80GB hočem zaradi: najmanjši z 8MB rama, manj je plat, tišji je.
nevem kok je se smiselen nakup 80gb diska, glede na to da je 120gb jurja ali 2 drazji.
glinik ::
Ha ha, ja hitachiji so že kul diski.
Jaz čakam na 160 Gb SATA, da ga dobijo v Avstriji.V določeni trgovini :) .Takoj ga bom vzel he he he :) !!!
Tihi diski (120-160GB) (strani: 1 2 )
577430 (5582) Grimlord
Kateri 200GB disk izbrati?
453404 (2616) Dr_M
Disk IBM 7k250 moj najboljsi nakup letos. Priporocam bolj kot karkoli drugega. (strani: 1 2 3 4 5 6 )
25117092 (10989) e-marko
160gb sata disk: WD, Maxtor ali Seagate? (strani: 1 2 )
636250 (4822) Jaffa
Kater disk?
202436 (2139) nokia6310
