Forum » Omrežja in internet » Telemach traceroute
Telemach traceroute
CyberPunk ::
Je Telemach blokiral traceroute na mobilnih podatkih? Vsaj preko modema B535 pri vseh nodih izpiše "request timed out", latency izpiše samo pri prvem (router/modem) in pri ciljnem.
NoName ::
Ne le na mobilnih podatkih, telemachovci precej skrivajo topologijo omrežja tudi na optiki.
I can see dumb people...They're all around us... Look, they're even on this forum!
Gapi ::
Sigurno spet čez Srbijo šibajo promet. Ni prvič...
No person is rich enough,to buy back his past.
CyberPunk ::
Izgleda, da je problem v Huawei B535. Kar je po svoje čudno, saj niso posodabljali firmware že par let.
Gagatronix ::
CyberPunk ::
Čudno v smislu, da se je nekaj spremenilo, ne da bi bil kakšen viden vzrok kot npr. update ali sprememba nastavitev. Razen če je operater na svoji opremi blokiral ICMP ipd. za ta model. Preko hotspota na telefonu namreč traceroute deluje OK.
CyberPunk ::
Menda so blokirali "zaradi varnosti"... -_-
Takole izgleda preko modema Huawei:
Takole pa preko hotspota na telefonu (zdaj prikazujejo samo njihove node):
Tracing route to 94-140-14-49.adguard-dns.com [94.140.14.49] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms 192.168.xxx.xxx 2 * * * Request timed out. 3 * * * Request timed out. 4 * * * Request timed out. 5 * * * Request timed out. 6 46 ms 39 ms 50 ms 94-140-14-49.adguard-dns.com [94.140.14.49]
Tracing route to 94-140-14-49.adguard-dns.com [94.140.14.49] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms 192.168.xxx.xxx 2 * * * Request timed out. 3 * * * Request timed out. 4 35 ms 14 ms 16 ms 10.8.0.225 5 19 ms 13 ms 14 ms 10.8.6.30 6 19 ms 15 ms 17 ms 185-66-150-164.static.telemach.net [185.66.150.164] 7 20 ms 17 ms 16 ms 10.2.19.3 8 18 ms 22 ms 16 ms 185-97-71-17.ipv4.telemach.net [185.97.71.17] 9 44 ms 37 ms 32 ms 94-140-14-49.adguard-dns.com [94.140.14.49]
Tommytik ::
TELEMACH fix
C:\>tracert 94.140.14.49
1 4 ms 4 ms 4 ms 192.168.x.x
2 7 ms 6 ms 7 ms 217-72-74-225.static.telemach.net [217.72.74.225]
3 12 ms 14 ms 12 ms 185-66-149-28.static.telemach.net [185.66.149.28]
4 12 ms 14 ms 11 ms 185-66-148-25.static.telemach.net [185.66.148.25]
5 12 ms 14 ms 10 ms 185-66-150-40.static.telemach.net [185.66.150.40]
6 11 ms 11 ms 11 ms ae3-1.vie20.core-backbone.com [193.203.0.154]
7 23 ms 23 ms 23 ms ae1-2003.fra20.core-backbone.com [80.255.14.82]
8 22 ms 22 ms 22 ms coreb-fra.cdn77.com [169.150.195.70]
9 21 ms 21 ms 21 ms vl251.fra-drt30-dist-1.cdn77.com [79.127.195.83]
10 22 ms 22 ms 22 ms 94-140-14-49.adguard-dns.com [94.140.14.49]
Trace complete.
TELEKOM mobilna
1 10 ms 2 ms 2 ms 10.47.145.198
3 30 ms 22 ms 34 ms 213.229.192.241
4 44 ms 28 ms 25 ms 213.229.192.213
5 33 ms 27 ms 27 ms ip-95-176-241-10.generic.siol.net [95.176.241.10]
6 35 ms 29 ms 33 ms 195.22.208.38
7 58 ms 45 ms 52 ms 195.22.196.7
8 54 ms 47 ms 59 ms 195.22.196.7
9 39 ms 39 ms 45 ms 195.22.214.33
10 56 ms 46 ms 43 ms vl251.fra-drt30-dist-1.cdn77.com [79.127.195.83]
11 43 ms 47 ms 44 ms 94-140-14-49.adguard-dns.com [94.140.14.49]
A1 mobilna
1 4 ms 3 ms 3 ms 10.47.145.198
3 37 ms 34 ms 36 ms 10.107.141.193
4 40 ms 35 ms 42 ms edge3.simobil.si [109.239.185.138]
5 30 ms 39 ms 34 ms 109.239.185.157
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * 39 ms 23 ms 80.120.167.30
10 45 ms 25 ms 25 ms 80.120.167.29
11 51 ms 26 ms 27 ms lag14-9079.as8447.a1.net [195.3.64.202]
12 39 ms 38 ms 24 ms lag6-9070.as8447.a1.net [195.3.64.230]
13 36 ms 21 ms 28 ms lag1-9073.as8447.a1.net [195.3.64.150]
14 53 ms 47 ms 44 ms 178.18.236.189
15 74 ms 41 ms 43 ms vl231.ams-eq6-core-1.cdn77.com [169.150.194.32]
16 56 ms 46 ms 48 ms vl221.ams-eq6-dist-1.cdn77.com [79.127.194.83]
17 57 ms 49 ms 53 ms 94-140-14-49.adguard-dns.com [94.140.14.49]
Trace complete.
C:\>
Zgoraj trace iz Telemach fix ter Telekom in A1 mobilne. Kot se vidi ima vsak svojo pot.
Zakaj na mobilni ne prikažejo celega tracea je pa že kak razlog, ker ga tudi pri A1 ni.
Živ
Trace complete.
TELEKOM mobilna
A1 mobilna
Trace complete.
C:\>
Živ
| » | Kater LTE modem? (strani: 1 2 3 )Oddelek: Omrežja in internet | 20934 (1028) | alekskac |
| » | kater 5g modem (strani: 1 2 3 )Oddelek: Omrežja in internet | 30820 (926) | LTE freak |
| » | Hitrost mobilnega internetaOddelek: Omrežja in internet | 4211 (242) | LTE freak |
| » | Carrier AggregationOddelek: Omrežja in internet | 7000 (2607) | beta1 |
| » | 4G/LTEOddelek: Omrežja in internet | 3744 (2413) | V-i-p |
