Forum » Mobilne tehnologije » Huawei p50 pro menjava baterije
dajoker ::
Na p50 pro sem menjal baterijo. Zadeva obstane v boot loopu. Splet pravi, da je vzrok neoriginalna baterija. Ko vstavim nazaj staro baterijo, telefon normalno deluje. Se je kdo spopadel s tem problemom in kako ga je rešil?
Hvala vnaprej za pomoč!
"Hacker" is a term of honour and respect. It is a term that describes
a skill, not an activity. K. Mitnick
Preizkusi hot swap metodo
https://www.reddit.com/r/Huawei/comment...
Single-Risk4389
This happens with used battery only. Original new battery will pair with the phone the first time it is powered one.
Since some time has passed, you probably wont need the solution any more. But maybe it will help somebody else. The solution is easy.
You start your phone with your old original battery. You insert a charging cable. At this point you are able to remove your old battery, the phone will remain powered on during that. Don't power it off. Then while it's still powered on without any battery connected you insert the ,,new" battery that was not accepted before. Restart phone. At this point your problem is solved, you can use the Phone without any future problems.
Razlog ?
BMS - Battery Management System
Telefoni Huawei (in tudi drugi proizvajalci) imajo pogosto strožjo kontrolo pristnosti baterij, saj prek BMS-a komunicirajo z vezjem na sistemski plošči:
o Preverjanje serijske številke in UID baterije.
o Merjenje upora / temperature celic.
o Kalibracijski podatki (IC na bateriji hrani podatke o ciklih, zdravju
https://xdaforums.com/t/battery-replace...
Ali idoc.eu baterija ?
Softver za zamenjavo serijske:
Sigma Software v.2.40.02
https://forum.gsmhosting.com/vbb/f719/s...
Single-Risk4389
Razlog ?
Huawei battery have serial id which must be setted with a software, or you can hotswap it (if the original work)
- spremenilo: sbawe64 ()
dajoker ::
Na bateriji piše SCUD (Fujian) Electronics, popolnoma identično, kot na originalu.
dajoker ::
Hot swap sem naredil po postopku
1 ugasnjen telefon
2 stara baterija
3 zagon
4 priklop polnilca
5 odklop stare baterije
6 priklop nove
Do tu vse deluje, ampak po ponovnem zagonu zopet boot loop.
Pri naslednjem poskusu sem po zamenjavi baterije odklopil polnilec, ponovno zagnal - zopet boot loop.
Zdaj sem ponovil postopek, pustil polnilec, da se je nova baterija napolnila do 100%, odklopil polnilec in pustil telefon, da se popolnoma izprazni.
1 ugasnjen telefon
2 stara baterija
3 zagon
4 priklop polnilca
6 priklop nove
Technics ::
Ker moraš vpisati serijsko baterije z Sigmakey boxom.
dajoker ::
Dela to kdo v okolici Celja?
| » | Kateri Power pack / power bank ? (strani: 1 2 3 )Oddelek: Kaj kupiti | 38470 (19260) | k4vz0024 |
| » | Apple bojda ob iztrošeni bateriji upočasni iPhone (strani: 1 2 3 )Oddelek: Novice / Apple iPhone/iPad/iPod | 64583 (58715) | MrStein |
| » | Samsung predstavil Galaxy Note8 (strani: 1 2 )Oddelek: Novice / Android | 37369 (33361) | Ishmael |
| » | Najdlje zdrži HTC 10, najhitreje se upeha iPhone 7 (strani: 1 2 )Oddelek: Novice / Android | 34096 (29498) | leiito |
| » | Počasno polnjenje (Galaxy S5)Oddelek: Mobilne tehnologije | 5637 (5291) | gusto |
