Forum » Programiranje » pygame problem 2
pygame problem 2
dejco_h ::
dober dan spet jaz.
Skratka delam enako igrico kot pred parimi tedni in sem naletel na problem...in sicer problem je ta da ko collidam playera in fllor in hočem pritisnit tipko space(za skok mi player kar izgine) in tudi ni picture perfect collison saj player pristane rahlo pod florom in ne čisto na njem...mi lahko kdo pomaga razrešit nastal problem?? hvala vsem za odgovore ter sugestije
import pygame
import random
import math
import os
from os import listdir
from os.path import isfile,join
pygame.init()
pygame.display.set_caption("platformer game")
WIDTH,HEIGTH=1000,800
win=pygame.display.set_mode((WIDTH,HEIGTH))
FPS=60
Player_Vel=3
def flip(sprites):
return [pygame.transform.flip(sprite,True,False)for sprite in sprites]
def load_sprite_sheet(dir1,dir2,width,heigth,direction=False):
path=join("Assets",dir1,dir2)
images=[f for f in listdir(path) if isfile(join(path,f))]
all_sprites={}
for image in images:
sprite_sheet=pygame.image.load(join(path,image)).convert_alpha()
sprites=[]
for i in range(sprite_sheet.get_width()//width):
surface=pygame.Surface((width,heigth),pygame.SRCALPHA,32)
rect=pygame.Rect(i*width,0,width,heigth)
surface.blit(sprite_sheet,(0,0),rect)
sprites.append(pygame.transform.scale2x(surface))
if direction:
all_sprites[image.replace(".png","")+"_right"]=sprites
all_sprites[image.replace(".png", "") + "_left"] = flip(sprites)
else:
all_sprites[image.replace(".png","")]=sprites
return all_sprites
def load_block(size):
path=join("Assets","Terrain","terrain.png")
image=pygame.image.load(path).convert_alpha()
surface=pygame.Surface((size,size),pygame.SRCALPHA,32)
rect=pygame.Rect(96,0,size,size)
surface.blit(image,(0,0),rect)
return pygame.transform.scale2x(surface)
class Object(pygame.sprite.Sprite):
def __init__(self,x,y,width,heigth,name=None):
super().__init__()
self.rect=pygame.Rect(x,y,width,heigth)
self.image=pygame.Surface((width,heigth),pygame.SRCALPHA)
self.width=width
self.heigth=heigth
self.name=name
def draw(self,win):
win.blit(self.image,(self.rect.x,self.rect.y))
class Block(Object):
def __init__(self,x,y,size):
super().__init__(x,y,size,size)
block=load_block(size)
self.image.blit(block,(0,0))
self.mask=pygame.mask.from_surface(self.image)
def get_background(name):
image=pygame.image.load(join("Assets","Background",name))
_,_,width,height=image.get_rect()
tiles=[]
for i in range(WIDTH//width+1):
for j in range(HEIGTH//height+1):
pos=(i*width,j*height)
tiles.append(pos)
return tiles,image
def draw(win,backGround,backg,player,objects):
for bckg in backGround:
win.blit(backg,bckg)
for obj in objects:
obj.draw(win)
player.draw(win)
pygame.display.update()
class Player(pygame.sprite.Sprite):
GRAVITY=1
COLOR = 255, 0, 255
DELAY=3
SPRITES=load_sprite_sheet("MainCharacters","MaskDude",32,32,True)
def __init__(self,x,y,width,heigth):
super().__init__()
self.x_vel=0
self.y_vel=0
self.mask=None
self.direction='left'
self.animation_count=0
self.fall_count=0
self.jump_count=0
def jump(self):
self.y_vel=-self.GRAVITY*6
self.jump_count+=1
if self.jump_count==1:
self.fall_count=0
def move(self,dx,dy):
self.rect.x+=dx
self.rect.y+=dy
def move_left(self,Vel):
self.x_vel-=Vel
if self.direction!='left':
def move_right(self,VEL):
self.x_vel+=VEL
if self.direction!='right':
self.direction='right'
def update_sprite(self):
sprite_sheet = "idle"
if self.y_vel < 0:
if self.jump_count == 1:
sprite_sheet = "jump"
elif self.jump_count == 2:
sprite_sheet = "double_jump"
elif self.y_vel > self.GRAVITY * 2:
sprite_sheet = "fall"
elif self.x_vel != 0:
sprite_sheet = "run"
if self.x_vel != 0:
sprite_sheet_name = sprite_sheet + "_" + self.direction
sprites = self.SPRITES[sprite_sheet_name]
sprite_index = (self.animation_count // self.DELAY) % len(sprites)
self.sprite = sprites[sprite_index]
self.animation_count += 1
self.update()
def update(self):
rect=self.sprite.get_rect(topleft=(self.rect.x,self.rect.y))
self.mask=pygame.mask.from_surface(self.sprite)
def loop(self,FPS):
self.y_vel+=min(1,(self.fall_count/FPS)*self.GRAVITY)
self.move(self.x_vel,self.y_vel)
self.fall_count+=1
self.update_sprite()
def landed(self):
self.fall_count=0
self.y_vel=0
self.jump_count=0
def hit_head(self):
self.fall_count=0
self.y_vel*=-1
def draw(self,win):
win.blit(self.sprite,(self.rect.x,self.rect.y))
def handle_move(player,object):
player.x_vel=0
keys=pygame.key.get_pressed()
if keys[pygame.K_LEFT]:
player.move_left(Player_Vel)
if keys[pygame.K_RIGHT]:
player.move_right(Player_Vel)
handle_vertical_collison(player,object,player.y_vel)
def handle_vertical_collison(player,object,dy):
collided_objects=[]
for obj in object:
if pygame.sprite.collide_mask(player,obj):
if dy>0:
player.rect.bottom=obj.rect.top
player.landed()
elif dy<0:
player.rect.top=obj.rect.bottom
player.hit_head()
collided_objects.append(obj)
return collided_objects
def main():
run = True
clock = pygame.time.Clock()
background,backg=get_background("Purple.png")
player=Player(100,100,50,50)
block_size=96
floor = [Block(i * block_size, HEIGTH - block_size, block_size) for i in
range(-WIDTH // block_size, (WIDTH * 2) // block_size)]
while run:
clock.tick(FPS)
for event in pygame.event.get():
if event.type==pygame.QUIT:
run=False
break
if event.type==pygame.KEYDOWN:
if event.key==pygame.K_SPACE and player.jump_count<2:
player.jump()
player.loop(FPS)
handle_move(player,floor)
draw(win,background,backg,player,floor)
if __name__ == '__main__':
main()
| » | Return ne deluje[python]Oddelek: Programiranje | 1477 (1341) | Jonatan |
| » | [Python3] Izvajanje ukazov po določenem časuOddelek: Programiranje | 1966 (1576) | noraguta |
| » | Predstavitev dvojiškega drevesa z seznamomOddelek: Programiranje | 2692 (2292) | ktka |
| » | [Python]Naloga z razredi in dedovanjemOddelek: Programiranje | 1540 (1292) | ktka |
| » | python -slovarOddelek: Programiranje | 3800 (2779) | Valex86 |
