Forum » Zvok in slika » Zvok ne dela v tv ripu
gonilnik ::
A mi lahko kdo pove kateri codec si moram naložiti da bi mi delal zvok v filmu?
gonilnik---} driver---} šofer---} jaz
- spremenil: CaqKa ()
gonilnik ::
Sem uporabil G-spot pa poleg tega ne vem kaj naj naredim.G-spot mi je pokazal naslednje:
Special Note: GSpot determined this audio should play, yet it didn't, and the format code is 0x160 or 0x161.
This combination of conditions is a likely indicator that the Microsoft WMA codec is attempting to play DivX 3 audio,
or vice versa - an unfortunate result of original DivX designers' neglect to use a distinct format code.
The ability to play this audio may be dependent on the installation or uninstallation of at least the audio portion
of the DivX 3.11 codec. This codec may also be referred to as "DivX audio version 4.0x"
gonilnik ::
Mislim da nimam instaliranega div 3.11
Tole vrže ven g-spot:
The following codecs all claim to be capable of processing this format:
--> {Windows Media Audio}
--> {Windows Media Audio Decoder}
{WMAudio Decoder DMO}
Special Note: This audio format code, 0x160/0x161,
is problematic in that may indicate audio encoded with either the Divx 3 or one of the a Microsoft WMA codecs.
It is suggested that you press the "render" button and view the results.
GSpot will offer special information in that section if there appears to be a problem related to this
DirectShow was also able to find a codec to render it - the sound for this media clip should work fine.
CaqKa ::
ti razmeš angleško?
namreč prevedo ti bom samo to kar ti je gspot napisal in si ti tukaj postal
enega od teh dveh kodekov morš izbrisat/odinštalirat, ker se tepeta med sabo in se ne znata zmenit kater bi zvok predvajal.
gonilnik ::
Bolj bogo razmim Angleško
Povej mi samo nekaj:Kako naj izbrišem/odinstaliram tale codec če pa tega sploh instaliral nisem.
Tepeta pa se spodnja dva(se mi zdi)
CaqKa ::
hmm tega pa žal nebi vedel..
možno da je z kakšno inštalacijo wmp9 prišel zraven .. ali pa z dx9...
predlagam ti da inštaliraš divx3.11 ali pa wmp9, če pa nebo delalo pa kar oba...
gonilnik ::
Hvala za pomoč CaqKa.Sem instaliral wmp9 pa sedaj imam zvok.
| » | DivX codec nadomestilo - ffdshow kodek (strani: 1 2 3 4 5 )Oddelek: Zvok in slika | 62636 (17784) | BaRtMaN |
| » | Film malo pred koncem zaštekaOddelek: Zvok in slika | 2606 (2529) | mmilos |
| » | Kateri codec pack uporabljate?Oddelek: Zvok in slika | 3058 (2756) | Cokolesnik |
| » | div3?Oddelek: Zvok in slika | 1762 (1599) | Kawl6 |
| » | NOLF2 + talk/speachOddelek: Igre | 2192 (2037) | cooolah |
