Forum » Programiranje » [FIXED] Debian 12 in MariaDB 11: Ukaz mysqldump in mysql ne delata (command not found).
HotBurek ::
Dobro jutro.
Danes imam sledeč izziv. Imam najnovejši sistem Debian 12 (bookworm) in MariaDB (11.2.2).
Paketa mysql-client "ni", a ga nadomeščata druga dva:
Nameščena imam oba paketa (mariadb-client in mariadb-client-core):
Ukaz locate mysqldump ne najde fajla, se pravi, da ga ni v /use/bin/ ali /use/sbin/ ali /usr/local/ (preveril tudi peš).
Program mysql (oz. mariadb) laufa.
UPDATE (fixed)
Našel sem file mariadb-dump na lokaciji /usr/bin/. Pognal ukaz mariadb-dump ...(namesto mysqldump) in dela. Isto velja, če se hočeš v terminalu konektat na server: namesto mysql... gre z mariadb.... Krneki tole po/pre imenovanje.
root@nightrun:/# apt-get install mysql-client Reading package lists... Done Building dependency tree... Done Reading state information... Done Package mysql-client is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source However the following packages replace it: mariadb-client-core mariadb-client E: Package 'mysql-client' has no installation candidate
root@nightrun:/# apt-get install mariadb-client Reading package lists... Done Building dependency tree... Done Reading state information... Done mariadb-client is already the newest version (1:11.2.2+maria~deb11). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. root@nightrun:/# root@nightrun:/# root@nightrun:/# apt-get install mariadb-client-core Reading package lists... Done Building dependency tree... Done Reading state information... Done mariadb-client-core is already the newest version (1:11.2.2+maria~deb11). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@nightrun:/# ps aux | grep mysql mysql 679 0.2 1.8 5559244 302788 ? Ssl 12:17 0:01 /usr/sbin/mariadbd root 1014 0.0 0.0 6332 2144 pts/0 S+ 12:29 0:00 grep mysql
UPDATE (fixed)
root@debian:/# iptraf-ng
Please resize your window
- spremenilo: HotBurek ()
nosiyo ::
Quick history lesson: MySQL je bil free, dokler ga ni prevzel Sun (tega pa Oracle) in ga naredil plačljivega. Ostala je free različica, ki pa ne dobiva vseh fičerjev, ki jih ima plačljiva verzija. Zato se od leta 2009 naprej ločeno razvija še MariaDB, ki je fork free verzije MySQLa. Posledično je MariaDB vedno korak pred free MySQL-om in že precej let defacto standard free SQL baza. Še vedno pa večina ljudi temu reče MySQL, jezik je skoraj identičen.
| » | Kako namestit modul "pid" (Python) na Debian?Oddelek: Programiranje | 932 (745) | Ales |
| » | Izšel Ubuntu 21.10 (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 18239 (13204) | Ashrack |
| » | [Debian] apt remove zagonetka...Oddelek: Operacijski sistemi | 862 (654) | HotBurek |
| » | [Ubuntu] SambaOddelek: Programska oprema | 2345 (2135) | black ice |
| » | [ubuntu] nepreverjeni paketi na si.archive.ubuntu.com ?Oddelek: Programska oprema | 1338 (1223) | MrStein |
