Kako namestit modul "pid" (Python) na Debian?
HotBurek ::
Dobro jutro, fantje in dekline.
Nov dan, nov problem.
V Python-u sem imel delujoč pid package, kateri pa sedaj ne deluje.
ModuleNotFoundError: No module named 'pid'
Če ga poizkušam namestit preko pip3, dobim sledeč error:
root@debian:/# pip3 install pid
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
    python3-xyz, where xyz is the package you are trying to
    install.
    If you wish to install a non-Debian-packaged Python package,
    create a virtual environment using python3 -m venv path/to/venv.
    Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
    sure you have python3-full installed.
    If you wish to install a non-Debian packaged Python application,
    it may be easiest to use pipx install xyz, which will manage a
    virtual environment for you. Make sure you have pipx installed.
    See /usr/share/doc/python3.11/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or
OS distribution provider. You can override this, at the risk of breaking your
Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
Preko apt ga prav tako ne morem namestit (ga ne najde):
root@debian:/# apt-get install python3-pid
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package python3-pid
In sedaj ne vem, kaj še naj poizkusim.
root@debian:/# iptraf-ng
Please resize your window
  • spremenilo: HotBurek ()
HotBurek ::
Ok, zadevo sem rešil z uporabo --break-system-packages.
Vir: https://stackoverflow.com/questions/756...
Ne vem pa, kje je zdej na disku ta package.
Ahim ::
Zakaj pa nisi sel po prvi predlagani poti?
If you wish to install a non-Debian-packaged Python package, create a virtual environment using python3 -m venv path/to/venv. Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make sure you have python3-full installed.
HotBurek ::
Ta venv mi je neznanka in ne ne znam uporabljat.
Ahim ::
HotBurek je izjavil:
Potem se ti pa splaca malo ustavit, vlozit kak dan v to in nastudirat, ce mislis se napej s Pythonom delat.
Ales ::
Alternativno, poglej https://software.opensuse.org/download....
Ampak dejansko poglej vsebino paketa, preden ga kar tako nameščaš.
[linux] python update -> izginil taskbar, ikone, terminal ne deluje
5835 (609) Invictus
Python PyCharm in Pandas/NumPy paketi
Oddelek: Programiranje
121432 (1107) bluefish
Postavitev mySQL
92880 (2458) M01O
Uporaba py2exe, Freeze in py2app
Oddelek: Programska oprema
71063 (902) filips
[python] težave z namestitvijo setuptools, pypi
111200 (1096) ragezor
