[Debian] apt remove zagonetka...
HotBurek ::
Dobro jutro.
Iz Debian sistema bi rad odstranil emacsen-common, a se zadeva zalomi. Kot, da bi pri remove želel namestit paket... kar je kontra od remove.:|
Takole so ukazi in log v terminalu:
root@debian:/#
root@debian:/#
root@debian:/# apt remove emacsen-common
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libwebkit2gtk-4.0-37 : Depends: libenchant1c2a (>= 1.6.0) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
root@debian:/#
root@debian:/#
root@debian:/# apt list --installed | grep libenchant1c2a
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libenchant1c2a/stable,now 1.6.0-11.1+b1 amd64 [installed]
root@debian:/#
root@debian:/#
root@debian:/# apt list --installed | grep libwebkit2gtk-4.0-37
libwebkit2gtk-4.0-37/stable,stable,now 2.32.3-1~deb10u1 amd64 [installed,automatic]
root@debian:/#
root@debian:/#
Pognal sem že apt reinstall za oba, libwebkit2gtk-4.0-3 in libenchant1c2a, a ni pomagalo.
root@debian:/# iptraf-ng
Please resize your window
errhec ::
Zaženi synaptic package manager in tam odstrani emacsen-common.
dd
HotBurek ::
Ok, sem namestil Synaptic, našel paket emacsen-common in ga dal za remove.
Potem pa prikaže obvestilo, da bo to odstranilo še ~100 drugih programov.
Zanimivo, da apt na to ni obvestil. Bi že tam lahko zaključil.
Hvala za nasvet za Synamptic program. Nisem poznal.
  • spremenilo: HotBurek ()
Zvezdica27 ::
to veš, da si root? To se načeloma odsvetuje... oz. zakaj nalašč delaš to kot root in ne le kot superuser?
zz
To je čudno, da bi ti emacsen-common odstranil tudi libenchant1c2a. A samo apt install ti deluje ok?
HotBurek ::
Če mi apt install deluje ok? Well v kakšnem kontekstu?
Z apt lahko nameščam in odstranjujem programe normalno, računalnik je isti že par let.
Do zgornje zagonetke sem prišel tako, da sem namesti emacs, pogledal program, in se odločil da ga odstranim.
Pod apt list --installed | grep emacs se mi tudi ta paket izpiše.
Mogoče bom šel gledat, če se da zlistat, kdaj je bil ta paket ploh nameščen...
Debina9 Apache2 | ./configure, make, make install
Oddelek: Operacijski sistemi
51067 (953) HotBurek
Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )
1960128063 (43737) RedDrake
Debian 4.0 (Etch) končno izdan
405705 (4028) Matevžk
Kako naj naložim program v linux-u (strani: 1 2 3 )
Oddelek: Programska oprema
1458059 (6988) CCfly
Linux internet povezava problem
442516 (2131) dr.J
