Forum » Loža » Irska ukinja svobodo govora
Polda ::
Ireland’s lower house, the Dáil, has passed a hate-speech bill that is almost comical when described. You don’t even have to offend anyone to be guilty of “hate.” A judge can simply determine that the speech at issue was “likely to incite hatred or violence” toward members of protected groups. Also, you can be convicted before uttering or publishing the speech. A judge only has to determine whether you “possessed” the speech, perhaps in a drafts folder on a phone, and had an intent to utter or publish it. Oh, and by the way, the bill allows the state to compel a person to hand over the passwords to his phone or face imprisonment, based simply on the allegation. And finally, the law would presume guilt once possession is established. “In any proceeding under this section . . . the person shall be presumed until the contrary is proved, to have been in possession of the material in contravention” of the law. You’d have to prove to the judge and the prosecutor that you did not intend to publish it.
https://www.nationalreview.com/2023/05/...
Ta zakon so podprle vse večje stranke od levice do desnice.
Potrebno je izpostaviti pomemben del zakona. Sciti zgolj zascitene skupine. Torej lahko zascitena skupina zali in napada nezasciteno skupino nekaznovano. Sramota od zakonodaje.
s1m0n ::
Oziroma tole je že malo zastarelo zdaj je trans pred geji na lestvici zatiranosti... samo za muslimani? Oziroma kako gre lestvica trenutno?
Torej je ta zakonodaja kup dreka. Pol pa jokate, da je tezava, da nas bodo pojedi africani. Mogoce trenutno stanje kaze na degeneracijo zahodne druzbe, ki jo bo izpodrinila bolj vitalna druzba.
T440 ::
tikitoki, dobro da si omenil afričane! Tudi ti so zaščiteni in jih je treba ustrezno umestiti.... Če se identificiraš kot trans črna muslimanka iz Afrike, po moje lahk še vedno govoriš kar želiš.
al pa če se identificiraš kot podpornik instituta 8. marec....
... je tud vse dovoljeno.
- spremenilo: T440 ()
Tema gre downhill.
Postani gej in/ali musliman in uživaj zaščito novega zakona!
Napačno! Identificiraj se kot gej in/ali musliman...
Pa sej se lahko identificiraš tudi kot zobna vila ali pa samorog. Boš lih tko zaščiten.
WizzardOfOZ je izjavil:
Pa sej se lahko identificiraš tudi kot zobna vila ali pa samorog. Boš lih tko zaščiten.![]()
Ne nujno. Kot rečeno je caka tega sovražnega govora, da obstaja znotraj "lestvice zatiranih". Recimo, če so zlobne vile stopničko višje na lestvici zatiranih kot samorogi lahko one mirno rečejo "jebeš samoroge" in ne bo nič, obratno pa cela štala. Lep primer so transi, ki so trenutno prehiteli geje - ko da bi konjski derbi gledal.
- spremenil: Miki N ()
lynxslo5 ::
Dokler je bila Irska revna je bila očitno bolj normalna in zdrava družba kot je sedaj. Sedaj, ko pa so druga najbolj bogata država v EU pa sprejemajo take nore zakone.
Drugače pa bo ta tema še danes zaklenjena, ker ni v skladu z agendo mavrične moderatorske sekcije.
- spremenil: lynxslo5 ()
Darko! ::
To bi na ST pa ja mogl bit jasno.
To še mi, zabiti desničarski kmetavzi vemo, kako stvari stojijo v mestu in kot kaj se moramo identificirat, da preskočimo vrsto.
Trenutno si največja faca, če se deklariraš kot temnopolta lezbijka, s tem, da maš nekje v CV navedbo, da si se v bistvu rodil kot transgender dec, ki si je kasneje spremenil spol.
Sliši se zakomplicirano, vendar ni. Se človek navadi.
Na gasilski veselic v soboto zvečer to še vedno ni za razlagat; ma že v osnovni šoli pa ne bi smel bit panike in je najbrž že tko samoumevno, kot tisto, da smo šli mulci po verouku na čips in sendvič s posebno (ok, včasih smo dobl še sir not, če si prej dokazu prodajalki, da maš dnar in boš lahko plačal).
Sploh, če ti že mula iz osmega razreda osnovne šole pri družinskem kosilu pravi, da je bit gej ali lezbijka zdaj in. Ko jo vprašam zakaj tako misli, mi odvrne, da tako pač je in da sem itak za cajtom. Ji nisem hotel oporekat.
In sem kr tiho srebal svoje nudlne.
Zimonem ::
Ma dej tis 20 let za leseno žlico. Če nis transeksualna lezbika temnopoltega porekla, si preživeta zgodba.
- spremenilo: Zimonem ()
no comment ::
Na srečo nič v tem povzetku ne drži. Tisti, ki znajo brat, se lahko sami prepričajo.
DeeJay ::
Itak, da ne drži. Low IQ si hitro sam po svoje razloži zakone, oziroma jim jih njihov vodja predstavi kot sam hoče. Ovčke pa blejejo.
Don't f with me.
Samael ::
Ah kje. Potrebno je izpostaviti, da podobno kot vse ostale jokice zgoraj, nisi prebral ene vrstice zakona, ki ga komentiraš. Sramota za tikitokija. Ampak saj smo navajeni, aneda :)
Zdaj pa marš brati - pozorno, razmišljujoče - predno postrežeš z naslednjo bedarijo.
Samael != Samuel
no comment ::
Pozitivna stvar te teme je, da smo končno videli, kako so kritično razmišljujoči osebki (tisti, ki informacije ne pobirajo nekritično iz MSM), popravili vse lažne informacije, ki so jih natrosili opranoglavci na začetku teme.
Wait....
Wait....
ahac ::
Irska ukinja svobodo govora?
Kdaj so jo pa imeli?
Še do nekaj let nazaj je bilo tam prepovedano "žaliti" religijo.
Blasphemy law in the Republic of Ireland @ Wikipedia
Ampak to vas seveda ni motilo, ker v resnici vam ne gre za svobodo govora...
- spremenil: ahac ()
fulk ::
Popolne svobode govora sicer res ni, je pa bolje, ko zaniha v našo stran kot pa na stran degenerirancev. Pač pragmatično gledam.
Če že moram biti posiljen, raje sem posiljen od klera kot od satanistične drag queen.
Tu imaš.
https://www.gov.ie/en/press-release/74e...
Criminalize hate speech for first time.
Genuine free speech.
Naša stran je zgolj extrapolirala kako se bo zakon uporabljal. In točno tako se bo.
no comment je izjavil:
Wait....
Tu imaš.
The new legislation will criminalise any intentional or reckless communication or behaviour that is likely to incite violence or hatred against a person or persons because they are associated with a protected characteristic. The penalty for this offence will be up to five years' imprisonment.
- spremenil: fulk ()
fulk ::
The protected characteristics in the new legislation are race; colour; nationality; religion; national or ethnic origin; descent; gender; sex characteristics; sexual orientation; and disability.
We are all horrified when we hear of homophobic, racist, and other hateful incidents in our country.
BAM!!!! NAŠEL!!
Descent is distinct from race and would be relevant, for example, in the context of the Jewish community, where a person may have Jewish ancestry but does not practice the religion.
Jup. Kot pričakovano!
"Would be relevant in the context of the Jewish community"
Prekleto, kako tako zelo predvidljivi so!
fulk ::
BTW. To je Irska. Del EU. Garantiram vam, da mašinerija v EU že melje podobno.
V doglednem času, bo tudi pri nas 5 letna zaporna kazen. In takrat boste končno nazaj lahko vrjeli, da je vse zgolj naključno in da Jewish community nima nič pri tem.
| » | EU za čistejši svetovni splet (strani: 1 2 3 )Oddelek: Novice / NWO | 39027 (33186) | konspirator |
| ⊘ | No-go zones (strani: 1 2 )Oddelek: Problemi človeštva | 16281 (14177) | kuglvinkl |
| » | Violation of Privacy by DURSOddelek: Loža | 5256 (4120) | Bankey |
| » | Prepoved "spodbujanja nestrpnosti" in paradoks svobode govora (strani: 1 2 3 4 5 )Oddelek: Problemi človeštva | 15583 (12923) | BlueKnight |
