[HELP] Linux in mrežna kartica
Spike ::
Namestil sem si slovensko verzijo RedHat 9 -> Pingo 2.0. Sedja pa sem naletel na majhen problem. Linux mi sam ne zazna mrežne kartice, ki je integrirana na matično ASUS A7V333-X in bi si rad namestil gonilnike, ki so na CDju. Tukaj pa pride do problema. OK odpakiram gonilnike v en imenik na disku kot piše v navodilih. Ko pa bi morla narediti nek file z ukatom 'make' pa napiše gcc cannot found ... ali nekaj takega
tukaj so še navodila, če komu kaj rabijo:
Building Driver From TAR File
1. Create a directory and extract the files:
tar xvzf bcm4400-1.0.1.tar.gz
If installing the driver on SuSE Linux, refer to the Notes section below
before continuing.
2. Build the driver bcm4400.o as a loadable module for the running kernel:
cd src
make
3. Test the driver by loading it:
insmod bcm4400.o
4. Install the driver and man page:
make install
See RPM instructions above for the location of the installed driver.
5. To configure network protocol and address, refer to various Linux
documentations.
To torej piše v navodilih. Če kdo ve kako naj namestim naj pomaga:)
podtalje ::
nimaš instaliranega gcc prevajalnika.
Poglej katere pakete imaš instalirane in tam obkljukaj gcc.
dr.J ::
verjetno boš moral narediti točko 4) pred 3)
Sicer pa inštaliraj naslednje pakete:
c++
gcc
glibc-devel
libstdc++
libstdc++-devel
Novi SuSE v10.0 (strani: 1 2 3 )
Oddelek: Operacijski sistemi
10811349 (8800) kriko1
unmergal sem gcc
422337 (2083) borchi
Problemi s compilanjem v Linux Slackware 9.1
352378 (2097) Vesoljc
Linux / ATI Radeon / problem z driverji
132208 (2025) ahac
Vtis Gentoo Linux 1.4
211745 (1509) Brane2
