Forum » Problemi človeštva » Nova finančna kriza na obzorju
Krize ni. Rekordne zaloge plina, 0% inflacija...
Verjento so v EU mislili, če boš v Ukrjino poslal dvoletni vojaški proračun rusije, da bo zadeva končana in bomo v evropi imeli poceni žitarico kot Hitler, ki je rabil poceni hrano za nafutrat narod.
Kot kaže nekateri še vedno uporabljajo sistem Noja.
FrRoSt ::
Hitler je potreboval nafto.
komu zvoni; zvoni tebi.
cias ::
Hitler je potreboval nafto.![]()
Saj so meli sintetično, še danes se uporablja.
South Africa has no oil. But it has a heck of a lot of coal. And from the 1960's, when South Africa was internationally isolated due to Apartheid, fuel became a problem, due to pressure put on the oil-rich countries by the West not to sell to SA.
So, South Africa started up SASOL, the Suid Afrikaanse Steenkool en Olie Maatskappy, to manufacture synthetic fuel (the whole range - from petrol to diesel with even agricultural fertilizer as byproducts) from coal, using the Fischer-Tropsch process.
And we're still using it. It is sold at the same price that other oil-based fuels due to fuel price regulation, but if it wasn't for that, it would've been sold a lot cheaper.
Nizozemski tulipanarji gredo v default
https://www.spiegel.de/wirtschaft/servi...
Sankcije delujejo!
Sankcije delujejo!
- spremenilo: sbawe64 ()
cias ::
Zadnjič sem bral da nordijci mečejo jagode v smeti. Vsaj pujske bi z njimi nahranili, samo menda tudi te mečejo v odpad
Prihodnost tako svetla...
Da kot nemci so za svoje potrebe potrebovali nafto in žitarico.
Last weekend, Credit Suisse repo guru published what may have been the most insightful snippet of the entire European energy crisis (to date) when he extended the infamous "Minsky Moment" framework to Europe, and specifically Germany, which he said "can't cover its payments without Russian gas and the government is asking citizens to conserve energy to leave more for industry." He then elaborated that "Minsky moments are triggered by excessive financial leverage, and in the context of supply chains, leverage means excessive operating leverage: in Germany, $2 trillion of value added depends on $20 billion of gas from Russia... ...that's 100-times leverage - much more than Lehman's.
https://www.zerohedge.com/markets/swede...
V EU imamo po novem prosti trg za plin, dolgoročne pogodbe so odpadle, rezultati kmalu..
nirburu ::
Upam, da se ta planiran kolaps izjalovi in da se namesto zmrzovanja ob praznem kurišču, kurimo na razne WEF-ovce, Eu-komisije in ostale sovražnike evropskih narodov.
jernejl ::
v tem primeru bomo najprej skurili rusofile, potem pa ruse. Slednjih bo dovolj za nekaj zim. Za boljše gorenje bomo pristavili zaplenjeno rusko premoženje: pohištvo v njihovih nepremičninah, les z njihovih jaht in podobno.
- spremenil: jernejl ()
nirburu ::
Hja, tudi prav. Glej, meni ni rus prepovedal vn iz občine, tko da ni na moji prioritetni listi. WEF-ovci in ostal globohomo aparat je moj primarni cilj.
Sicer ljudstvo se ne bo borilo proti njim, ker še preveč jih ne vrjame vanje, ampak lahko se bomo piggybackali na kaosu. Morda bo toliko klanja, da ne bo noben opazil.
Eh, sanja svinja kukuruz.
Sicer pa ruse se hitro ustavi. Rečeš ukrajini, da naj jim časti ta jugo-vzhodni del. Začnemo kupovati nazaj plin in zahtevamo, da se permanentno umaknejo na šenkano mejo. Ukrajina mora vedet, da jo je napadla druga država in da žrtve bodo tako ali drugače.
To kar se sedaj dogaja pomeni, da se mi borimo za celovitost ukrajinskega teritorija. Redko so se države v zgodovini tako vneto bojevale za tuje ozemlje. Ukrajini lahko komot prodamo poceni oržoje kot znak dobre volje, lahko jih tudi inštruiramo in celo pomagamo pri obveščevalni. Ampak, da bomo scuzali lastne države zanje, pa no go. Tega še nobena država ni počela za nekega daljnega soseda.
Argument, da če ne, bi putin napadel Poljsko al neki je BS. Njegovi tanki prej porjavijo do tam, kaj šele da bi se bojevali.
Jaz ne vidim razloga zakaj ne kupujemo njegov plin če ga rabimo. Ukrajina naj bo vesela, da ji toliko šenkavamo, ampak zmrzovali pa ne bomo zaradi njih, sorči.
Samo kaj moremo, če smo postavili sovražnike za naše politike
https://twitter.com/ivan_8848/status/15...
To je sovražnik nemškega naroda, žal.
"no matter what my German voters think"
Počasi bo pač treba pobrskat kje ima deda še tisto shranjen revolver
cias ::
Dober odgovor, kaj si vzel še en robček. Ker Rusija dela točno to kar si trdil da je samomor ob rekornih dobičkih za Ruska energetska podjetja.
Verjetmo bi bilo ceneje, če bi najprej podarila cca 36 mijard $ pomoči ukrajini ali še bolje odkupila za 100 mijard ukrajisnkih duš in jih naselila
doma. Bi bilo ceneje kot ena zima ob zaprti ruski pipci.
PM says Sweden is facing the prospect of a ‘war winter’ due to an energy crunch amid the Russia-Ukraine war.
Sweden has said it would provide several hundred billion dollars in liquidity guarantees to Nordic and Baltic energy companies to avert a financial crisis sparked by Russia’s Gazprom shutting the Nord Stream 1 gas pipeline.
- spremenil: Mr.B ()
nirburu ::
Hmm.
V deželah kjer je veliko migrantov, najbrž bodo imeli kar polne roke dela. Namreč oni se bodo združevali v preživetvene skupine. Torej kriminalna dejanja.
Glih apokalipse ne pričakujem. Bi pa vseeno rad videl odstranjeno glavo kakega globohomo levičarja.
Levičarji so isto kot vamp.
Ko so časi dobri se razrastejo in eventuelno zboliš z nečim.
- spremenilo: nirburu ()
Zanimivo, da ti ob vsem tem domnevnem 'znanju' ni potegnilo, da identitetne agende (LGBTXY+, prepoved splava ipd.) ne furajo levičarji temveč liberalci in konservativci. Oboji z enakim namenom, da plebs ne bi preveč razmišljal o tem zakaj celo življenje gara kot suženj za drobtine, ne glede na to ali je bel, črn, rumen, Američan, Nemec, Anglež, ateist, kristjan, musliman, straight, gay, lezbijka itn.
Hmm.
Bs,
Zakaj misliš da je /da ni dogovor v smislu da Putin spušča ladje z žitom v vse te Afriške države. A misliš ko svojo fatalno zgrešeno nedodelano tezo lastnih OPIC spišeš umotvor , da imaš sploh širino dojemanja kaj se dogaja. Verjetno res ne misliš da so kompanije socialnih medijev to tisti pravi viri informacij.
cias ::
Rusi s Kitajci se kar trudijo nahranit Afriko, sploh od kar se Afrika zelo trudi otresti Zahoda. Naši pa se zelo trudijo preprečiti da ta hrana pride tja. Se bojijo večanja vpliva v Afriki pa, a sploh še kdo lahko zanika, hočejo celo Afriko preseliti v Evropo.
nirburu ::
Dobro ja. Sem malo poenostavil. Pač globohomo elita, leva in desna. Itak konzervativcev v naših deželah nimamo več.
V bistu o tem pa niti nisem razmišljal. Ker destabilizacija v afriki bi predvsem koristila majhnemu Ameriškemu igralcu v tej regiji.
Kdo potem nabija o prepovedi splava in podobnem?
Levica je za enake pravice brez celotnega identitetnega šita, ki je bolj kot ne pesek v oči.
- spremenilo: Fritz ()
Ne moreš vzeti za vzor Ameriško demokracijo, kjer nekateri na forumu bi raje živeli pod ameriškim sistemom. No nihče pri sposobnosti pisane besede 200 znakov, si takega sistema ne želi.
Možakar pravi, da v Sloveniji ni konservativcev. Kaj pa so potem tisti krogi, ki zagovarjajo prepoved splava in kdo so (bili) tisti ljudje, ki so nekaj protestirali pred stavbo porodnišnice?
Printing press :
Helge Haugane, Equinor's senior vice president for gas and power, told Reuters that in Europe excluding Britain, the total of such margin calls was probably more than 1.5 trillion euros, squeezing market liquidity and leaving a number of small- and medium-sized firms struggling.
Sklepam da je tu mišljeno TUDI sobvencioniranje omejitve cene energentov za gospodinstva. D
Reycis ::
Jaz se ne strinjam s tem, da Ukrajini rečemo karkoli. Napaka je že v osnovi bila, da se jim je sploh dajalo kakršnekoli obljube. Še vedno so si sami krivi, ker 1: so jim verjeli in 2: so si izvolili žida za predsednika. Proti Rusom pa bi bilo potrebno voditi enako politiko kot od 2014 dalje.
Od (ruskega) plina je potrebno iti stran. Na sploh moramo biti sposobni avtarkije, trgovanje se uporablja samo tam kjer majhna izmenjava doprinese ogromno ekonomsko korist. Nikakor pa nobene odvisnosti od izmenjave.
Sicer pa kljub temu, da imava različne poglede na tole "krizo" se strinjava, da je fake oz. zrežirana. Tako, da je tole debatiranje dejansko čisto mimo. Ampak jaz še vedno trdim, da je ta kriza dobra za nas in našo dolgoročno prihodnost in da se bo na koncu vse dobro izteklo.
Printing press :
Človek, ki je sposoben le update server ja, se zime lahko boji, človek ki si zna nacepit 2m bukovine je lahko brez skrbi, sedaj pa malo pofilozofiraj na 200 znakov.
Printing press :
Ja bošček how how, kaj si moral spet sinonim zamenjati da si svojo patetiko stresal v drugi temi. Kaj so te spet patetično vrgli admini iz sekret teme, pa nimaš druge možnosti socializacije. Ja revček, moraš biti res patetičen da producira tako skropucalo od protiargumenta zahodnmega vira ki ni del socialno medijskega poneumljanja. JE pa tvoje izrazoslovje da si ravno malo več kot 200 znakov, lep obraz tvojega mentalnega stanje, in nek dosežek katerim bi se hvalil kot argument, ravno ni. Da si ravno lahko opravičiš napisano, ker si pač uporabil več kot 200 znakov in tvoja koncentracija pisne kulture, tega enostavno ne premore. Patetično.
Printing press :
Sem te čakal! :D 200 znakov pa da si windowse updatal! :D haha nobeden me ni kam vrgel! če boš ti zmrznil druge ne straši! :D
nirburu ::
Koliko od njih predstavlja resno politično opcijo? Bolj malo, vsaj na zahodu.
hbgqzR ::
Samo test, ce mi to kaksna avtomatika brise ali pa je JPD forumsko nezazelen (prav dol mi visi za te vase persone ali blokade, dajte si duska!)
Jože P. Damijan blog
A tega ne smem pisati, ker je vzel kredit v CHF?
Ali zato, ker ga je dr. Mencinger pohvalil, ko je postal keynesianec?
Ali zato, ker je bil voditelj KULa (ali kaj)?
Je karkoli od tega sporno?
Je redni profesor na Ekonomski fakulteti Univerze v Ljubljani. Oktobra 2020 so ga opozicijske stranke LMŠ, SD, Levica in SAB evidentirale kot mandatarja tehnične vlade Koalicija ustavnega loka, a se je nato umaknil Karlu Erjavcu. Njegova poročna priča je bil Drago Kos.
- spremenilo: hbgqzR ()
cias ::
Hungary imposes heating limit
The Hungarian government has introduced an 18C temperature limit in public institutions as the EU grapples with an energy crisis
Dvomim, da te katera avtomatika briše.
Sporno je to, da se obrača po vetru in da je teoretik, ki vsem drugim pametuje. Sicer napiše kdaj tudi kaj pametnega, kaj dobro analizira, če bi ostal pri tem, mislim, da ga bi marsikdo rad bral. Ko pa začne pisat svoje mnenje...hja, tu ga pa dostikrat biksa.
Identitetna vprašanja gonijo liberalci (LGBTQ+ ipd.) in konzervativci (prepoved splava ipd.), kar je odokativno 90% političnih strank na zahodu. Je pa razlika med Evropo in ZDA, da neumnosti kot je prepoved splava v Evropi težje padejo na plodna tla. Tisti leviičarji, ki se primarno ukvarjajo z identitetnimi vprašanji so fake levičarji. Po Blairovi 'tretji poti' oz. premiku levih strank proti centru in še malo čez, je večina socialdemokratskih strank v Evropi prešla na desni pol, vključno z našo SD. Zato pa so se v praznini na levem polu pojavile nove leve stranke kot so Levica, Die Linke, Podemos ipd.
Liberalci in konservativci so desnica (za tiste, ki jim to ni jasno).
Če preveč spremljaš ameriški splet, so liberalci in fašisti levica, kar je seveda čisto in namerno zavajanje, kljub temu, da pojma levica in desnica nista absolutna. Fašizem je skrajno desno, komunizem je skrajno levo.
nirburu ::
V ZDA niso zares prepovedali splava. Ena ali dve zvezni državi morda, ostali pa ne. Ampak ok. Ta leva desna paradigma ne deluje več dobro.
In tam skrajno levo in skrajno desno si običajno podata roko =)
Kar se pa tiče slike politics 101 je pa tako zavajajoča, če nekdo prebere tisto, je vedno raje levičar, ampak resnica je dosti drugačna
Počakajmo po kongresnih volitvah, koliko jih bo do božička.
Tracking the States Where Abortion Is Now Banned
Most abortions are now banned in at least 12 states as laws restricting the procedure take effect following the Supreme Court’s decision to overturn Roe v. Wade. An additional two states now ban abortion at about six weeks of pregnancy, before many women know they are pregnant.
In many states the fight over abortion access is still taking place in courtrooms, where advocates have sued to block enforcement of laws that restrict the procedure.
Seveda, zato se južni in severni pol stikata, anede
Seveda, zato se južni in severni pol stikata, anede![]()
To je bolj Vzhod in zahod
Aja, potem se Portugalska in Japonska stikata, anede?
Vsakdo lahko zine kakšno neumno ampak vztrajati pri njej je pa že višja stopnja.
cias ::
Hm, na tole bi se splačalo vreči en uč tudi pri nas, ker je potencialno lahko pomembno na našem koncu:
https://www.euronews.com/next/2022/09/0...
... ampak podobno kot pri elektrarnah bodo verjetno Nemci pač malo zrahljali eko zahteve, po mojem bo ta zimska sezona res (tragi)komedija.
Canada says it will freeze the bank accounts of 'Freedom Convoy'
China's Village Bank Collapses Could Cause Dangerous Contagion
China: The Henan Bank Run and the Mass' Struggle against Tyranny and Crisis
V Libanonu obupani varčevalci "ropajo" banke.
Vedno več je takih naslovov..
Mislim, da obstaja možnost, da v hudi likvidnostni krizi tudi državne garancije na depozite odpovedo in naša sredstva niso več naša, ker jih ni.
What could happen, will happen :)
- spremenilo: redtech ()
nirburu ::
Za to je že inštrument uveden v celi EU.
Ampak ne skrbi. 2000 ščurkovih kalorij je povsem dovolj, da te ohranja pri življenju.
OSLO, Sept 12 (Reuters) - Norway and the European Union have agreed to a closer dialogue on proposals to resolve Europe's energy crisis, Norwegian Prime Minister Jonas Gahr Stoere said on Monday following a telephone meeting with European Commission President Ursula von der Leyen.
"We're going into the talks with an open mind but are sceptical towards a maximum price on natural gas," Stoere said in a statement. "A maximum price would not solve the fundamental problem, which is that there is too little gas in Europe."
They can't print energy. Reši se kdor se more :)
@nirburu dokler nam naciji ne predpišejo diete 180kcal bomo preživeli... 2k je požrtija :)
cias ::
Uranium price soars due to power supply crisis
Uranium has rallied to a 10-year high as the European energy crisis sparks bullish betting on nuclear power.
Bizkit45 ::
[url=https://file.si/5o45/uranium.jpg][img]h...
niti tretjino od ath ni.
- spremenilo: Bizkit45 ()
hbgqzR ::
Naučite se lepiti slike ali boljše, dajte povezavo na gibanje cene v različnih časovnih okvirjih. Vas dronyx ni še ničesar naučil?
Cias iz nekega, verjetno mazohističnega, razloga večinoma navaja neumnosti.
| » | Snowden postal ruski državljan (strani: 1 2 3 4 )Oddelek: Novice / NWO | 43543 (37407) | l0g1t3ch |
| ⊘ | Sankcije proti Rusiji in učinki za Evropo (energenti) (strani: 1 2 3 4 … 9 10 11 12 )Oddelek: Loža | 121373 (109506) | starfotr |
| ⊘ | Konec dobave ruskega plina ali ko pustimo vladati ženski (strani: 1 2 )Oddelek: Loža | 19976 (18780) | Griffin R500 |
| ⊘ | Kakšne opcije ima Rusija da nam zagreni življenje? (strani: 1 2 3 4 … 47 48 49 50 )Oddelek: Loža | 361314 (288023) | endelin |
| » | Priprave na predčasno priključitev Ukrajine v evropsko električno omrežje (strani: 1 2 3 4 )Oddelek: Novice / Znanost in tehnologija | 48052 (39747) | Mr.B |
