Forum » Loža » Kje prodajajo pri nas vitamin D2 oz. varnost "ebay recnij"?
bajsibajsi ::
Torej, kje pri nas prodajajo vitamin D2? Ne, v fizicni lekarni se nisem vprasal.
Zdravila in prehranske dodatke nerad kupujem preko ebaya. So pa relativno ugodne cene. Je https://www.ebay.co.uk/itm/Vitamin-D2-1... legit? Oxford vitality site deluje ok.
Erik39 ::
Vitamin D3 je boljši od D2. D3 pa se dobi v vsaki trgovini z športno prehrano.
Vir: https://www.healthline.com/nutrition/vi...
Vitamin D3 Is More Effective at Improving Vitamin D Status
Vitamin D2 and D3 are not equal when it comes to raising your vitamin D status.
Both are effectively absorbed into the bloodstream. However, the liver metabolizes them differently.
The liver metabolizes vitamin D2 into 25-hydroxyvitamin D2 and vitamin D3 into 25-hydroxyvitamin D3. These two compounds are collectively known as calcifediol.
Calcifediol is the main circulating form of vitamin D, and its blood levels reflect your body's stores of this nutrient.
For this reason, your health care provider can estimate your vitamin D status by measuring your levels of calcifediol (6Trusted Source).
However, vitamin D2 seems to yield less calcifediol than an equal amount of vitamin D3.
Most studies show that vitamin D3 is more effective than vitamin D2 at raising blood levels of calcifediol (7Trusted Source, 8Trusted Source).
For example, one study in 32 older women found that a single dose of vitamin D3 was nearly twice as effective as vitamin D2 at raising calcifediol levels (9Trusted Source).
If you are taking vitamin D supplements, consider choosing vitamin D3.
Summary
Vitamin D3 appears to be better than D2 at improving vitamin D status.
- spremenil: Erik39 ()
D3 samo trenutno so akcije zanič. Moda bo na začetku tedna kaj bolje?
https://si.myprotein.com/sports-nutriti...
Sc0ut ::
Kot je zgoraj napisal, kupi od Krke. So vsaj preverjene surovine, od proizvajalcev z nekim standardom. Pri food supplementih nikoli ne vec katero cungalungo lahko dobis.
Hvala za info
Ne komplicirajo pri teh zadevah. Itak ima večina folka pomanjkanje vitamina D. Tako, da 3 kapljice na dan te rešijo težav.
Zdravila na recept preverjeno vsebujejo točno količino učinkovin. Medtem ko prehranska dopolnila so bolj tako tako, ni nujno, da vsebuje tisto, kar piše.
Zdaj lahko buzerirate osebne zdravnike, da vam pišejo recept vsak mesec za kaplice(uradno niste upravičeni brez razloga). Lahko pa greste direkt v lekarno, skeširate 15EUR in nabavite 60 tablet od krke, ki zadoščajo za dva meseca. Takrat ko je sončno itak ne rabite vzet in grete raje ven na sprehod, tako da vam bo zadostovalo za tri mesece.
- spremenil: Magic1 ()
Če dobiš na bel recept, je 10 eur za pol leta. S tem da je to res to.
Oh, za kaj vse buzerirajo dohtarje. S tem enim receptom pa preprečiš marsikaj. Če bi vsi jemali vitamin D, bi bilo dosti manj obiskov zdravnikov, ki so velikokrat neupravičeni, samo zaradi npr. bolniške ipd.
Ta varjanta na bel recept je ok. Oleovit imaš res za pol leta primerljive količine Krkinim tabletam.
bajsibajsi je izjavil:
Zakaj zelis D2? biolosko aktiven je D3.
Pokličeš dohtarja in naj ti predpiše Oleovit na recept.
To! Te preverjeno delujejo. Sem jemal OCT vitamin D. Krvni test je kljub temu pokazal pomankanje. Pri Olevitu sem cutil ucinek.
- spremenilo: tikitoki ()
bajsibajsi ::
15 postov, pa nobenega odgovora. :)
Predvidevam, da pri nas sploh ne prodajajo D2. Zanimivo, saj je D2 cenejsi za proizvodnjo kot D3. Bom narocil iz tujine.
@tikitoki
Tudi ce ni v prosti obliki bo v telesu izkoristek dovoljsen; zlasti ob tako visoki koncentraciji. Na dolgi rok je to verjetno celo bolje (bolj varno). Prav tako ga ne zelim jemati redno, zelim da mi sluzi komplementarno.
@tikitoki
Massacra ::
@tikitoki
Jaz že leta naročujem pri tej firmi v USA:
https://www.swansonvitamins.com/q?kw=D3
Pa ne samo D3. Naroči nas vedno več skupaj, da pridemo do 150€ (skupaj s poštnino UPS ali DHL), carina je 9.5% (na vrednost do 150€, nad to mejo je 22%).
Pride nekje v 2 tednih.
Cene pa so NEKAJKRAT nižje, kot pri nas! Da o cenah v lekarnah in drogerijah ne govorim (recimo, NAC, pri nas poznan kot Fluimukan, je 10x cenejši, kot v naših lekarnah)
Master_Yoda ::
Jaz narocujem te pri iherb. Imas tudi klasicne cenejse npr. te. Postnina okoli 5 dolarjev, narocim pa za pod 22. Samo bo tega heca konec nazalost drugo leto.
22% davek in stroski carinjenja so ce vrednost presega 22 EUR. Pri 150 EUR se pa se potem carini zraven. Tako da za 150 EUR paket bi moral vseeno placati 22% davka ce je izven eu.
Dovie'andi se tovya sagain.
- spremenil: Master_Yoda ()
Massacra ::
Master_Yoda je izjavil:
Pa ne samo D3. Naroči nas vedno več skupaj, da pridemo do 150EUR (skupaj s poštnino UPS ali DHL), carina je 9.5% (na vrednost do 150EUR, nad to mejo je 22%).
Ti poskeniram zadnji račun in dam link do carinske uprave, kjer so razložene carine?
https://ibb.co/X8378Rr
- spremenilo: Massacra ()
Mihal01 ::
Vitaminversand24
https://vitaminversand24.com
5000 iu D3 (Vit4ever), Artikelnummer: vit4-037,
K2 MK-7 200 mcg (Daily Essentials), Artikelnummer: de-010
K2 MK-7 'transportira' kalcij v kosti, zobe, ... - da ni
kalcifikacije ozilja zaradi povisane doze D3 ... (v Reddit
iskalnik se vpise D3 K2 MK-7 ... in se v zvezi s tem dobi
vec informacij).
vec informacij).
Korak do konca in Naprej :).
- spremenilo: Mihal01 ()
Horas ::
je težko poguglat?
https://www.maxximumshop.si/vitamin-d
jaz imam taprve...
maxximum ma ceneje
jaz imam taprve...
60 tablet po 1000mg za 14€ od Tovarne Krka
https://www.moja-lekarna.com/vitamin-d3...
maxximum ma ceneje
- spremenil: Horas ()
Kvinta ::
Idi na Iherb pa tam kupi vse je 3x bolj poceni kot v Slo in Eu pošta pride v cirka 10 dnevih poštnina je 2,5€ v 7 letih od kar sem se mi ni zgubila še niti ena pošiljka.
A.C.A.B
Master_Yoda ::
No ok, te pa je 9.5% ker izgleda prehranski dodatki padejo v nizjo - sem popravljen. Ampak to se vedno ni carina, ampak davek. Carina je nad 150 EUR.
Poglej sem na furs tabelo.
Prehranska dopolnila imajo 12.8 carine, ter 9.5 davka. Torej bi placal 12.8% carine ce bi nad 150 vzel. Davka pa je 9.5% ja.
6151 ::
Pol ure na sonce pa ni opcija?
Pol ure na soncu, razen če nag (površina kože izpostavljene soncu je pomembna!) ležiš nekje zunaj ob 12:00 v tem času ne bo kaj dosti pomagalo.
7900X3D | 32GB | 6800 | 4 TB
harvey ::
Od oktobra pa tam do marca je malo premalo, smo žal na takšni legi.
Samael ::
je težko poguglat?
jaz imam taprve...
Ni težko, ampak vseeno težje, kot zgolj prebrati, kaj dejansko išče, pa ti to vseeno predstavlja težave ;-)
D2 je vitamin rastlinskega izvora. Bo zdaj šlo?
Samael != Samuel
Samael ::
10,000iu, to je 250mcg, na linku je prevelika dnevna doza tudi če vzameš v poštev, da so nekoliko manj učinkoviti kot D3, kjer je za odraslo osebo nekako normalna dnevna doza 20 mcg, maksimalna pa recimo 100 mcg.
Raje najdi nekaj v smislu 2000IU (50 µg oz. mcg), pa lahko še vseeno kakšen dan preskočiš.
Samael != Samuel
bajsibajsi ::
Ja, linkan D2 ima res visoko koncentracijo. V bistvu to niti naj ne bi bilo slabo, ce bi lahko eno tableto razdelil na vec kosov. :) Potemtakem je cena sploh ekstremno ugodna (~9 eur za malo pakiranje) glede na kolicino. Po drugi strani pa spet ni smiselno, saj bi imel potem eno "tamalo" vrecko (120 pilul) teoreticno za celo leto oz. celo za vec let. Po nekaterih studijah pa D vitamin scasoma izgublja svoje lastnosti; naj ne bi bil dolgo obstojen.
edit/
Slovenska studija D3 v povezavi s COVID. PDF file: https://www.kclj.si/dokumenti/FINAL_30....
edit/
- spremenilo: bajsibajsi ()
Samael ::
IL_DIAVOLO je izjavil:
Vitamini v tabletah so BS.
Zgolj zato, ker ne veš, kaj je vitamin D in kako ga pridobiš. V tem obdobju so BS zgolj če si na sončni strani poloble. A si? Ali pa boš trdil, da se po 4 ure na dan te dni nastavljaš soncu v Sloveniji? :)
Samael != Samuel
Massacra ::
Pa saj sem pripopal printscreen dajatev, ki mi jih je zaračunala država SLO.
Še enkrat: do 150€ je carina=9,5% (kot davek).
Nad 150€ pa je še teh 12,8% dodatka, kar znese nekje 22%
bosmla ::
Moras vedati da 1000 i. e. NI 1g ampak pri Vitaminu D: 40 IU (i.e.) = 1 μg (torej 1000 i. e. = 25 µg/l)
6151 ::
Priporočam: Valens D3 pršilo, 2000IU/dan, 10,90€ v lekarni za 125 dni.
harvey ::
Aktualen zapis o vit D na 24ur.com
https://www.24ur.com/novice/slovenija/v...
Siuka vsem, ki vitamina ne bodo dobili na zeleni recept, svetuje, da preverijo cene in odmerke in izberejo tistega, ki je najcenejši oziroma naj pogledajo, da dobijo čim več za čim manj denarja. Formulacija pa pri tem ni pomembna (ali tablete, kapsule, pršilo ali kapljice) in naj se ne pustijo zavajati, poudarja.
V Lekarni Ljubljana odgovarjajo, da se je prodaja prehranskih dopolnil, ki vsebujejo vitamin D, in zdravil brez recepta z vitaminom D v letošnjem letu (od januarja do oktobra) glede na isto obdobje lanskega leta v povprečju povečala za 95 odstotkov. Izjemno povečanje prodaje pa so zaznali v zadnjem mesecu. Pravijo, da se stranke najpogosteje odločajo za zdravila brez recepta in prehranska dopolnila v obliki tablet ali kapsul. Za tiste, ki jim taka oblika ne ustreza, pa svetujejo pršila ali dopolnila v tekoči obliki. Tudi izdaja zdravil na recept se je povečala.
Kot dodajajo, se pri nekaterih proizvajalcih oziroma dobaviteljih pojavljajo težave z dobavljivostjo, saj zaradi velikega povečanja povpraševanja v zadnjem času ne zmorejo zagotoviti zadostnih količin. V Lekarni Ljubljana pravijo, da so zaloge za vse oblike vitamina D, ki so dobavljive, povečali v skladu s povečanim povpraševanjem.
Siuka pa ob tem apelira na vse lekarne in prodajalce, da ne podražijo vitamina v teh časih, ker bi bilo to nadvse neetično in bi spadalo v kategorijo vojnega dobičkarstva. Ob tem pa še enkrat poudarja, kako pomembno je pravočasno dodajanje. S tem bi namreč na eni strani lahko preprečevali stopnjevanje kritičnega poteka bolezni (to je dokazala tudi randomizirana španska študija iz Cordobe) in na drugi strani morebitni kolaps zdravstvenega sistema v kratkem času in tako preprečili italijanski scenarij in ogromno kolateralno škodo.
ivi ::
Jaz ga že 2 leti kupujem tukaj: https://www.bulk.com/eu/vitamin-d3-tabl... Preverjeno dobri in 1 pakiranje zadostuje za 3 mesece (90 tablet). Na dom pridejo v cca 2-5 dneh. Poreklo pa je iz EU. In še nekaj, pri teh zadevah vedno preverite koncentracijo samega vitamina, ne vsebujejo vsi enakih vrednosti.
Verjetno pretiravaš, če jemlješ to vsak dan pol leta. Te količine so v normalnih okoliščinah za na dva dni.
Naceloma nimam pojma, kaj je kateri vitamin, ker itak jem vse od zelenjave, sadja do vsega kar ima kost in kozo :)
Ce jes vse, nimas kaj komplicirat z dopolnili, ker dobiš vse potrebne minerale.
4 ure sonca na dan na stajerskem koncu, kjer nas razdajajo s soncem, pa tudi ni nic redkega :)
Čeprav je ze 15 minut dovolj :P
Badwolff ::
preber si kej ;)
sicer verjetnost, da ti bo kot mlademu moškemu kaj zaradi pomnjknja ni prav velika
Kdaj pa so bile tablete dobre? Je neki začetni efekt oz. placebo efekt, ampak to ni resitev. Vse vitamine je treba dobiti po naravni poti.
To je vse lobi zdravstva. Veste koliko se tega proda? Vec kot aspirina! :)
Pa se sploh nisem prišel do kolagena in to premium!
Samael ::
No, saj o tem govorim - napisal si veliko neumnost.
Najbrž si predvideval, da tudi ta vitamin v zadostnih količinah pridobiš iz svežega sadja in zelenjave, kar seveda ni res, sicer ne bi zapisal tiste neumnosti. Prav vseeno je kaj ješ, z D vitaminom to nima kaj dosti veze, razen če se vsak dan filaš z lososom. A se? :)
D vitamin je "sončni" vitamin in se akumulira zgolj za kratek čas. In če je poleti dovolj kakšnih 15 minut izpostavljenosti zmernemu soncu, je za zadostno količino tega vitamina v jesensko/zimskem letem času potrebno cca 4 ure nastavljanja soncu dnevno. In ker najbrž pozimi ne skačeš vsak dan po soncu 4 polne ure, pa ker si pozimi na prostem oblečen kot medo, pa ker tudi vsak dan ni sončen, ti tega vitamina v mesecih, ki prihajajo, skoraj gotovo primankuje. Ja?
No, sveže sadje in zelenjavo pa le jej.
Samael != Samuel
Z jajci in tuno pa se. Ja, ravnokar guglal, nisem vedel :P
Imam rajsi malo manj vitamina, kot pa strup v krvi :)
- spremenil: IL_DIAVOLO ()
| » | Prehranski dodatki (strani: 1 2 3 )Oddelek: Loža | 33498 (12765) | itonlineai |
| » | Podpora imunskemu sistemuOddelek: Loža | 4552 (3878) | vostok_1 |
| » | Prehranska dopolnila (strani: 1 2 3 )Oddelek: Loža | 37299 (33703) | kakob |
