Nizozemska in Spanija odpoklicale korona testerje in maske iz Kitajske
sheeshkar ::
vostok_1 je izjavil:
Če spremeniš parametre sredi merjenja lahko dokažeš karkoli. Če dovolj znižaš CT vrednost bo ob porastu hospitalizacij okužbe ostale nizke.
Zato pa skrivajo vsi parametre katere so uporabljali.
Kakšen dokaz, ali si kot ponavadi vse potegnil iz riti?
Kako je možno, da so med poletjem PCR testi kazali mnogo manj okuženih, če pa so dokazano povsem nezanesljivi?
Odgovor: SVETOVNA ZAROTA!!!
Če smo že prispeli v "zono somraka" - ali pri tej zaroti sodelujejo vsi, ki testirajo? Samo šefi, ki jim na skrivaj spremenijo parametre? Billy lastoročno hodi po zonah testiranja?
Urbano#Desno ::
sheeshkar je izjavil:
Na tisoče in tisoče ljudi se je zmenilo in delujejo usklajeno. Eni prirejajo teste, drugi usklajeno vozijo zdrave ljudi v bolnice, tretji ponarajajo mrliške liste i.t.d. Potrebno je samo še ugotoviti kako da imamo nek porast smrti ki je usklajen s porastom pozitivnih testov in hospitalizacij.
V vsej tej operaciji se seveda ne najde nihče ki bi zadevo sabotiral oziroma sčvekal pa vemo da sta pri zadevah ki morajo ostati tajne že dva preveč.
Tko da costok, coolbits samo :))
https://www.thelancet.com/journals/lanc...
It has become clear that a hard lockdown does not protect old and frail people living in care homes--a population the lockdown was designed to protect.3 Neither does it decrease mortality from COVID-19, which is evident when comparing the UK's experience with that of other European countries.
PCR testing and some straightforward assumptions indicate that, as of April 29, 2020, more than half a million people in Stockholm county, Sweden, which is about 20–25% of the population, have been infected (Hansson D, Swedish Public Health Agency, personal communication). 98–99% of these people are probably unaware or uncertain of having had the infection; they either had symptoms that were severe, but not severe enough for them to go to a hospital and get tested, or no symptoms at all. Serology testing is now supporting these assumptions.4
These facts have led me to the following conclusions. Everyone will be exposed to severe acute respiratory syndrome coronavirus 2, and most people will become infected. COVID-19 is spreading like wildfire in all countries, but we do not see it—it almost always spreads from younger people with no or weak symptoms to other people who will also have mild symptoms. This is the real pandemic, but it goes on beneath the surface, and is probably at its peak now in many European countries. There is very little we can do to prevent this spread: a lockdown might delay severe cases for a while, but once restrictions are eased, cases will reappear. I expect that when we count the number of deaths from COVID-19 in each country in 1 year from now, the figures will be similar, regardless of measures taken.
Lockdown: Collateral Damage in the War on COVID-19
https://architectsforsocialhousing.co.u...
Zanimivo branje.
Prehudo zdravilo.
  • spremenilo: sbawe64 ()
vostok_1 ::
Spremeniš Ct in imaš takoj manj okuženih. Trivialno.
Če pa ne poznaš PCR postopka pa lahko pogovor kar zaključimo.
sbawe64 je izjavil:
Zanimivo branje.
Prehudo zdravilo.
Štej sekunde kako bodo pro-koronarji povsem ignorirali izsledke.
There will be chutes!
It came from the lab.
  • spremenil: vostok_1 ()
vostok_1 ::
Sicer pa ne vem še kdo verjame tem korona-bedakom.
Iz dneva v dan se demantira njihovo pozicijo. Edino kar jih rešuje je koruptivna vlada, ki napihuje pandemijo. V resnici če prenehamo z histerijo gremo nazaj na bolj ali manj normalno zimo, morda kak žur manj in to je to.
Urbano#Desno ::
Ne motiš vas dejansko niti ni potrebno demantirati, je vsakemu jasno na kako nerealnih temeljih so vaše pravljice.
Ste zgolj poceni zabava.:D
sheeshkar ::
Ok, ampak kdo vse je udeležen v to? Vsi, ki testirajo? Samo njihovi šefi, ki to naredijo brez vednosti podrejenih? Kako to poteka?
vostok_1 ::
@šeškar
Hkrati pa se padanje/rast detektiranih okužb s temi nezanesljivimi testi zelo ujema s padanjem/rastjo hospitalizacij?
Je to tako težko razložiti?
Trivialno razložit. Poleti odredi Gantar ali kdorkoli, da zadeve niso kritične in se zniža Ct. V hladnih obdobjih rečeš, da moramo zaščititi vsakega in se poviša Ct.
Nobene globoke zarote, do katere bi se morali po James Bond načinu dokopati.
Vsaj na začetku je WHO vem da dajal navodila tudi za Ct value. Poglejte stare zapise, smo že linkali. Nek strokovnjak je reku, da sledijo WHO priporočilom. Govorim pol leta nazaj.
Ko smo uradno povprašali naše strokovnjake Ct vrednost po mesecih, so se delali francoze.
Urbano#Desno ::
Edino kar je pozabil da potrebno še hospitalizacije sinhronizirati z Ct številom.
Drugače pa se meni se sliši kar verjetna razlaga:))
Na mikrobiološkem inštitutu imajo verjetno poseben mail, kjer dnevno dobijo navodila kako nastavit mašine za teste.
vostok_1 ::
Gledam covid sledilnik.
Hospitalizacije načeloma pojenjajo aktivni primeri pa ravna črta.
To bi bil lahko morda bil znak antigen testov s slabo zanesljivostjo.
Ampak tega v resnici ni še nihče razložil. Ok, lažem, Vostok je podal looney tunes razlago, kjer so v zaroto spreminjanja ciklov vključeni vsi zdravstveni delavci, ki opravljajo PCR teste (predvidevam po celem svetu). Če je to vaš odgovor, potem resnično prosim za omenjeno literaturo in povezave, ki to dokazujejo.
~šeškar
Ti si certificiran bedak.
Razlaga je povsem enostavna in realna.
In ja, to delajo po celem svetu kjer ima WHO in podobni kriminalci svoje lovke.
Urbano#Desno ::
Kot velikemu razkrivalcu zarot ti branje trivialnih grafov dela težave?
To bi razložilo marsikaj
Hospitalizacije namreč še vedno rahlo rastejo oziroma bi lahko tudi rekli da so kolikor toliko konstantne, kar bi ustrezalo konstanti pri okuženih.
Si predstavljaš kakšna jeba je vse to sinhronizirat z nastavljenim Ct številom. :))
Ti kot prvo ne ločiš med pozitivnimi na pcr testu (brez simptomov), onimi pozitivnimi z opaznimi simptomi gripe/korone in onimi hospitaliziranimi.
Če rečemo da je korona sestra gripe, in pogledamo interval ponavljanja je jasno, da se (bo) oboje pojavljalo v vremensko neugodnih mesecih, ie. zima/jesen, vsako leto zapored.
https://apps.who.int/flumart/Default?Re...
Slo za 2010-2020
Cepljenje proti gripi poteka že od 1930 (svet) oz 1945 Zda, a je to početje kot kaže boj z mlini na veter.
https://twitter.com/_InThisTogether/sta...
Pandemije se vozijo po voznem redu kot avtobusi, vsako leto pride nova....
Urbano#Desno ::
Kolega tonete vse globlje ni več daleč dan ko se vam bojo tudi krave smejale.:))
V resnici tudi ne vemo koliko ljudi je končalo na intenzivni ki v resnici niso bili covidovci, ampak bolehali z nečem drugim.
Saj kisik ti ne dajo zgolj in samo za covid.
Saj v bistvu je vseeno. Zdravila itak ni, "karantenski" ukrepi pa učinkujejo na vse nalezljive bolezni. Epidemije in ukrepov nimamo zaradi virusa XXXX, ampak zaradi tega, ker ljudje zbolevajo in umirajo. Znanost nam sedaj omogoča, da prepoznamo točnega povzročitelja, ampak to je samo dodaten bonus. Tudi brez tega bi imeli enake ukrepe.
Karanteno so ljudje poznali že v srednjem veku, ko sem jim sanjalo ni, kaj povzroča bolezni. Še celo cepivo bi verjetno slej ko prej znali narediti, ne da bi vedeli, kaj točno povzroča bolezen. Proti črnim kozam so cepili že v 18. stoletju (in še prej), ko sploh niso vedeli, da virusi obstajajo.
sheeshkar ::
Trivialno razložit.
Se strinjam, iz riti potegniti "argumente" je res trivialno. :))
Poleti odredi Gantar ali kdorkoli, da zadeve niso kritične in se zniža Ct. V hladnih obdobjih rečeš, da moramo zaščititi vsakega in se poviša Ct. Nobene globoke zarote, do katere bi se morali po James Bond načinu dokopati.
Če ni globoke zarote, potem ti ne bo problem pokazati, da se je spomladi in danes delalo po drugačnih ciklih kot med poletjem?
Link prosim.
Ne, to je samo znak, da ne testirajo dovolj, in v enaki meri ves čas. Število aktivnih je v dobršni meri povezano s številom testov, ne zgolj s številom dejansko okuženih. Število ljudi v bolnici je pa povezano samo s številom okuženih, nanj število testov ne vpliva nič.
NIJZ šteje samo teste PCR, ne antigenskih in drugih hitrih testov.
  • spremenil: Okapi ()
sheeshkar
Link prosim.
Tu imaš Who 'smernice'
https://slo-tech.com/forum/t762973/p693...
In taiste 'smernice' je za Who postavil glavni nemški virolog profesor Christian Drosten s svojim pcr testom https://slo-tech.com/forum/t773723/p693... .
On 21/01/2020 (3 days before the first publication by the CCDC!) WHO recommended that all nations apply the testing method developed by Professor Drosten. Professor Drosten triggered and caused the growth and globalisation of the Chinese epidemic panic, with the claim that he had developed a reliable test process for the rapidly spreading virus in China, by not observing the clearly prescribed rules of scientific work, and by violating the laws of logic and the logic of virology, which are an integral part of his employment contract.
ajdov ::
Okapi je izjavil:
Karantena ne vpliva na število mrtvih, ampak jih samo porazdeli po daljšem časovnem intervalu.
ajdov je izjavil:
Ja, na koncu vsi umremo, genij.
Nobena bolezen na dolgi rok ne zviša števila mrtvih. Skrajšajo pa povprečno starost.
Tako danes kot pred 500 leti so vsi ljudje slej ko prej umrli. Samo da danes umirajo pri 80, pred 500 leti so pa pri 40 letih.
Karantena zagotovi, da nalezljiva bolezen manj skrajša povprečno življenjsko dobo. In to je tisto, kar hočemo doseči.
sheeshkar ::
sbawe64 je izjavil:
Debato smo danes začeli, ker sem rekel, da so najbolj pomembne številke hospitaliziranih, vse ostalo (vključno s PCR testi) je manj pomembno. Ti in tvoji somišljeniki od takrat izvajate vse mogoče akrobacije, da bi dokazali nasprotno, a sedaj sem jaz tisti, ki ne loči med PCR testi in hospitaliziranimi? :))
sbawe64 je izjavil:
Ja, to je jasno vsem. Kar vam ni jasno je to, da PCR testi v teh mesecih nekaj zaznavajo (pa zavoljo debatiranja s koronazanikovalci pustimo ob strani kaj točno zaznajo), poleti pa ne, torej očitno niso povsem nezanesljivi. Še več, rast okuženih se ujema s posledično rastjo hopitalizacij, torej so dovolj zanesljivi, da si z njimi lahko pomagamo, tudi če niso 100% (česar nihče nikoli ni trdil).
CoolBits ::
Stevilo hospitaliziranih bo treba najprej nedvomno dokazat. Tej vladi ni za verjet popolnoma nic vec.
Urbano#Desno ::
CoolBits je izjavil:
hehe kako ste luštno naivni
Torej sedaj jih imamo praktično v vseh bolnišnicah torej je v oskrbo teh bolnikov udeleženo ogromno ljudi in ponovno nobenega leaka da nekaj ne štima. Ne od medicinskega kadra, ne od raznih čistilk strežnic .., ne od bolnikov samih, ne od njihovih družin. Tale billy pa res fajn plačuje.:))
Saj to vostoka že ves čas sprašujemo, kdo je tisti, ki zdravnikom pri nas ukazuje, da v bolnišnicah na ventilator priklapljajo v bistvu zdrave ljudi, samo zato, da je videti, kot da imamo neko epidemijo. Kako to, da nihče od zdravnikov tega ne prizna. S čim jih vse ustrahujejo?
CoolBits ::
Who daje smernice, to je jasno. Zdravnike pa v bistvu placujejo zavarovalnice in s tem tudi lahko dajejo navodila.
Ce ne upostevajo smernic pa jim grozi odpoved in odvzem licence.
  • spremenil: CoolBits ()
sheeshkar ::
sbawe64 je izjavil:
sheeshkar
Link prosim.
Sem pregledal linke. Kje točno naj bi pisalo, da se je število zaznanih okužb med poletjem zmanjšalo zaradi spremenjenih smernic testiranja (in sedaj ponovno naraslo, predvidoma zaradi ponovno spremenjenih smernic)? Pa še enkrat, kako točno to vpliva na hospitalizacije, ki v tej sezoni (kljub strogim ukrepom!) podirajo vse rekorde in smo šele na koncu novembra?
Glede vaših Twitter in podobnih virov pa tole:
Fact check: Inventor of method used to test for COVID-19 didn’t say it can’t be used in virus detection
Urbano#Desno ::
Okapi je izjavil:
Doh, trivialno razložiti :))
zdraniki so na rednih billy čekih, bolniki pa dobijo dnevnice ena tarifa za enostavno hospitalizacijo in druga za ventilator.
/s
CoolBits ::
sbawe64 je izjavil:
sheeshkar
Link prosim.
To je enostavno laz.
sheeshkar ::
CoolBits ::
vostok_1 ::
Smo uradno povprašali organe. Podatkov ni oz. se izogibajo. Vrjamem, da si spregledal večkrat objavljene papirje.
Link prosim.
Vrjamem, da si gladko ignoriral sbaweja, ki ti je podal referenco.
Ni zastonj, da ti pravim certificiran bedak.
Okapi je izjavil:
Vse res.
Ampak umirajo v majhnem številu, in kot so ti linkali na grafih zgoraj, jih umira več zaradi lockdowna kot virusa.
Skratka, potegnite glavo vn iz riti in prekleto že spreglejte bullšit, ki ga propagirate.
Urbano#Desno ::
Kdo ste vi? V primeru da so vprašanje zastavljena v stilu kot pišete tu na slo-tech lahko upravičeno domnevamo da so sklepali da jih kolega pranka :Din so vas ignorirali. Nihče jim ne more zamerit.
vostok_1 ::
Okapi je izjavil:
Če ni dovolj navodilo, da moramo pojačati zdravljenje "za namene reševanja slehernika", pomagajo tudi finančne spodbude
https://www.dailywire.com/news/yes-hosp...
Kot ti je rekel in pokazal CoolBits, lažeš kot certificiran bedak.
vostok_1 ::
sbawe spet v akciji
https://www.bankofcanada.ca/wp-content/...
Jaz upam, da spektatorji, ki berejo to in ono temo razumejo, da to ni teorija zarote. To je prva prava, jasna, dokumentirana globalna zarota.
Od Okapija in podobnih sicer ne računam, da bodo spredvideli, enostavno nočejo. 30+ let vrjamejo v svoj model sveta, nikakor, da bi ga kdo spremenil.
Računam pa da druga publika ni tako zavedena in je bolj pozorna.
stroj66684 ::
sbawe64 je izjavil:
sheeshkar
Link prosim.
Očitno še ne razumeš. Hitro kaj pravi fact check . Streljaš prazne naboje
sheeshkar ::
Ali ti je zmanjkalo tudi namišljenih argumentov, da se moraš tako pogosto zatekati k žaljivkam?
Daj raje povej, kdo vse sodeluje v tej PCR prevari... So v njo vključeni čisto vsi zaposleni ali samo šefi? Do katerega nivoja gre zarota? Varnostnik na informacijah ve, da mora brez vprašanj v stavbo spustiti može v črnem?
vostok_1 ::
Povedali, pokazali in obrazložili smo ti vse.
Žalil pa te bom as i see fit oz. do takrat ko se boš delal totalnega bedaka.
Prej ko nehaš, prej te bom vsaj poskusil vzeti resno.
Urbano#Desno ::
ajdov ::
Okapi je izjavil:
ajdov je izjavil:
Žrtve korone so v povprečju starejše od pričakovane življenjske dobe torej to ni res
stroj66684 je izjavil:
sbawe64 je izjavil:
sheeshkar
Link prosim.
UK NHS uporablja Ct = 45 pri pcr (stran 22).
Če je to gold standard za pcr diagnostiko, potem sem jaz kitajski Cesar.
Reuters 'fact checker' gor ali dol.
vostok_1 ::
FW iz sosednje teme:
https://maribor24.si/slovenija/video-na...
Distopija ki so jo najnižje gliste tipa imagodei omogočili.
Okapi, ti še imaš čas to renounce your false gods. Repent.
stroj66684 ::
sbawe64 je izjavil:
sbawe64 je izjavil:
sheeshkar
Link prosim.
Kaj to leti name? Vsekakor se strinjam, da je Ct=45 preveč. Pač po WHO smernicami. V reuterfact check so iztrgali iz koneksta tisti citat.
vostok_1 ::
Mogoče pa bo to tudi pozitivno.
GenX in Milenijske generacije, ki so jih popolnoma skopili bodo nadomestile bolj uporniške generacije.
Smrt fašizmu, svoboda narodu.
https://www.facebook.com/virusuporazavs...
Brings tears of joy to my eyes.
Hard times breed hard men.
Upam, da uspe.
sheeshkar ::
Ja, kavč uporniki bodo naredili prevrat z razbijanjem tipkovnic in žaljenjem po obskurnih forumih. Viva la revolucion! :))
Kaj pa vsi svetovni mediji? Zakaj prav nihče ne razišče te prevare stoletja in moramo o tem brati na portalih David Ickea? So prav tako podkupljeni s strani Billyja?
Pa koliko denarja je ta človek že zapravil in to zato, da bo potem "mastno" zaslužil... s cepivi... :))
vostok_1 ::
Skratka potrjuješ, da si bedak in te lahko zavoljo privarčevanja živcev, zlahka ignoriramo?
Deal.
sheeshkar ::
Deal.
Ti kar, saj je ta tema tvoj peskovnik. ;((
vostok_1 ::
Done.
Publika, poglejte sosednjo temo in sbawejev zadnji post
https://www.mmnews.de/politik/154204-bu...
To ni borba proti virusu. To je borba proti ljudem.
Kot nam že celo leto govorijo, Dark Winter.
Tudi če virus pojenja, moramo ljudi demoralizirat za prihajajoči reset.
Ima še kdo dvome?
sheeshkar ::
Tud jst mam eno teorijo zarote - Vostok in sbawe sta ena in ista oseba...
Dokazov nimam, ker jih v tej temi ne maramo. Sklepam po izredno podobnem stilu pisanja in sposobnosti produciranja več kot treh idiotizmov na minuto. :))
vostok_1 ::
https://mobile.twitter.com/Max46023367/...
"Only 7% of tests will be succesful identyfing those who have the virus" ~uk minister
Kot rečeno. Zaključimo že enkrat. Vzpostavimo nazaj sodišče v Nurembergu in dosodimo vsem odgovornim.
To postaja že polnopravni kriminalni scam na globalnem nivoju.
vostok_1 ::
V glavnem, nihče ne pravi, da ni mogoče slepariti, tako ali drugače. To, kar taki, kot sta vidva z vostokom, ne znate pojasnit, je, kdo daje te ukaze, da po vsem svetu zdravniki in zaposleni v laboratorjih sleparijo. Kdo vse te tisoče ljudi tako ustrahuje (ali podkupuje), da ni še niti enega žvišgača, ki bi povedal, kdo mu je ukazal, da je treba ponarejati rezultate testov in v bolnice sprejemati zdrave ljudi in jim dajati lažno diagnozo korone.
~Okapi
A tudi ti si šel po poti bedakov Okapi?
Sem te cenil bolj kot to, pa zgleda da...
ajdov je izjavil:
Okapi je izjavil:
ajdov je izjavil:
:)):)):)) Še en genij, ki ne zna do tri računati. Ti sploh ne bom razlagal, kakšno neumnost si prijavil, ker itak ne bi razumel.
~Okapi
Kdo daje te ukaze, da po vsem svetu zdravniki sleparijo, pa vseeno ne znaš povedati, ne?
22 / 45
Ali remdesivir pomaga pri covidu-19? WHO pravi ne, FDA ga je potrdil (strani: 1 2 3 )
12132330 (28202) Uporabnik
Sodisce razveljavilo nekatere korona ukrepe (strani: 1 2 3 4 … 10 11 12 13 )
624111543 (101283) dexterboy
sezona gripe 750 hospitaliziranih, Zdaj zarad Covid pa 200 in panika (strani: 1 2 3 4 5 )
Statistika in COVID-19 (strani: 1 2 3 4 … 31 32 33 34 )
1663229613 (202623) BigWhale
