Forum » Programiranje » UTF-8 in Python
UTF-8 in Python
dunda ::
Tole je del kode:
Ta vrag deluje v Python 2. Sedaj pa zadevo selim v Python 3 in dobim napako:
Kaj se je spremenilo v prehodu iz Python2 na Python3? In kako naj laik reši problem?
.... list_of_files = glob.glob(potSlik + 'Ko*.jpg') latest_file = max(list_of_files, key=os.path.getctime) checksum1 = hashlib.md5(open(latest_file).read()).hexdigest() ....
Traceback (most recent call last):
File "/home/user/webcam/webcam-ko.py", line 72, in <module>
checksum1 = hashlib.md5(open(latest_file).read()).encode("utf-8").hexdigest()
File "/usr/lib/python3.6/codecs.py", line 321, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xff in position 0: invalid start byte
https://www.kacnje.eu
infiniteLoop ::
Ker jpg ni besedilo, ga moras odpreti kot binary file.
Potem bi moralo delati na trojki. Kako pa bi uredil da bi zadeva delala na 2 in 3 pa ne vem na pamet, bi moral iti guglat.
checksum1 = hashlib.md5(open(latest_file, mode='br').read()).hexdigest()
None of us is as dumb as all of us.
infiniteLoop ::
No evo sem poguglal, ce hoces, da zadeva dela v 2 in 3, moras uvoziti open iz io, potem se oba obnasata kot trojka.
from io import open #... checksum1 = hashlib.md5(open(latest_file, mode='br').read()).hexdigest()
dunda ::
Uf, hvala.
Zadošča mi, da deluje v 3ki. Ko bom vse prestavil na 3ko, bo delovalo tam.
HotBurek ::
Jst imam tako, da uporabim str.encode(), da string spremenim v byte:
Pa uporabim hashlib.sha512()
checksum1 = hashlib.md5( str.encode( open(latest_file).read() ) ).hexdigest()
root@debian:/# iptraf-ng
Please resize your window
- spremenilo: HotBurek ()
infiniteLoop ::
Upam, da me ne boste smatrali za dlakocepa, ampak to bi delovalo samo za text file, jpg moras se vedno prebrati kot binary.
HotBurek ::
Nekaj je na tem, ja.
Jst imam tak setup, da ločim, kdaj berem text, kdaj pa slike (bajte). In potem pri branju uporabim "r" ali "rb".
file = open(path + "/favicon.ico", "rb"); content = file.read(); file.close();
| » | [Python] HTTPS na desktopu dela, na Arduinu neOddelek: Programiranje | 1978 (1591) | N4g4c3N |
| » | Komuniciranje med PHP in pythonOddelek: Programiranje | 1688 (1420) | filips |
| » | Java skeniranje map in podmapOddelek: Programiranje | 1634 (1523) | nightrage |
| » | Generator enkratih geselOddelek: Programiranje | 1283 (1116) | fiction |
| » | Razbijanje gesel z GPU je realnost (strani: 1 2 3 )Oddelek: Novice / Varnost | 41746 (36177) | MrStein |
