Disk za življenje
Disk za življenje
2
poweroff ::
Lahko tudi - če uveljavljaš garancijo, te ustrelijo. :))
sudo poweroff
M.B. ::
Pol maš še pa Backblaze $0.005 na GB na mesec za storage pa $0.01 mna GB za download, pa za 99$ ti lahko USB ključ z do 256GB tvojih podatkov pošljejo, če ključ vrneš dobiš dnar nazaj. AWS GLacier je sicer cenejši $0.004 per GB / Month ampak plačaš pa $0.09 per GB za download + request . Ker je to pač namenjeno kot Backup backupa. Še Primerjava. Še ena možnost pa je Tarsnap:
Tarsnap uses a prepaid model based on actual usage:
Storage: 250 picodollars / byte-month of encoded data
($0.25 / GB-month)
Bandwidth: 250 picodollars / byte of encoded data
($0.25 / GB)
"Encoded data" are the actual bytes stored or transmitted after data deduplication, compression, and encryption.
Še primer kaj dela deduplikacija
Here's an example of hourly backup #24584 of the entire hard disk of one of the tarsnap.com servers:
This server has almost three years' worth of hourly snapshots, which add up to a total of 96,492 GB. But after duplicate blocks of data are removed (or more precisely, only stored once), that drops to 56.1 GB, which is then compressed to 15.8 GB -- an amount which costs $3.95/month to store.
By contrast, here's backup #32 of personal email and documents, which are run "almost every month":
Total size Compressed size
All archives 14304559063 10709002903
(unique data) 961452556 673438434
This archive 526692949 388934283
New data 2308253 359832
This computer is only backing up half a gigabyte; the sum of all the snapshots would give 14,305 MB (email accumulates over time). But thanks to deduplication, these snapshots can be reproduced with only 961 MB, which is further compressed to 673 MB, which costs $0.17/month to store.
Sam večkrat razmišljam da bi blo nujno neki cloud backup met, ampak se potem spomnim da mam 2MBit uploada, kar pomeni da bi vsak upload trajal sto let. Mogoče kdaj vzmamem HOT večji paket pa preko LTE uploadam, ker je tam večji upload kot pa na kabelski. Živel napredek.
TheBlueOne ::
Narocis office 365, kjer je vsteto 1tb OneDrive za ca 40€/leto in imas podatke dejansko na varnem mestu v oblaku.
Nikonja je izjavil:
Res je obstojen, ampak je še vedno DVD, in samo ena praska ga lahko uniči.
No, to mora biti orenk praska, ni treba pretiravati.
Je pa res, da se eni slabši DVD kar sami razkrojijo v nekaj letih.
Nikonja je izjavil:
P.S. Imam v starem rač. disk od 60GB star že cca 14 let in še vedno dela, brez napak na njem.
Ja, bi trebalo pogledati ta video kaj sploh bluzi.
"pravi, da se lahko diski HDD neuporabni po 10letih."
No, lahko so neuporabni tudi takoj, ko iz škatle vzameš. Tako da na nek trolovsko/filozofski način drži tisto o 10 letih...
Glede optičnih medijev, imam par posnetih CD-R iz 1997 in še vedno delajo brez težav (nazadnje preveril nekje lani, zgolj iz radovednosti, kako dolgo bodo OK).
iloveboobz je izjavil:
lahko ja, lahko ne. SSD mora imet funkcijo v kontrolerju, da prepisuje podatke, kjer so le ti ze izgubil charge.
Novejši TLC/QLC ssdji to počnejo, usb kjučki npr, pa tega _ne_ počnejo, tako da ti to nič ne koristi
Hmm, imam tole
https://www.heise.de/preisvergleich/eu/... iz leta 2006. Gor razni "mali backupi" (kaj več na 1GB itak ne gre), ki so se nabrali skozi leta, pa še nisem opazil, da bi kaj zmanjkalo.
Je pa res to naprava nad razredom "dobiš zraven pralnega praška".
  • spremenil: MrStein ()
Heisenberg je izjavil:
Prosim samo še za info ali bostaja kak program za backup, ki bi se sam zadnal ko bi se priključil zuzanji backup disk in sinhroniziral datoteke na disku v PCju? Ter po možnosti da bi ostajala še možnost gesla da bi vse skupaj zaklenil ?
Si prepričan, da se boš 10 let pozneje spomnil, kako geslo si uporabil?
blackbfm ::
to da "ni zmanjkalo" nič ne pomeni, preverit bi blo treba hash prej/potem
Večina fajlov je z builtin hashem, nisem začetnik.
TOP ::
TheBlueOne je izjavil:
Najbolj varno je na več lokacij skopirat in to je to.Tole z oblaki je pa,kot je že nekdo reku server lahko,kar ugasnejo ali pa ne boš moral dostopat,ker bodo pokrali gesla,kot se je že velikokrat zgodilo.
@Heisenberge, File History v Windows 10 se vklopi pod Setting/Update & Security/Backup prva opcija. Klikneš add drive in izbereš nek zunanji disk in viola, vsi user folderji(documets, pictures, desktop,...) se backupirajo, pod dodatne opcije lahko spreminjaš kaj se backupira:
https://www.pcworld.com/article/2974385...
Steinkauz ::
Js predlagam tole (tudi sam uporabljam že 2 leti):
https://www.pcloud.com/cloud-storage-pr...
https://www.pcloud.com/welcome-to-pclou... (če hočeš zastonj sprobat 1 mesec premium)
Torej maš 2TB disk + cloud.
Če kirokol crkne zamenjaš.
Da bi oboje naenkrat ckrnlo je precej malo verjetno.
MIHAc27 ::
Kot že rečeno je tak medij kar teško najti, ki bi zdržal 30, 40 let in bil enostaven za uporabo. Če imaš srečo lahko en navaden usb ključek toliko preživi. Če imaš smolo bo crknil ko ga boš hotel uporabiti.
Smo že imeli primer gospoda, ki je imel backup na trakovih. Problem 1: Najti bralno enoto. Ena je bila v Nemčiji, drugo smo našli v muzeju. Problem 2: Zapisano je bilo še z Unix sistemom. Najti sedaj nekoga, ki ga še pozna.
Za res varno kopijo je treba zato uporabit različne medije. Lahko je to 1 kopija na HDD, druga na DVD. Ali pa USB, ki se ga 1x letno posodobi.
Cloud je tudi dobra izbira, če seveda ni edina. Tudi veliki imajo izpade, in takrat lahko odleti tudi 100+ diskov naenkrat.
M.B. ::
Piql podatke shrani za vedno v Svalbardu, zraven banke semen. So pa napisani kot QR kode na posebni filmski trak. Baje zdrži 1000let+ v solnem rudniku. Ni pa še za posameznike na voljo zaenkrat.
poweroff ::
1000 let... toliko še država ne zdrži, kaj šele neka firma, ki naj bi hranila podatke...
sudo poweroff
SmeskoSnezak ::
Kateri je preverjena zadeva, ki zdrzi najdlje do sedaj? Izvzamimo trakove in stare kasete. In kako dolgo dejansko zdrzi in zadrzi podatke?
@ Pusti soncu v srce... @
SmeskoSnezak je izjavil:
Na metersko palico vrežeš ulomek, ki v desetiškem zapisu vsebuje vse, kar želiš zapisati.
  • predlagal izbris: MrStein ()
poweroff ::
Ti bom povedal kako to delajo arhivi podatkov. Recimo ADP. Podatke hranijo na različnih medijih, na različnih potresnih območjih (ali vsaj različnih stavbah, če je požar). Potem pa na roko vsake toliko časa pregledajo in presnamejo na novejše medije. Se pravi, najprej iz disket na CDje, potem na SSD-je, itd. Predvsem so se pa naučili, da morajo biti zadeve shranjene v odprtih formatih.
sudo poweroff
Ahim ::
Najdlje dokazano zdrzi naravni pigment (iz zemlje oz. razlicnih kamnin) nanesen na kamen, zaprt v kaki jami. Manj obiskovalcev in klimatskih naprav ima jama, dlje zdrzi backup.
Neprimerljivo manj kot to, a vseeno dokazano nekajkrat dlje kot hipoteticno neki M-disc in rudnik soli s QR kodami na filmskem traku pod Spitsbergi pa seveda zdrzi karkoli vklesano v kamen, po moznosti spet shranjeno nekje kamor bi dal tudi svoje DVDje/HDDje/DAT/fotoalbum/karkoli je ze bilo omenjenega v tej temi.
All hail IBM technical support!
Ahim je izjavil:
Zanima me, koliko jam je bilo v paleolitiku, ki jih danes sploh ni več.
poweroff ::
Paleolitic cloud service 8-)
sudo poweroff
SmeskoSnezak ::
Hvala na razumevanju :)
NOT.
A ni govora o novejsih tehnoloskih zapisnih metodologijah? Vsaj OP je zacel s tem, kolikor sem razumel.
kakob ::
ajfon je izjavil:
kupiš 3x ssd, zapečeš identične kopije..
SSDji so približno najslabša možnost za shranjevanje podatkov.
Never take a financial advice from someone who works for a living.
Uros!no ::
Upam, da ne mislite da so USB ključki večni :)
  • spremenil: Uros!no ()
Jst ::
Ko so bili USB ključki 16-32-64MB sem spisal program, ki je low level od začetka do konca obračal bite. Znova in znova. In sem zelo rad razne ključke, ki so jih talali po konferencah, sejmih, mučil/uničeval s tem programom. Vsi so crknili - kar je bil namen. Škoda pa, da nimam "live*" dostopa do tabele, ki sem jo izpolnjeval po uničenju ključka. Ne vem, če je kakšen zdržal več kot teden dni.
*Z besedo live mislim to, da imam nekje backup.
Drugače pa mi je pred novim letom USB 32GB Super-Najboljši-Najdražji Sandisk umrl. Gor so bili samo razni certifikati in osebni podatki tekstovne oblike a v Truecrypt kontejnerjih. Za mogoče par mega. Tako da ni bil dosti prepisovan. Stran od USB ključkov, nikoli niso bili dobri in pri njih ni "na-pol-začne-crkovati". Ali dela ali je umrl.
Uros!no je izjavil:
5-10 let data retencije za kjučke je _zelo_ optimistično dandanes :)
Han ::
Super-Najboljši-Najdražji Sandisk pa je bil?
A da diskete držijo dvakrat dlje kot CD? No ja, na to vpliva kar nekaj faktorjev, recimo:
- kvaliteta medija (TDK in Traxdata versus Smartbuy in noname)
- kvaliteta zapisa (32x na noname pogonu versus 4x na Plextor-ju)
- način hrambe (na polici v avtu vs priporočeno okolje)
Ta zadnji stavek me je spomnil, da imam dejansko ducat CD-jev v avtu že ohoho let, bom jih testiral ob prvi priložnosti.
Jst ::
Pojdi na Amazon. Nimam pokopališča. :)
Drugače pa ene 60-70 EUR (lani spomladi, USB 3).
2
M -Disc
484234 (3305) _Sajmon_
10 let star CD in disk
194826 (4316) [D]emon
Uporaba USB ključev ali SD kartic kot backup?
329373 (8623) energetik
Nov domala večen način zapisa podatkov (strani: 1 2 )
6726949 (23531) vostok_1
Nova anketa: je DVD/Blu ray enota (že) odveč? (strani: 1 2 3 )
Oddelek: Novice / Ostalo
10043544 (41016) kuglvinkl
