Izguba omreznega diska
SmeskoSnezak ::
A je kdo dozivel, da izgubi Mapped Drive zaradi kaksnega Win 10 Update-a?
Ali pa da izgubi povezavo do Mapped Drive, ker je iz brezzicnega preklopil na kabl/mrezo?
@ Pusti soncu v srce... @
SmeskoSnezak ::
Zakaj tocno bi Mapped Drive izgubil povezavo? Da se X pojavi na disku, in ne mores dostopati do njega? Kaj bi lahko preveril?
Ali pa da izgine iz File Explorerja?
Uporabnisko ime in geslo je pravilno. Da bi pa stalno moral "disconnect" narediti in/ali "map drive", pa tudi nima smisla. Vsak nasvet je dobrodosel.
SmeskoSnezak ::
VPN izgleda , da je povezan, ampak povezava pada. Internet in vse ostalo dela brez tezav. Bi ta error pomagal pri resevanju tezave?
The system failed to register host (A or AAAA) resource records (RRs) for network adapter
with settings:
Adapter Name : {997AC6B0-6AB2-4BEE-8A5B-B20262A01EB4}
Host Name : PC08
Primary Domain Suffix : domain
DNS server list :
dns_IP
Sent update to server : server_IP
IP Address(es) :
IP
The reason the system could not register these RRs was because of a security related problem. The cause of this could be (a) your computer does not have permissions to register and update the specific DNS domain name set for this adapter, or (b) there might have been a problem negotiating valid credentials with the DNS server during the processing of the update request.
You can manually retry DNS registration of the network adapter and its settings by typing 'ipconfig /registerdns' at the command prompt. If problems still persist, contact your DNS server or network systems administrator. See event details for specific error code information.
ToniT ::
Preberi tole!
Pomaga...
SmeskoSnezak ::
A to nardim na serverju, ce prav berem?
SmeskoSnezak ::
Server je 2012, preveril masine pa nisn nasel teh KB-jev na serverju ali na masini, kjer je Mapped Drive.
Nazadnje posodobitve na racunalniku s tezavo so:
KB4480116,
KB4483235,
KB4480056,
KB4480979.
ToniT ::
Če gre za server 2012, potem pozabi na zgornji link. Problem je nekje drugje...
VMware Player - DNS server zmešan
Oddelek: Programska oprema
226964 (6533) AndrejO
Windows 8.1 že na voljo za MSDN/TechNet
4412580 (8984) Jst
Računalniki se ne vidijo preko My network places
82442 (2303) BaRtMaN
Group Policy; kako nastavit GPO za OU?
Oddelek: Operacijski sistemi
383416 (3088) Microsoft
Računalnik ne registrira DNS-a?
Oddelek: Omrežja in internet
102142 (1912) Hojne
