Forum » Strojna oprema » NVIDIA Turing - Uvod v RTX
DamijanD ::
Tale druga izjava je pa malo hecna, AMD kartice za igranje iger so super, samo ne za igranje iger.
Vem ja
FlyingBee ::
Radeon je gaming first, tako da...
New Sphincter Kvartet:
FlyingBee ::
V Death Stranding dsll2.0 dela čudeže, pa je Decima engine console first pogon, ki na PCju dela tudi dobro in imajo Radeonke prednost, tako da bo sigurno tudi pri next gen to pomagalo, vendar:
In this review we also took a look at NVIDIA DLSS 2.0. Performance gains are huge, up to 50%, depending on the scene, yet visual quality is pretty much identical to native resolution rendering. This is a huge achievement for NVIDIA as it makes DLSS an important technology many game developers do not want to miss out on. Unlike the first generation of DLSS, DLSS 2.0 does not need any time-consuming and expensive game-specific training. Rather, one algorithm fits all. Effort required from game developers is minimal, all they have to do is feed the game's motion vectors to the NVIDIA API. Technically, DLSS 2.0 is an optimized temporal anti-aliasing algorithm, basically TAA on steroids. Machine learning is no longer used to solve the aliasing problem, but to solve the TAA history problem.
V tem videu lepo razlozi, zakaj so nvidioti tipa klinker, leteca cebela,... neumni, k noc;).
klinker ::
Po izidu big navija, bos mogoce celo dojel da si zabit bolj od kamna, pac, tipicen AMDtard
Senitel ::
Eh tale video zgreši kar nekaj zadev. Za začetek to za kolk bo Lisa Su pustila prodajat PS5 in Xbox Series X. Kaj piše na temle čipu?
AMD ne dela teh čipov in jih tudi ne prodaja. AMD proda IP SONY-u in Microsoft-u ki potem hendlata vse naprej. AMD dobi upfront $ za razvoj, potem, ko je zadeva končana dobijo samo še licenčnine, ki nimajo nikakršne veze s tem za kolk se SoC (oziroma cela konzola) prodaja. SONY in MS te konzole potem prodajata z zelo minimalnimi maržami, ker sta v biznisu prodaje iger in ne hardware-a per se.
Dodatno je pri teh novih konzolah težava za primerjavo s PC-ji to, da imajo dodaten hardware za dekompresijo direktno na GPU-ju. PS5 lahko streama podatke direkt v GPU memory in jih razpakira tam z namenskim hardware-om. Xbox Series X ima izboljšan "block compression" za teksture in jih bo dekodiral šele TMU znotraj GPU-ja. PC-ji trenutno še niso na istem nivoju.
Back from the dead I see.
- predlagal izbris: AapocalypseE ()
Kje je rekel ,da bo Lisa Su dolocila ceno PS5 oz. XBoxa?
Tvoje besede ne spremenijo dejstva, da zna imeti cist soliden p/w in zmogljivost. Kaj bodo spravili na trzisce in po kaksni ceni, bo pokazal cas.
Da ne bos dobil iste cene na PCju, je jasno vsem, ki niso retardirani. Konzole lahko prodajajo tudi pod proizvodnjo ceno, ker so glavni vir zasluzka storitve in igre in ne strojna oprema.
Damn, ce bi lahko jailbraku konzolo in gor nalozil Win10:).
- spremenilo: tikitoki ()
FlyingBee ::
Rdna2 grafične bodo itak pred konzolami in to bomo gledali.
mailer ::
Prava konzola bi imela vsaj pcie slot v katerega bi vrgel grafiko po želji in jo nadgrajeval po željah/potrebi. Ram pod 16GB sploh ni več vprašanje, procesorji pa tako niso največji problem konzol.
Furbo ::
Zakaj je sploh govora o konzolah?
A če bo AMD začel delati burek, bo tudi debata, kako je AMD razvil burek, nvidia pa caplja zadaj?
FlyingBee ::
Ker amd fanboyi spet vse upe v konzole dajejo, saj v PCju caplja preveč zadaj.
- spremenil: FlyingBee ()
Senitel ::
Na 18:40+ je rant, da Lisa Su ne bo pustila tega prodajat po 500$.
Tudi ne spremeni dejstva da primerjamo 2 leti star tech na PC-jih z brand new techom na konzolah. GPU za PS5 je performančno na nivoju 5700XT. Sprememba je RDNA2 vs. RDNA. Kolk bo to vplival na performance vs. kolk je novih feature-jev bomo pa vidl, ko pride RDNA2 na PC-je.
On je primerjal z xBox, ki ima konkretno mocnejsi graficni del. Bolj blizu RTX 2080 Ti, kot RX 5700. Vsaj po TFLOPS, kako se bo obneslo pri igrah, bomo se videli. Kar je spektakularno za konzolo in tud poraba je solidna, ce drzi, da bo napajlnik mel 350 W. Izboljsave zelo ocitno so.
Moje stalisce je itak bilo, da bo potrebno pocakati na recenzije. Nekateri pa ze slavijo zmago in primerjajo staro zelezo. Ti imas mogoce kaksne insajderske informacije.
Sicer pa je bil video namenjen tistim, ki tu utrujajo s svojimi fanbojevskimi izpadi.
Po čisti računski moči bo Ps5 gpu celo za 10% zmogljivejši od RX 5700XT. Če bodo obdržali enako razmerje teksturnih enot, rop-ov ter sp-jev na CU, potem se zaradi arhitekturnih izboljšav predvideva kaj 20% zmogljivejšega od rx 5700xt.
Za primerjavo, glede na Radeon VII so arhitekturne izboljšave prinesle tam 25%.
Če RDNA 2.0 prinese dodatnih 10% (RL performance / tflop), potem bo PS5 gpu kar v redu.
RT bo seveda ob primerni kvaliteti učinka deloval zaviralno, predvidevam, da bi lahko deloval pri 60fps @1080p.
AngelOfDeath ::
To bo pa spet zanimivo postalo.
Nvidija pričakuje da bo Big Navi cca 40-50% hitrejši od 2080TI...
AMD pa je tiho...
Upajmo da se Nvidia ne moti. Skrajni cas za malo konkurence.
AMD pa je tiho...
edit: Slovnica
- spremenil: AngelOfDeath ()
FlyingBee ::
kje si pa to pobral?
Glede na to, koliko casa se ze hypa glede big navija, se mi zdi, da je big navi samo smoke screen.
Neznane specifikacije, neznan launch date, neznana arhitektura, ampak amd fanboyi ze vsaj eno leto vedo, da je zadeva top shit. Jest tega fantomskega cipa ne jemljem resno. Se ko/ce kdaj pride v sprodajo, bom sel v trgovino pogledat, ce to res obstaja.
gmajna84 ::
Big navi je resnicen kot obstoj boga na zemlji
i7 8700K @ 5GHz|Intel UHD Graphics 630|16GB DDR4 3000MHz|
Asus Prime Z370 - A|NZXT Hale 90 v2 1000W 80+ Gold|
Corsair Carbide Air 540 White|Logitech G105 / G500 / Z623|
FlyingBee ::
Big Navi niti ni več pravi izraz, gre se za posodobljeno arch. RDNA2, naj bi bila pred konzolami predstavljena v obliki pc grafične, verjetno časovno okoli Geforce Ampera.
FlyingBee ::
https://www.techpowerup.com/270209/nvid...
Verjetno prevelik zalogaj za nvidio. Applu bi bila pa mala malica pa še na ARM prehajajo. Ali pa Amazon.
klinker ::
Imam obcutek da se bo Nvidia v naslednjih 5 letih posteno izstrelila naprej...pa ne v gamingu, ker tu se po moje drzijo nazaj. Zadnja leta enostavno razturajo na vec podrocjih.
FlyingBee ::
Ja, nakup Mellanoxa je znak, da gredo full in datacenter, AI,..., vseeno pa mislim, da bo Apple edini kupec, ker to pri SoftBank načrtujejo, saj je Apple zdaj primoran ARM vzet, da ne izgubijo licence ali pa jim nvidia ali kakšno drugo tehnološko podjetje le last gen prodaja.
FlyingBee ::
Zadnje čase pa samo Gainward RTX2080 TI Phoenix v malih oglasih
FlyingBee ::
Bolha v kategoriji Grafične kartice, skoraj vsaka druga 1080ti in vse nad 400eur. Sehr optimistisch?!
https://www.bolha.com/graficne-kartice
Furbo ::
Zakaj bi prodajali poceni, ko še ni nadomestka na trgu? Sploh pa imajo po nizkih cenah čas prodajati še vsaj pol leta.
Wrop ::
Cene bodo šle v roku enega meseca dol. In to kar precej dol. Lahko seveda čakajo, če se še najde kakšen kupec rabljenih kartic po teh oglaševanih cenah, ampak teh je res zelo zelo malo. Tudi kupci rabljenih si lahko privoščijo čakanje na nižje cene.
globoko grlo ::
Hehe itak, cakam 2080ti za 250 ojrov.
Furbo ::
In kupci takih kartic ne bodo prodali zdaj in naslednja 2 meseca trpeli simptome odvajanja od iger.
BT52 ::
Zdaj se vidi, da je bil Touring plačan beta test. Pričakovano, kot smo številni menili, da je DLSS prihodnost. Me je Ampere še bolj presenetil (čakamo na bench score). Seveda prvi vtis je impresiven. Folk prodaja 2080ti za 700 EUR LOOOOOL
- spremenilo: BT52 ()
GenZNPC ::
Jaz se v zadnjih 10 letih ne spomnim, da bi bil tak p/p skok v zgornjem koncu od niti enega proizvajalca.
AMPAK, vecina vas mesa tukaj RTX perf. gain z NonRT !!!
skibidi
FlyingBee ::
Daj ti raje na ZS napiši kdaj in za koliko mi lahko zrihtaš 3080!?
Nvidia je izvedla preemptive strike, saj jo vendar prvič po dolgem času ogrožata kar dva konkurenta.. AMD in prihodnje leto še Intel.. Sicer ne vem, kolk se bojijo enega in drugega, ampak so lepo preventivno zatrli odpor in lahko mirno spijo naslednji dve leti.
FlyingBee ::
Pizduni izdajo Turinga, ki ga večina folka popljuva, reviewerji dramatizirajo from villain to hero, market share pa že dolgo ne toliko visok. Svašta!
GenZNPC ::
Daj ti raje na ZS napiši kdaj in za koliko mi lahko zrihtaš 3080!?Pisi mi na ZS, ko jih bos zagledal
Cena 3070 je postavljena ob bok novim konzolam.
skibidi
- spremenil: GenZNPC ()
FlyingBee ::
Sem mislil, da imaš veze.
GenZNPC ::
Zdaj zaradi korone, te veze vec ne palijo. Mogoc kak popust edino lahk zrihtam, ce bo kaj pametnega. Pa ce ne zaupas Mailbox.de, postnina s sledenjem je 16 Eur.
skibidi
FlyingBee ::
Ne popust, 3080 fe za 700eur plus poštnina in še malo dodatka, še pred koncem septembra in bi bilo ok.
FlyingBee ::
Se mi je zdelo.
Na 3080 SUPER bo čakal leto dni. :)
GenZNPC ::
AapocalypseE je izjavil:
Its gonna be speacial. Mal vec rama, ornk hitrejsa. Prevelika luknja je med 30080 in 3090. Pa mogoce bo bolj zrel proizvodni proce pa to. Bi znala biti vredna dati malo vec.Nene, ti pocakaj na 3080 Super/Ti
Zakaj pa to?
980-980Ti
1080-1080Ti
skibidi
| » | AMD najavil Radeona RX 5700 XT (strani: 1 2 3 4 5 6 7 )Oddelek: Novice / Grafične kartice | 86962 (78399) | Mr.B |
| » | nakup grafične v letu 2019 (strani: 1 2 3 4 5 6 )Oddelek: Kaj kupiti | 69110 (62344) | Glugy |
| » | AMD Navi in EPYC 2 prispeta v tretjem četrtletju (strani: 1 2 3 )Oddelek: Novice / Rezultati | 26637 (24091) | Mr.B |
| » | Nvidia prinaša podporo DXR raytracingu na kartice GTX (strani: 1 2 3 )Oddelek: Novice / Grafične kartice | 38835 (35264) | Cange |
