Forum » Problemi človeštva » Oblikovanje vlade
Oblikovanje vlade
Goody ::
Ja če ne znaš brati je verjamem da problem. Organiziranost v barriosih ki je izrecno omenjena je recimo tudi del Chavezovega sistema.Ja, in kaj tocno je slabega glede demokraticne organizacije? Saj menda vemo da je do propada venezuele prislo zaradi skrajno skorumpiranega avtoritarnega sistema Chaveza/Madura, ne pa zaradi neke demokraticne mularije ne?
A)Kolektivno vodstvo in kolektivna odgovornost v praksi enostavno ne deluje - že n-tič dokazano.
B)Tako kot čisto vsak socialistični sistem v zgodovini do sedaj. Ampak Levica ve bolje ali ne.
zmaugy ::
Kdo je plačal letalske karte in bivanje?
SimplyMiha ::
The overall number of World War II casualties in Slovenia is estimated at 97,000. The number includes about 14,000 people who were killed or died for other war-related reasons immediately after the end of the war,[11][12] and the tiny Jewish community, which was nearly annihilated in the Holocaust.[13][12] In addition, tens of thousands of Slovenes left their homeland soon after the end of the war. Most of them settled in Argentina, Canada, Australia and in the United States.
The overall number of World War Two casualties in Slovenia is estimated to 89,000, while 14,000 people were killed immediately after the end of the war.[11] The overall number of World War II casualties in Slovenia was thus of around 7.2% of the pre-war population, which is above the Yugoslav average, and among the highest percentages in Europe.
Slovene Lands in World War II @ Wikipedia
Toliko o zgodovinskih dejstvih.
3p ::
Zgleda bo še Cerar stisnu pizdo...
https://siol.net/novice/volitve-2018/pi...
Ne nujno. Mogoče le dvomi v učinkovitost manjšinske vlade in pripravlja teren za snedenje lastne besede in večinsko vlado z Janšo.
Truga ::
Kdo je plačal letalske karte in bivanje?Bojda davkoplacevalci. Tako kot pri nas ko pride na obisk obummer/trumper.
A)Kolektivno vodstvo in kolektivna odgovornost v praksi enostavno ne deluje - že n-tič dokazano.Tole ste si pa mal zmisnli, guspot.
- spremenilo: Truga ()
Horejšio ::
Upam da jim ne uspe. Imamo krasno gospodarsko rast, ki se nam sicer ne pozna v denarnicah, sam ne morejo pa dodatno zajebat.
Mavrik ::
-- Dajte ne vleč ven domobrancev in partizanov. Smo že meli to pravilo. Hvala. --
(Pa dajte nehajte z osebnimi napadi - kar vkljčuje izjave tipa "vi levičarji/desničarji ..." )
- spremenil: Mavrik ()
Najbolša vlada za Slovenijo bi bila SDS + LMŠ + SMC in še mogoče NSI za bolj stabilno vlado z več glasovi.
3p ::
O tem se seveda ne strinjamo. Lahko pa se strinjamo, da bi bila najbrž bolj stabilna.
(Mogoče celo preveč stabilna.)
Saj smo to že imeli. Potem so se pa šli preimenovanja vojašnic, namesto reševanja resnejših težav, da bi na koncu popolnoma zgubili razsodnost, ker so ljudje protestirali proti njim naklonjenemu županu.
Je pa trenutna situacija še najboljša za Cerarja, da njegovi 'olastninijo' ali 'zasedejo' kar še lahko. Škoda, da ne moremo od politikov terjati odškodninske in kazenske odgovornosti, ker to kar počne Kolar-Celarčeva presega vse meje normalnega.
zmaugy ::
Kdo je plačal letalske karte in bivanje?Bojda davkoplacevalci. Tako kot pri nas ko pride na obisk obummer/trumper.A)Kolektivno vodstvo in kolektivna odgovornost v praksi enostavno ne deluje - že n-tič dokazano.Tole ste si pa mal zmisnli, guspot.
Kateri davkoplačevalci? Slovenski? Mislim da ne. A venezuelski? A preko Kickstarterja?
MonoPattern ::
A se kakšna stranka pri nas resno zavzema za zmanjšanje javnega sektorja in predpisov? Očitno se niso naučili, da je država bolj slaba pri vodstvu gospodarstva.
Kdo bi si misli da se Levica (Kordiš in Tomičeva) tako izrecno navdušujeta nad državnim kapitalizmom...Bos dal kak vir
Jao, je v temi https://siol.net/novice/slovenija/kako-... pa tudi na žalost levičarjev nimamo prav vsi volivci spomin zlate ribice in se še dobro spomnimo kako je Kordiš po tv hvalil venezuelsko revolucijo in za vse težave tam krivil tuji grdi imperialistični kapitalizem
Pa saj vse južno od ZDA - komplet kontinent - je pod kontrolo USA, ki je pod pretvezo demokracije dobesedno morila demokracije levo in desno ter na njihovo mesto postavljala diktature. Tiste države, ki se niso dale, so bile pa konstantno tarča terorističnih napadov. Hkrati pa vsaj v srednji ameriki poprečno bolj demokratične in napredne. Ali morda zanikaš te trivialno preverljive zgodovinske resnice?
Tako da je hinavsko ignorirati ta "grdi imperialistični kapitalizem", sploh če vidiš, kako se je USA spravljala na socialistične sosede s terorizmom (saj bi šli Vietnam style, pa se je raja uprla...).
Zdaj konkretno za Venezulo ne vem, a ko sem bral na strani Levice o Venezueli sem videl, da TOČNO vedo, kaj govorijo. Za razliko od tebe, ki pojma nimaš, kaj dejansko američani počnejo. No, nič kaj takega kar ne bi pred njimi počela katerakoli druga velesila, a dejstvo ostaja, da se gredo imperij in zadeva je brutalna, ker drugače ne more biti. In za to so se pač zavestno odločili dobrih 100 let nazaj.
Zdaj čisto verjamem, da je Venezuela greznica od države (ni bila ena od držav, katerih zdodovino sem bral). Saj ne more biti drugače. In nihče ne trdi, da levi sistemi niso skorumpirani. Samo a je tako težko zastopiti, da lahko tudi v skret državi dobiš dobre ideje. In konkretno se je iz povsem benigne opombe zdaj naredilo cel halo. Nihče ne zna povedati, zakaj je bila ona izjava tako grozna. Ves argument se poneumi na - bomo kot oni.
Truga ::
Najvecja ironija venezuele je, da kljub totalnim pajacom na vodilnih polozajih (ce vas zanima kako bi zgledala slovenija ko ima SDS vecino si samo predstavljajte Madurota ki nima nafte), jim ne gre tako slabo kot jim je slo pred Chavezom. Ne se, anyway. Zdaj bomo videli kako se bo odzvala svetovna skupnost na krizo v Venezueli. Ce se bo mednarodna pomoc pogojevala z ukinitvijo vsega dobrega skupaj z vsem slabim ki je prinesel chavinizem, potem bo venezuela kmalu spet v 19. stoletju.
zavajon ::
Hah! Se mi je kofe zaletu.
Dobra šala![]()
Ne vem, če je to le šala.
Sam sicer nisem še bil v Venezueli, a imam znanca, ki je tam živel pred Chavezom. In pravi, da takrat ni bil problem, da ni bilo elektrike za hladilnike, ampak to, da ni bilo kaj dati v hladilnike.
Možno. V tem primeru sta zanj dve varianti: ali totalna zmaga s tem, da PTTM izrine iz politike ker svojo participacijo pogojuje z njegovo upokojitvijo ali politična smrt, morda izgnanstvo.
PT se novih volitev ne boji. Postavljanje takih pogojev s strani LMŠ, SDS ne bo sprejela.
Odvisno od tega ali je stranka slepo zvesta PTTM ali ne. Kažejo že tako, izganjajo vse heretike ki vanj dvomijo, možnosti za to so šibke, a ni nemogoče, da bi bila stranka za.
Če pride do javne debate okoli tega jih zna letošnji slogan malo zbosti.
Če ponujenega ne sprejmejo je jasno, da ne gre za Slovenijo, ampak za PTTM. Seveda jim bo njihova volilna baza to laž mirno spregledala, saj se s tem strinjajo.
Še nekaj je, če gre Cerar v koalicijo s PTTM v načinu kamikaze jih tudi zna torpedirati. Če bodo na oblasti vsaj pol leta bo na naslednjih volitvah tistih 75% volivcev, ki imamo dvomestne IQ postalo vsaj malo mar za politiko, udeležba bo šla gor in naslednja dva volilna cikla bo ne-55-80 zopet zmagovalna. To ni dobro, ampak ker dovolimo glasovanje retardirancem je to morda še največ na kar upamo. PTTM ni večen, je na močnih zdravilih, čez dober mesec dni bo imel 60 let, zdravje ga bo nekoč izdalo. Z nekaj sreče bo to preden bo naredil še več škode.
- spremenil: Smrekar1 ()
rekt ::
Ja, to je težava z anekdotičnimi podatki in spominom. Tudi danes se bo v SLO našlo kup ljudi, ki ti bo trdilo, kako je bilo v jugi vse fino, danes nas pa štrafa vse, od nata do pomanjkanja WC papirja.
Na srečo imamo hard dato:
- Proizvodnja jekla je nižja kot leta 1980 1
- Enako tudi proizvodnja aluminija 2
- Število nasilnih smrti je več kot 5x večje kot leta 1999
- 93% venezuelčanov pravi da jim njihov dohodek ne omogoča nakupa hrane 3
- Venezuela je bila nekoč vzor borbe proti malariji, število primerov bolezni pa je danes za cca 15x višje kot leta 2000 4
- Januarja je bil preračunan povprečni dohodek cca. 8 dolarjev. Stroški za nujne osnovne potrebščine so ocenjeni na 130 dolarjev. To je bilo več kot pol leta nazaj - stanje je danes slabše 5
- Od začetka revolucije je emigriralo 4 miljone ljudi. Emigracija se še posebej močno povečuje zadnja leta 6
Če pa hočeš še anekdotične podatke, pa malo beri, kaj pravijo venezuelci sami. Država je po vseh (razen vladnih) kazalcih v totalni buli.
2
3
4
5
6
- spremenilo: rekt ()
je izjavil:
Smrekar, daj prosim, razloži mi te PTTM, 55-80 in ostale šifre.
PTTM = Princ TemeTM
PTTM (desno)
55-80 je oznaka njegove stranke, saj lepo popiše vsaj enega, praviloma dva atributa njegovih volivcev.
Reprezentativen volivec, ki izkazuje oba atributa.
Unknown_001 ::
SimplyMiha je izjavil:
Če gre zdaj za Slovenijo, a prej ni?
Tipična SDS.
V bistvu ima tist slogan point. Na vsakih volitvah gre za Slovenijo in njeno prihodnost.
So mi pa oni iz NSi bistveno bolj všeč. S temi se bo dalo kaj pametnega zmenit. Z jajotom ali mesečnikom pa čisto nič.
Begabt
Begabt
A ta Kovačič ima že 80 let? Jih ne kaže ;)
Prav daleč tudi ni, 77 jih šteje. No, star je 77 let, ne vem ali zna šteti do 77.
Številki sicer označujeta območje, v tem stilu:
54,9999 < x < 79,999
Kjer je x atribut, ki ga območje popisuje.
predvidevam, da iq in starost
Vsekakor obstaja razlog zakaj sta ti dve meji izbrani kot sta.
Vazelin ::
Za razliko od patetičnega smrekarja se je Vili izpostavil in že večkrat opozarjal na kriminalno rabote vodilnih.
Najprej TEŠ6 ... tudi takrat so ga imeli za norčka ... no, imel je prav. niti dvomim ne, da bo kriminal še večjih razsežnosti v primeru drugega tira. Ampak ja, dejmo se delat norca iz Vilija.Slovenija je narod hlapcev.
Postajaš dolgočasen, Smrekar. Ne vem a ti je mamo butal ali od kje takšno zaničevanje? Saj tip nima nobene moči odločanja ... vlado sestavlja Serpentinšek, ne Vili.
Državljanski aktivizem v sloveniji je itak označen za dno dna :)
- spremenilo: Vazelin ()
To je zgolj dokaz, da slepa kura zrno najde.
http://www.publishwall.si/vili.kovacic/...
Obramba se strinja, da je nekdo vstopil v hišo skozi nezakljenjeno klet, se pritihotapil mimo mame, ki je gledala televizijo, ustrelil hčer in se odtihotapil ven. Motiva ni, materialnih dokazov tudi ne, kot tudi ni neke razlage zakaj je ne bi raje ustrelil od zunaj skozi okno ter zakaj je imela mama na sebi sledi smodnika na delih, kamor se prime pri streljanju, vendar hkrati na sebi ni imela niti kaplje hčerine krvi, čeprav naj bi ji umrla v rokah. Kovačič opozarja, da je scenarij obrambe realen, medtem ko tožilstvo po njegovem fantazira.
Verski fanatizem je VK izločil kot možnost z neznanimi dejstvi, na neznan način, z neznano logiko.
Wrop ::
Stranka bo zvesta vodji. Po do sedaj videnem se SDS ne bo pustila diktirati drugim palčkom, kdo bo njihov vodja. Heretike iz stranke meče tudi SMC, nekateri pa so izstopili celo sami.
Zakaj bi že sprejeli to ponudbo? Bodo tudi AB, MC, MŠ, KE odtopili svoje položaje drugim, da dokažejo, da jim je mar za Slovenijo? Dvomestne low level IQ logične zahteve.
1000x izjavljeni, ponovljeni in poveličevani etični pogon SMC je upehal. Sedaj jih čaka borba za obstoj z golimi rokami. Pa tako dobro priložnost iz leta 2014 so zapravili. SMC je stranka 2-3 mandatov, potem bo verjetno izginila. Člani se bodo prepakirali v lepšo in novejšo embalažo, volilci pa jih bodo lahko ponovno veselo volili.
JJ seveda ni večen, do penzije bo še kakšno odškodnino pokasiral in lepo živel v upokoju.
Malajlo ::
Repovžev uvodnik današnje Mladine je dovolj zgovoren.
Nekatere stranke so rekle NE populizmu, nacionalizmu, revanšizmu, rasizmu in še kaj bi se našlo. Tiste, ki tega ne opazijo ali pa so ignoratske, so pač out.
Da pa se najdete kritiki Levice, češ, da nočejo popustiti, pa takole... Petorček je obenem z NSi uskladil tudi svoje zahteve. In zdaj morajo zagovarjati "skupno" mnenje in stališča. Da bi kdo spet nazaj stopil in (ponovno) zagovarjal svoje mnenje in usklajeval z novim (potencialnim) partnerjem, je pa utopija. Cona udobja pa to.
Rešitev je seveda samo ena: res domišljen sedežni red. Oče in bivši tast narazen, obrnjena s hrbtoma drug proti drugemu. Hči in njen fant ob bivšem možu, ki ga fant ceni (ali pa se ga malo boji). Prababica med otroke in stran od vešče (sestra od nekoga). In tako naprej.
No, sedežni red je problem, ki ga zdaj rešuje Marjan Šarec. Res ni lahko sestaviti tega omizja, ki naj bi naslednja štiri leta zagotavljalo podporo vladi. In medsebojne "ljubezni" so zelo podobne. Na primer med Alenko Bratušek in Mirom Cerarjem. Kaj je bilo že prvo dejanje Mira Cerarja leta 2014, še preden je imel sestavljeno koalicijo? Sestrelitev komisarke Alenke Bratušek. A to je na osebni ravni. Na ravni posameznih političnih tem je seveda še huje. Luka Mesec pač meni, da je Nato neumnost. Miro Cerar je na članstvo v Natu ponosen. Pa sploh še nismo prišli do žice ...
Truga ::
Wrop ::
Ker gre za Slovenijo. Baje.
To bodo lahko pokazali z drugimi dejanji, ne pa z odstavljanjem vodstva po diktatu drugih strank, ki so nastale dva meseca pred volitvami.
Pajaci tipa JJ se ne upokojijo. Njegov idol je bil precednik jugoslavije do smrti...
Dobro so to naštudirali. Vedno, ko kdo poveličuje Tita, se jim začne valiti pena iz ust. Ampak nekateri ste spregledali in veste, da je to samo predstava za tiste, ki jim Juga ni bila ravno intimna opcija.
- spremenil: Wrop ()
Truga ::
Ja, vcasih je bil tito idol. Zdaj je nevaren, ker se takoj vidi kam pripelje tak rezim. Zdaj je bolj popularen Orban, ker se ni imel cajta vsega zafurat.
kuall ::
zmaugy ::
rekt ::
Eh, levici je pri sedanjih pogajanjih za očitat samo to, da mešajo blato. Njihov program, kakorkoli butast se komu že zdi, je pač njihov in prav je da se ga držijo, če so bili na njegovi podlagi izvoljeni. Odgovorno bi pa bilo, da naravnost povedo "gremo se/ne gremo se", ne pa da mutijo s projektnim sodelovanjem.
Markus386 ::
Čaki, hočeš reči, da je bil režim pod Titom slab?
Jah enim je bilo fajn... zastonj počitnice na jadranskem otoku, fitnes na prostem... ni da ni.
Saj tud američani znajo... kdor ne ve, se "waterboarding at guantanamo bay" slisi kot neka precej zabavna stvar.
Nak, stranka katere zadnja vlada je izključno odpuščala ljudi po strankarski liniji, aktivno sabotirala državo v času krize in pogrevala starih zamer namesto reševanja trenutnih težav je izgubila pravico odločanja kaj naj počne in kaj ne. Tiho naj bodo in ubogajo pametnejše od sebe, takih je samo v parlamentu vsaj 61.
zmaugy ::
- spremenilo: zmaugy ()
Unknown_001 ::
Če si bil tiho in naredil kar se je reklo, se je dalo lepo živet. Sploh če si bil prijavljen med komuniste ali bil kako drugače povezan s partijo.
Potem imaš na drugi strani ljudi ki so sistem zavračali pa jih je to teplo na vseh področjih. Tako kot sosed ki je bil na vusoki poziciji v vojski dokler ni jezika preveč stegnil.
Imaš folk ki je delal preko granice pa so se še po sboje kaj znašli...
Verjetno je bilo lepo in na nek način slabo. Kakor komu pač...
Begabt
Begabt
zmaugy ::
Saj za nekatere je tudi v Severni Koreji lepo, za druge pa ekstra zanič. Ker sem v Titovi jugi živel, vem precej dobro, kako je bilo.
zmaugy ::
| » | a bodo ukinili dodatno zavarovanje al ne? (strani: 1 2 3 4 … 8 9 10 11 )Oddelek: Loža | 104661 (70257) | aviator |
| » | Stranka Levica vložila zahtevo za referendum o Zakonu o dohodnini (strani: 1 2 3 )Oddelek: Loža | 24430 (11471) | bbbbbb2015 |
