Forum » Kriptovalute in blockchain » Radeon RX 570
Radeon RX 570
kekeck ::
Pozdravljeni
Imam sledečo strojno konfiguracijo riga:
- plošča GIGABYTE GA-H110-D3A
- procesor Celeron G3930
- RAM 8GB
- 6x SAPPHIRE Nitro+ Radeon RX 570 OC 8GB GDDR5
Programsko:
- Win 10 64
- driver 23.20.15015.1002 (crimson 18.1.1)
- Trixx: GPU 1450, RAM 2200
- Claymore Dual Miner 10.3, rudarim samo ETH.
Ko rudarim mi kaže naslednje hitrosti:
- GPU0 20 MH/s
- GPU1 27 MH/s
- GPU2 20 MH/s
- GPU3 20 MH/s
- GPU4 27 MH/s
- GPU5 27 MH/s
Zanima me zakaj ni na vseh grafičnih ista hitrost ???
- RAM 8GB
Programsko:
- Win 10 64
- GPU0 20 MH/s
- GPU1 27 MH/s
- GPU2 20 MH/s
- GPU3 20 MH/s
- GPU4 27 MH/s
- GPU5 27 MH/s
Lahko je čisto v karticah samih lahko pa provaš naslednje v uefi, če še nisi:
* Initial Display Output
Specifies the first initiation of themonitor display fromthe installed PCI Express graphics card or the onboard
graphics.
IGFX Sets the onboard graphics as the first display.
PCIe 1 Slot Sets the graphics card on the PCIEX16 slot as the first display. (Default)
* Internal Graphics
Enables or disables the onboard graphics function. (Default: Auto)
* Above 4G Decoding
Enables or disables 64-bit capable devices to be decoded in above 4 GB address space (only if your system
supports 64-bit PCI decoding). Set to Enabled if more than one advanced graphics card are installed and
their drivers are not able to be launched when entering the operating system (because of the limited 4 GB
memory address space). (Default: Disabled)
ali
graphics.
* Internal Graphics
* Above 4G Decoding
ali
kekeck ::
Hvala za pomoč.
V BIOSU imam
- mining mode ENABLED
- IGFY ENABLED (monitor imam vklopljen na grafično na plošči)
- internal ographics ENABLED
- 4G Decording ENABLED
Virtual memory sem imel zgleda nastavljen OK in nima vpliva ne glede kaj nastavim.
Bom poskusil še riserje menjat.
pomoje ni druge kot gor dat bolj stabilne Win7 in na novo naložiti driverje?
PS.
Sem pa imel težavo na drugem rigu (ista konfiguracija) 6x GTX 1060 6GB ker mi Claymore Dual Miner ni delal. Sem spremenil virtual memory iz 8 na 16GB in sedaj dela BP.
Zamenjal riser, nič bolje.
V BIOSU imam
PS.
- spremenilo: kekeck ()
kekeck ::
Sem probal najpej z Win7, ampak Win7 in 6x AMD ni slo, najvec 4x.
Torej, na novo sem nalozil W10, blockchain driverje, atipatch, zamenjal riserje in sedaj dela, 27,27,20,20,27,27MHs, skupaj povprecno 150.
Ali ima kda kaksno idejo zakaj mi vse kartice nocejo delat z 27Mhs?
Pennywis3 ::
si probal CLR Cmos?
Pa zrihtaj si ene orenk memory strapse, rx 570 8GB mora iti gladko čez 30mh/s z bilokatero memorijo.
kekeck ::
CLR cmos nisem probal, ali na plati ali na grafični? Prosim za več navodil.
Memory straps pa imam se v planu.
kekeck ::
Ko sem delal memory strap sem videl da nimam vseh enakih RAMov, 4x Samsung, 2x Hynix.
Nastavil sem 1:1750 na 1:2000 in 1:2200. Ostalo sem pustil.
Po novem mi dela na Samsung 4x 29,5MHs ETH, na Hynix pa 2x 27,5MHs ETH.
Mislim da je sedaj že kar OK.
| » | Etherum mining (rudarjenje) (strani: 1 2 3 4 … 60 61 62 63 )Oddelek: Kriptovalute in blockchain | 671607 (280338) | Jagdpanter |
| » | Random restart računalnika (strani: 1 2 )Oddelek: Strojna oprema | 18004 (16049) | Pero_SLO |
| » | DOGe Coin (strani: 1 2 3 4 … 37 38 39 40 )Oddelek: Loža | 308896 (231652) | matjaz82 |
| » | Litecoin (strani: 1 2 3 4 … 12 13 14 15 )Oddelek: Loža | 159262 (96989) | -žiga- |
| » | Ne spozam se na grafične kartice. Prosim pomoč.Oddelek: Strojna oprema | 2886 (2435) | DeeJay |
