Python - klic PowerShell
dunda ::
Se komu sanja, kaj je narobe pri tem klicu:
lnkTarget = subprocess.check_output(["C:\\WINDOWS\\system32\\WindowsPowerShell\\v1.0\\powershell.exe", ". \"./SamplePowershell\";", "(New-Object -ComObject WScript.Shell).CreateShortcut('" + wordFile + "').TargetPath"], shell=True)
Popravljal sem v drugem delu programa, potem pa se je pri testiranju pojavilo:
 The term './SamplePowershell' is not recognized as the name of a cmdlet, function, script file, or operable program
. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:3
+ . "./SamplePowershell"; (New-Object -ComObject WScript.Shell).CreateS ...
    + CategoryInfo          : ObjectNotFound: (./SamplePowershell:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
https://www.kacnje.eu
dunda ::
Rešeno, izpustil sem tisti nesrečni parameter, pa je delovalo :-)
Zanimiv ...hm... problem
Oddelek: Programska oprema
283489 (2984) poweroff
batch fajl iz txt (strani: 1 2 )
Oddelek: Programiranje
6513161 (11822) b3D_950
.vbs & .bat
71330 (1250) darkolord
Login script
51367 (1301) Mercier
Pomoč pri nastavitvah NTbackup.exe v win xp
291998 (1727) XWY
