hub list za DC++
hub list za DC++
DropMan ::
Pravkar sem si instaliro DC++ zaj pa ne znam poiskat hub list pa niti nastavit ga pol neznam. Prosim pomagajte.
stay cooooooooool
wind ::
pivmik ::
PrvaNoga.com
http://www.1stleg.com/PublicHubList.con...
Tle maš cel kup seznaom hub-ov:
http://dreamland.gotdns.org/PublicHubLi...
sandos' hublist. This is checked with automatic scripts to ensure quality. The hubs are collected from various official lists, along with several hundred direct-registering hubs. If you are a hubowner, you use dcreg.mine.nu as your registering server. If your hubsoftware does not allow you to change, you are probably using the official hub. You can download a version of it that has been modifed to register there by clicking here.
http://www.neo-modus.com/PublicHubList....
The official hublist, this will not show very many hubs at one time, but it will change contents every 6 minutes approx.
http://cdinfo.org/PublicHubList.config
http://finhublist.no-ip.org/publichubli...
http://www.imperialnet.org/PublicHubLis...
http://www.team-ppm.com/~dawson/PublicH...
LP, Gregor GRE^
[P2P]eMule , eDonkey, Overnet, DC++ & co. (strani: 1 2 3 4 … 69 70 71 72 )
Oddelek: Omrežja in internet
3558440906 (24190) Freakylion
RevConnect DC++
Oddelek: Programska oprema
213649 (2457) Brilko
direct conect++
96767 (6506) Bakunin
DC++ search ne dela
61514 (1370) CaqKa
slovenska dc++ hub lista
74700 (4451) iro
