Forum » Loža » brezžični prenos (internet) hitreje al isto hitro kot optika.. kdaj bo to?
blink ::
"Let's take London-Frankfurt as a real-world example. As the raven flies, the two cities are 396 miles apart. A radio signal travelling through air at just under the speed of light (299,700km per second) would cover that distance in 2.126 milliseconds. Through a glass or plastic fibre, where light has to bounce along the refractive index rather than travel in a straight line, the speed of light is reduced to around 200,000km/s, resulting in a theoretical minimum latency of 3.186 milliseconds."
https://arstechnica.com/information-tec...
shintaro ::
thx
Nikonja ::
Ampak tu ni pomembna hitrost kot bandwith ampak latency, in finančnim institucijami je to zeloooo pomembno, ostalima tudi ampak niti blizu v takšni meri.
Bandwidth: Bandwidth determines how fast data can be transferred over time. Bandwidth is the amount of data that can be transferred per second.
Latency: Latency is delay. Latency is how long it takes data to travel between its source and destination, measured in milliseconds.
Najhitrejši brezžični prenos podatkov:
https://www.extremetech.com/electronics...
shintaro ::
waw zelo zanimivo branje
vostok_1 ::
Je pa bistveno bolj zanesljiva in potrebuje manj error cheking mehanizmov. Pa še precej težje za prisluškovat.
There will be chutes!
It came from the lab.
- spremenil: vostok_1 ()
Radijski spekter se deli med vse uporabnike.
Kabel do tvojega doma ne.
Seveda je pa vprašanje kak link naprej je od end-point vozlišča.
SaXsIm ::
No shit, Sherlocka. Ampak vprašanje na takšnem nivoju pač zasluži primeren odgovor.
SaXsIm
- spremenil: SaXsIm ()
Kaj niso LTE hitrosti prenosa že primerljive s tistimi na optiki?
Od kdaj pa imaš na LTE samo zase 1Gbit/s??????
Miha 333 ::
Dobro, 1 Gbit/s je luksuz. Povprečne hitrosti uporabnikov interneta na optiki so 10 - 100 Mbit/s
mojster_joni ::
odvisno, 1 gbit dl in ul je lukus, 1 gbit dl ja pa manj kot 20 eur nažalost... mar bi imeli 500/500
| » | Prvo javno omrežje 4G bo na ŠvedskemOddelek: Novice / Omrežja / internet | 6821 (4560) | PrimozR |
| » | kontrola outputa informacijOddelek: Znanost in tehnologija | 1819 (1627) | Thomas |
| » | Kakšna hitrost je FLOP?Oddelek: Pomoč in nasveti | 1736 (1554) | Dr X |
| » | Gravitacija s svetlobno hitrostjoOddelek: Novice / Diski | 2603 (2603) | Aggressor |
| » | NasvetOddelek: Pomoč in nasveti | 3816 (3646) | Huey P |
