Intel Core 8th-gen: Coffee Lake
RegulusDraco ::
ja med 25 do 30% hitrejši je trenutno. Epic cpu.
D3m je izjavil:
Samo 19%. LOL.
Redko boš obremenil vseh 16 threadov hkrati. Ko pa jih boš pa bo 20% hitrejši Intel.
Bomo videli če ga ryzen ujame v svoji zen2 iteraciji.
A coding sequence cannot be revised once it's been established.
FlyingBee ::
AapocalypseE ::
Tistih 30% pa kar spreglej...
Rdeči lahko greste v kot jokat... 9900K owns ya all :))
FlyingBee ::
Bolj se splača 9900k kot pa top TR, lol, matične so 100eur cenejše pa še tr je precej dražji.
AapocalypseE je izjavil:
In to brez coolerja
neo5468 ::
Po performanceu je 9900k boljši ja, vsi smo vedeli da bo, ampak 9th gen intel cpuji se bodo merili z 7nm zen2, ne pozabit na to. Ryzen 2700 je star pol leta, medtem ko je intel frišen.
See ya at 2019 CES.
Ahim ::
Anandtech review:
https://www.anandtech.com/show/13400/in...
Po pricakovanjih mnogo hrupa za ne ravno najboljse rezultate )tako proti interni konkurenci plavih manjedrnikov kot proti rdeci, ki je kljub nizjemu taktu le malo zadaj).
Bwaze6 ::
Intel's own marketing paraded the Core i9-9900K as the best processor for gamers. While that is technically true, the differences are rather slim in our own testing. For example, at 1080p resolution, with all games set to highest details, the difference between i7-8700K and i9-9900K is just 2%. As you increase resolution, the bottleneck shifts more and more to the GPU, which is why even higher resolutions like 1440p or 4K see smaller increases. Even at the theoretical scenario of 720p, where the CPU is the bottleneck, the same 2% difference stands. Compared against AMD Ryzen processors, the differences are bigger, especially at 720p, where the 9900K is 17% ahead. As we increase resolutions, that advantage does get smaller and smaller though: 1080p (8%), 1440p (4%) and 4K (2%).
Že na 1080p je razlike med 2700X in 9900K 8%.
8%.
Kolk to manjka do 50%?
Sem pričakoval optimistično več. Pa ne bo nič iz tega očitno. Pffffffff.
Bwaze6 je izjavil:
8%.
En klik stran od Gaming mode. :P
Pri 5,0 GHz temp poskoči na 100°C na vodnem. Bravo.
  • spremenil: D3m ()
RegulusDraco ::
ryzen 2 ga bo dohitel. zagotovo. In bo hladnejši, varčnejši, tišji na STOCK coolerju za 350 eurov.
bolano. amd bo zmlel intel :D
Ampak ja, trenutno je Intel i9 boljši. In za ceno nvidia gtx 1060 6gb grafične kartice dražji.
To je res.
Samo cene so blizu 1000EUR.
In ne po bruto ceniku.
  • spremenil: D3m ()
neo5468 ::
Mislim, v evropi je že 8700k šit glede na to kok je cena trenutno napihnjena zaradi shortage-a. Ko se bojo pa cene umirile, bo pa zen2 pred vrati, tako da ne vidim poante kupit karkoli v intel lineupu. Zdejle je res najslabši čas za nakup procesorja.
RegulusDraco ::
D3m je izjavil:
To je res.
ni važno. Intel je pomojem pričakoval da se 9900k ne bo prodajal. Želeli so samo obdržati krono najhitrejšega CPUja.
In jo bodo obdržali, dokler ne pride na trg ZEN2.
FlyingBee je izjavil:
Oh, wtf, grafe imajo za vse popularne resolucije, kaj ti ni jasno? A ti test na 720p preprečuje ostale pogledat. Ne delaj se neumnega, no more.
Tebi se ni treba delati.
RegulusDraco je izjavil:
ker samo otroci procesor menjajo na 2 leti. Ostali ga imamo po 5 do 10 let. Po 5 letih pa se začne že kar konkretno kazat koliko CPU ovira grafično kartico.
Je pa tudi nemogoče napovedat koliko se bo to poznalo čez 5 let. Se spomnim nekoč ko so bili 2 jedrni procesorji hitrejši od mojega 4 jedrnika (višja frekvenca delovanja, bolj so se navijali)...več frejmov na sekundo in so takratne igre laufale hitreje. Zdaj pa moj q9400 še vedno lahko poganja moderne igre, ki jih 2 jedrniki niti zaženejo ne več, ker ogromno modernih iger zahteva vsaj 4 jedrni CPU).
Tako da če si pred 10 leti gledal reviewe, si kupil 2 jedrni cpu in si se zajebal...če si malo razmislil si kupil quada, ki je imel življenjsko dobo 10 let.
Vsi, ki so takrat kupili recimo e7500 ali pa mogoče e8600, so 2 do 3 leta kasneje kupivalo i5-2500k. Če si kupil q9550, q9400 ali kaj v tem rangu pa ni blo prav _nobene_ potrebe po upgradanju sistema.
se pravi še na kratko: performance pri 720p ti pove kolikšna razlika je v delovanju procesorjev trenutno. Pove pa ti tudi kako bo procesor delal, ko se bo postaral. Če imaš žnj jeder na voljo, kot jih ima Ryzen...verjemi, da se bo staral zelo, zelo dobro.
A si ti sploh prebeal, kar si napisal? Ker v istem prispevku sam sebe demantiras.
  • spremenilo: tikitoki ()
RegulusDraco ::
s čim specifično
s tem da ti 720p resolucija pove koliko je trenutno hiter cpu? in da s tem, če to informacijo povežeš s številom threadov točno izveš tudi kako se bo cpu staral?
Buggy ::
kje je zdej tist Intlov fanclub, ki se jim mal prizadeto cufa v vsakem drugem postu in zmerjajo ostale z otroci? Prizadeto, custveno in neargumentirano kot kaksno navijastvo med fuzbalerji, desnimi in levimi, lasko in union...res neverjetno. Najbolj zalostno je pa to ker si tudi sam lastim 1x I7 7700, 2x i7 2600/K, I5 2320, Q9400 in Fx 8120...zdej prihaja pa se R5 2600, pasem se vedno odlocal zgolj in samo na p/p. Custva do ene firme, kot jih berem od enih zgoraj so miloreceno nezrela, sploh takrat ko je vec kot ocitno da so v tem primeru bad guysi >:D
Torej ce povzamemo:
Trenuten top tier gaming Intel CPU:
-stane s hlajenjem skoraj trikrat vec kot top tier AMD CPU
-rabi vodno hlajenje ali top zracno hlajenje, da ze default ne throttla
-rabi se enkrat drazji MB kot AMD
-porabi za skoraj isti performance se enkrat vec stroma + 100W
in to vse zato da lahko imas na 720p 19% boljsi performance, ker bos cez 5 let menjal grafo in bos se vedno in. Kako mu ze recejo - "Technically The Highest Performing Gaming CPU"..slisi se tko nekak kot bigfoot >:D
Ostali bomo pa lepo vzeli cenejesi AMD za razliko boljso grafo in monitor ter uzivali na 1440p gamingu. Cez pet let pa ponovi vajo.
ROFL za poscat smesen kaksna Intel blamaza :))
  • spremenil: Buggy ()
dejansko pa je večinoma 30% boljši kot od AMDja.
Intel je naredil zverinsko dober CPU. škoda da je tako drag. Kapo dol Intlu.
Če bo bil samo 100 eurov dražji od AMDja bi bil Amd povsem obsolete.
Kar naenkrat poraba ni pomembna. Damn, ta CPU zre elektriko, k da bi bila zastojn. Za tistih povprecnih 20% vec hitrosti, je 100% visja poraba. Damn,m kaksna ucinkovistost.
Seveda poraba ni važna, ker tekmuje proti AMD.
Pazi to....na 5.0 GHz dosega pod custom vodno 100°C!
s čim specifično
Preberi.
Ryzen na tem testu pogrne, ti pa trids, da se bo dobro odlocil. Bos moral mal razcistiti svoje dihotomije.
s čim specifično
Ti si napisal, da rezultati tudi napovejo kako se bo obnasal v prihodnje. In, ne, nikjer nisi napisal, da informacijo povezes s stevilom threadov. Vsaj ne koherentno.
gendale2018 ::
D3m je izjavil:
zimski procesor :D
ja sam mali poštar, kurac mi je oštar
čuvajte se žene, bit ćete jebene
Vsem je bilo janso, da bo to najhitrejsi CPU. Sam ne vem, ce je bilo vsem jasno, da bos rabil svojo elektrano, ce si sposodim bedarije, ki jih pisejo nekateri fanbojcki o AMD.
Smesno je tudi kako fanbojcki druge ozigosajo za fanboje. Ce bi bil, nebi kupil INTEL platforme, ko sem nadgradil. Glede na trenutno stanje pa me zanima, ce bo smiselene prehod na 7 nm Ryzena, ko bo na voljo.
Bwaze6 ::
Pa mislite, da se bodo cene umirile? Ali je to pač nova realnost, itak je že grosistična cena i9 9900K 488$, potem pa marža prodajalca, stroški, davki... Je sploh lahko kaj dosti pod 600 €?
gendale2018 ::
če se bo prodajal za to ceno potem sigurno ne bojo znižali
FlyingBee ::
Žal jim ni treba, ker AMD ne povede absolutno.
A to ti Intel pravi? :D
FlyingBee ::
Kdo si ti?
  • predlagal izbris: Ahim ()
Stojan že nisem. ;)
FlyingBee ::
Sprašujem, ker očitno imaš neke druge podatke kot so dostopni na review straneh ali pa si izmišljuješ, v vsakem primeru kr neki.
FlyingBee ::
tikitoki je izjavil:
s čim specifično
Preberi.
Malo je vse skupaj pomešal. Tile testi so po metodi izločanja bottlene ka druge komponente, da ne zavira testirano.
Treer ::
Kot sem rekel zadnjič, 50% malo verjetno, 20-30 pa ko keks :D in ja, s tem je boljši že tudi od 12/24 TR (in cenejši, ko se gleda cena celotne platforme), marsikje pa zajeda celo mnogo dražjega 2950x, lol :)) Bogi AMD, kaj jim sploh še preostane...
Zheegec ::
Waw, "95W TDP".
Izgleda zelo očitno, da je tole čisti maksimum, ki ga trenutna Intel arhitektura premore.
Janez Janša, 29.04.2014
FlyingBee ::
Nižanje cen, na srečo.
Damn. Požrešen bolj, kot TR 32/64.
Zheegec ::
i9-9900K stane preko 50% več od R7-2700X in porabi 100% več energije od R7-2700X. Pri Intelu bo še dražja matična plošča in pa hladilnik.
Price/performance je res slab, rekel bi da je nakup smiseln samo za lastnike 240Hz monitorjev.
  • spremenil: Zheegec ()
Buggy ::
Zheegec je izjavil:
Price/performance je res slab, rekel bi da je nakup smiseln samo za lastnike 1080p240Hz monitorjev, ki igrajo 5 let stare FPS igre.
fixed!
neo5468 ::
Tiste esports igre, ki grejo do 200fps+ kot je csgo, furajo take frejme že z i7 8700k, torej katere igre si to mislu glede 240hz?
Za esport je APU in RX 550,GTX 1030/50.
neo5468 ::
Če greš apu, zakaj rx 550/gtx 1030 če je vega 8 grafično isto močna? Slab advice.
Buggy ::
neo5468 je izjavil:
...to je tudi meni neznanka :(
Če slučajno kdo noče dGPU sta 2200/2400g dovolj zmogljiva.
gddr85 ::
btw, nimajo vsi enak igpu, 200ge ima vega3, 2xxx serija pa vega8 in 11
neo5468 ::
Mislil sem 2200g, ker je logično najboljši APU buy, glede na to da ima 2x boljši performance od 200ge za samo 30€ več.
Treer ::
APU-ji so samo gimmick - na papirju se fino slišijo, a v resnici je njihov GPU del še vedno precej preslab za kakršenkoli omembe vreden gaming, razen za 720p, kateremu se rdeči vedno smejejo, kadar je na cpu testih, češ kako na tej resloluciji nihče več ne igra >:D
gddr85 ::
v bistvu niso nič kej drugačni od kakega i5, i7 (4c/8t), samo da imajo pač bolj zmogljiv igpu, ne vem o kakem gimmicku ti to ;)
Lol. Ti ga pa rad biksaš A N?
FlyingBee ::
gddr85 je izjavil:
Ne mešaj intel 4/8 in amd 4/8, razen, če gledaš Haswell iz 2014 in Ryzen 5 iz 2017, lol.
Treer ::
Še to mogoče tisti najbolj entry level i5 4*** serije, katerikoli i7 iz te serije pa povozi 2400g po dolgem in počez
neo5468 ::
Treer je izjavil:
https://www.anandtech.com/bench/product...
https://cpu.userbenchmark.com/Compare/I...
To je zate po dolgem in počez? Pa to je Skylake, kaj šele Haswell in below.
46 / 47
Nakup CPUja 2019 (strani: 1 2 3 )
10624542 (20180) Predator X
i7-9700k ali i9-9900k ? (strani: 1 2 )
6312408 (10786) TheKingZiga
AMD najavil Ryzene 3000 in Radeone 5000 (strani: 1 2 3 )
Oddelek: Novice / Procesorji
12652381 (45968) Predator X
