Kateri "keyboard shortcut" je "meta"
Jst ::
Torej, vprašanje je že v naslovu teme.
V SVP vidim keyboard shortcuts, ki so recimo:
"Meta+Ctrl+A"
Pojma nimam, kaj naj bi ta "Meta" predstavljal.
AC_DC ::
  • spremenilo: AC_DC ()
Jst ::
Smooth Video Project.
Vzame video, ki ima recimo 24FPS in extrapolira vmesne sličice, da se predvaja z 60FPS oz. toliko, kot imaš monitor.
In kako naj pritisnem recimo "Meta+Ctrl+Alt+P"?
Jaz imam spodaj Ctrl, Win, Alt, Space, Alt, Fn, Ctrl.
Fn+Ctrl+Alt+P ne dela, kar sem že probal.
fosil ::
win = meta
Tako je!
Jst ::
Nope. Vsaj pri meni ne dela.
shinko ::
Si probal z Alt Gr?
Jst ::
Probal vse mogoče, potem "vprašal" internet, nato se obrnil sem.
Moral bi pa vprašati na strani projekta namesto tu. Bom, pa sporočim...
Iatromantis ::
Internet pravi:
Meta
The Meta key is not found on modern keyboards. Its use is sometimes emulated with AltGr (on some international layouts) or the right Alt key on the others. In addition:
Sun keyboards have a meta key (?) as well
Emacs calls Esc the Meta key
Some additional information:
Wikipedia claims the Windows key is sometimes called Meta, but I didn't find any other reference for this.
In še: here is no "Meta" key in Windows. You will need to remap them. - kar bi mogoče šlo s tem http://www.razumny.no/2008/09/remapping... - program dobiš na naslovu https://www.microsoft.com/en-us/downloa...
Linux Mint 12 zunaj, ponuja dobro staro gnome izkušnjo
4918053 (14139) Icematxyz
Novice o XGLju
134495 (3704) G-man
Luknja v požarnem zidu SP2 za Windows XP
Oddelek: Novice / Varnost
334097 (4097) Cokolesnik
Datoteke za dobro jutro
Oddelek: Novice / Igre
73040 (3040) ThePlayer
Nasvet
93816 (3646) Huey P
