The Witcher
The Witcher
todman74 ::
yayo je izjavil:
Čakte, jaz govorim o romanu. Kaj so tv serijo po njemu naredili?
To ne vem, ti pa povem, kako bi serija zgledala. Ker nas "posiljujejo" z moško goloto v zadnjem času na polno. Pa me ne moti, če je narejeno uravnoteženo, kot je bilo v Westworldu, niti, če je namenjeno specifičnemu občinstvu, za kar so bile narejene serije Oz, Minx, Euphoria....ampak, če je serija namenjena splošnemu občinstvu (The Leftovers, White Lotus),me pa moti, da se prikazuje skoraj izključno gole dede.
Sem brskal zadnje dni po HBO meniju in našel serijo The Deuce, ki "govori" o snemanju pornografije v 70 letih prejšnjega stoletja. Pričakoval sem precej golote, "dobil" pa sem veliko penisov (tudi trdih), pa topless "porno igralke".
BaTeMaN ::
Da se ne bo kdo za sekiral :) :) :)
Many of the dicks we see on our 4K televisions are fake, he wrote for The Conversation. HBO has a long history of displaying naked penises, such as in the 1990s show Oz. The difference between Oz and, say, Euphoria, which stirred up dick discourse in 2019, is that the dicks in the latter are prosthetics. The penis tide changed from real to artificial with the 2010 Starz series Spartacus, Lehman said.
Why? Because prosthetics allow filmmakers and actors to decide how they want characters' dicks to look, namely: huge.
Society's obsession with big dicks isn't anything new, but it's an obsession perpetuated by porn. The dicks on porn performers are sometimes portrayed as cartoonishly large (no doubt enhanced by camera angles, lighting, and other movie magic), and if not then definitely above the average penis size of 5.1 to 5.5 inches.
....in tako naprej.
less then zero
todman74 ::
BaTeMaN je izjavil:
....in tako naprej.
A zdaj naj pa jaz ugotavljam, a je k**c tam naraven al pa ne. Briga me za to, dejstvo je, da so penisi tam, žensko mednožje pa izginja iz mainstream filmov in to je tudi del woke propagande.
BaTeMaN ::
To je, da želijo spravit penetracijo v normalen TV program :)
To ni ravno od včeraj ampak delajo na tem zadnjih 20 let...
Ker se nekaterim zdi to seveda primerna vsebina za na TV.
less then zero
todman74 ::
BaTeMaN je izjavil:
Kaj ti govoriš? Tle razlagam, da je ogromno penisov na zaslonu, vagine pa praktično ni v mainstreamu.....če hočejo neko revolucijo, potem naj dajo na zaslon ženska mednožja (pa ne samo sramnih dlak), ne pa tono moških spolovil, ki so na TVju že od nekdaj...
  • spremenilo: todman74 ()
V Hangover trilogiji pokazejo veliko penisov. Še tam kjer bi morala biti vagina je penis, pa Stu se v zadnjem delu na koncu filma zbudi z umetnimi joškami:>
We are fine without wings.
Horas ::
to je pa res da se tiči večinoma kažejo brez problema v filmih in serijah. lulike pa nič, samo noge skup. pa če že slučajn pokažejo, ma kosmato (kar nimam nič proti big fan here) samo da se ne vidijo žnablčke.
BaTeMaN ::
Jaz samo govorim kak je plan.
Ti pa se razburjaj kolk hočeš.
Hočem samo povedat, zakaj je tega vedno več.
less then zero
todman74 ::
BaTeMaN je izjavil:
Seks se v filmih prikazuje že od 50+ let. In včasih so pokazali tudi kakšno žensko mednožje, sedaj pa se ženska ko končata zavije v rjuho, možakar pa še 5 minut leži razkrečen s svojim onetom vsem na pregled.
Tudi neseksualna golota je zadnje čase bolj kot ne samo moška.
BaTeMaN ::
https://www.vice.com/en/article/5gjwwk/...
Zanimivo branje in pogledi... še dobro, da sem iz generacije, ko sem še v kinu videl "Ko zorijo jagode (1978)" (sicer malo pozneje), in žensko telo, da mi možgani scene z male nudity - avtomatsko izklopijo. Tudi jugoslovanski film z goloto žensk ni imel nobenih težav.
Priznam, da imaš glede danšnjih zadev seveda prav in da je moteče... oz. popolnoma nepotrebno. Medtem ko "more boooobs" vedno dobrodošlo. :)
Je pa tud res, da sem to nazadnje opazil v westworldu, kjer niso šparal z nobenim spolom, vsaj zdi se mi tako.
less then zero
todman74 ::
Saj tako, kot je bilo v Westworldu, je v redu, pač oba spola gola, pa še smiselno je bilo.
Mogoče drugi tega ne opazijo toliko, odvisno kaj kdo gleda. Če pogledaš dosti dram, tako kot jaz, je tega veliko. V filmih in serijah o raznoraznih superjunakih, ki jih je na HBO ogromno, pa seveda ni. Sam jaz teh supermanov, spidermanov, captain America in podobnih , ne prenašam.
Horas ::
ne , v westworldu se tudi nič ni videlo, al so meli skup noge tesno, ali pa je grmiček vse zakrival.
BT52 ::
Westworld S01 top ideja. Potem pa downhill. Niti ne morem pogledat 3 dela 2 sezone. Niti joški ne morejo rešit tega
todman74 ::
Horas je izjavil:
Razen v eni zelo kratki sceni, ko je imela eno pobrito, imaš bolj kot ne prav. Sedaj nam pa še grmičke jemljejo....
BT52 je izjavil:
Se strinjam...po prvi sezoni je šlo samo še navzdol.
The Witcher: Season 3 | Official Teaser | Netflix
Kot pravi večina finalna sezona.
lisaac ::
Jaz sem trenutno s prvo knjigo Withcerja (Zadnja želja) skoraj pri koncu, vmes sm si pa zavrtel prvi dve epizodi prve sezone Witcherja..in se mi poraja vprašanje, ali se sploh splača pogledat serijo po tem ko preberem obe knjige? Ker če primerjam že zdaj serijo in pa knjigo...je serija katastrofa napram knjigi
Po mojem ne, se ne splača izgubljati časa za to (kot tudi sicer v življenju za stvari, ki ti niso všeč - npr. greš v kino in ti je film že na začetku porazen, ali boš ostal do konca, samo zato ker si plačal 10 evrov za karto ali ti je tvoj izgubljen čas več vreden in boš vstal in šel?) - razen v primeru, če bi te serija res pritegnila; kar pa te itak ni.
yayo ::
lisaac je izjavil:
Če si prebral kratko zgodbo Zrno resnice si lahko pogledaš prvo epizodo druge sezone in to je to. Pa še to, da primerjaš konec zgodbe, ki je v tv seriji seveda prilagojen tekočem "woke" zgodovinskemu trenutku. Ostalo je milo rečeno drek pa še spoilal si boš nekatere stvari iz knjig, ki še niso prevedene.
lisaac ::
Sem si kar misliu da bo tako ..hvala obema! :)
The Witcher's Next Live-Action Spinoff Begins Filming Soon
A report suggests the next live-action spinoff of Netflix's The Witcher, centered on the controversial gang known as the Rats, has begun production.
https://www.cbr.com/the-witcher-spinoff...
Netflix ne ve kdaj mora nehat.
joze67 ::
oo7 je izjavil:
Če kaj, to dobro vedo. P&L.
Nikakor netflix ne ve
Marsikere serije so nehali za bv in bi bile se gledane da bi zakljucili hkrati so marsikaj silili bv naprej
Ozark je bil recimo redki primer res donre serije ampak k sreci so nehali ker je postajalo vedno bolj nategnjeno
Hkrati so pa nek lost ship serijo meli in ni nic naprej pa nic dokoncano
yayo ::
bodo bolj kompetentni povedali ampak Netflix se gre nek biznis model kjer sili nove serije v upanju, da bo pridobil nove subscriberje. Potem pa kensla take, ki neko bazo gledalcev že imajo. "Podgane" iz Witcherja bodo zelo verjetno uber-woke fest. In to ne govorim kot nek nasprotnik woke gibanja ampak, ker vse tako kaže. V romanih so podgane tolpa mladih - mladoletnih izobčencev, ki živijo kot nekakšni hedonistični Robin Hoodi. Med njimi sta ena lezbijka in ena energična vilinka, ki ima razmerje s šefom bande, bivšim vojakom. V seriji bodo verjetno vseh možnih pigmentacij pa pol moških bo gejev. Po mojem so tako serijo tudi "pitchali" šefom Netflixa. Drugače v romanih nastopijo bolj na kratko in končajo klavrno. Seveda serija, tako kot Netfixov Witcher pa Blood Origin pa tista risanka o Vesimirju s knjigami razen par imen in malenkosti ne bo mela skupnega čisto nič. Netflixu se je šlo za to, da dobi naslov znane poljske serije knjig/blagovne znamke, katero nihče v hiši še zdaleč ne razume ali spoštuje, in, da znamko izkoristi v trgovske namene. Pa šefica celega projekta je poročena z neko večjo živino, ki dela pri Netflixu pa so ji Witcher projekt dali kot neko odskočno desko.
Napovedana 5 sezona TV serije Witcher :| Kot kaže Netflix resno misli s Hemswortom kot Geraltom ampak mislim, da bo ta TV serija mrtva po 3 sezoni zaradi odhoda Cavilla.
Jaz sem že nehal gledati po prvi.
estons ::
Bomo pogledali for old times' sake, da jim damo priložnost, ampak močno dvomim, da bo še kaj iz tega.
The Witcher: Season 3 | Official Trailer | Netflix
Badwolff ::
3. sezona je eno veliko sranje , sploh pa zadnji del.
  • spremenilo: Badwolff ()
Meh, glede na trenutne nove vsebine na Netflixu niti ni tako slabo:)
Badwolff ::
Mah od začetka je za silo, zadnji del je pa čist bruh ...
baje bo še pet delov konc mesca.
BT52 ::
Ali ni to ta šov, kjer so pisci rekli, da nimajo radi originalnega materiala? To pa je en velik BRUH. Direktno se nam slovanom posrali v grlo. Žanji kar seješ. Sezona 1 še zelo prebavljiva. V 2 pa sem po 3 delu rekel WTF?!!! Netflix nima sramu.
Tretja sezona je živ dolgčas no saj tudi prvi dve nista bili kaj boljši. Pa tudi tole ni preveč podobnu slovanskemu Witcherju ampak bolj New yorku.
yayo ::
ne gledam serije, sem pa danes pogledal en YT video in izvedel sledeče: Jaskier/Dandelion, ki je v knjigah predstavljen kot nepopravljiv kurbir je v seriji biseksualec, ki se dol daje z Radovidom. Margarita Laux-Antille, čarovnica iz mogočne Lože je v knjigah predstavljena kot ženska nezemeljske lepote. Kot vse ostale čarovnice je uporabila magijo, da bi postala lepotica, lepota je pri čarovnicah stvar prestiža in dokaz lastnih magičnih talentov. No v seriji je postala črnka in še debela povrhu. :))
ales85 ::
yayo je izjavil:
Err: močnejše postave, vsaka za svoj tip moškega. Ali ženske. Ali onega. :))
yayo ::
Margarita Laux-Antille emerged from the pool with a splash, spraying water everywhere. Ciri couldn't stop herself looking. She had seen Yennefer naked on several occasions and hadn't imagined anyone could have a more shapely figure. She was wrong. Even marble statues of goddesses and nymphs would have blushed at the sight of Margarita Laux-Antille undressed.
:P
2dark ::
oo7 je izjavil:
Ta serija je živ dolgčas tudi zaradi izbira glavnega irgalca. NI dovolj da nekomu samo pobarvaš lase na sivo oz-. belo in imaš lik. Hennry Cavill enostavno ne deluje zastrašujoče.
(\___/)
(> _ <)
(>&#127851; )
BT52 ::
2dark je izjavil:
oo7 je izjavil:
BRUH Cavill je bil zadnji problem Witcherja. Oprosti ampak ni.
svecka ::
3 sezona je aktastrofa. Že od začetka je celotna serija slabo režisirana. V 3 sezoni je pa kot da bi amater skup kadre dal. Brez vsakršnega prehoda, prehajanje iz scene v sceno, časovni preskoki itd. Totalno konfuzno in sem vesel da je Cavill odšel stran ker tole je sramota. PRav vsevedec moraš biti, da razumeš kaj se dogaja, ko takole kaotično skačejo kadri. V eni sekundi v hiši, v drugi že beži pred jezdeeci v gozdu. v tretji sceni se Witcher čudežno teleportira in reši zadevo. WTF BRUH.
ales85 ::
svecka je izjavil:
To je bilo že v prvi sezone. Tretje nisem gledal, ali je sploh lahko še slabše?
BaTeMaN ::
Zdaj ko sem prebral 3 knjige sem prišel do zaključka, da je hype nastal bolj zaradi uspešnosti igre The Witcher 3: Wild Hunt, kot pa zaradi "source materiala" :) Tako imenovani poljski Tolkien Andrzej Sapkowski je super ded pa vse, ampak to res ni neko globoko branje. Ni treba velik razmišljat :)
less then zero
ales85 ::
BaTeMaN je izjavil:
To absolutno drži. Jaz sem začel z Witcher 1, nato 2, nato 3... vmes so me pa igre tako pritegnile, da sem želel prebrati knjige. Ne bom sodil o kakovosti pisanja, ampak sem pa izvedel tisto ozadje, katero mi je manjkalo.
svecka ::
ales85 je izjavil:
BaTeMaN je izjavil:
PRavi fani smo še gledali Poljski Wiedźmin film in serijo, še preden Netflix Witcher prišel ven ;)
  • spremenil: svecka ()
yayo ::
če kdo želi gledati Hexerja je tukaj boljša resolucija kot na YT. Za dvd kvaliteto pa torrenti, ruski seveda.
če nič drugega dajte malce poskipat prvo epizodo, da vidite kako zgleda Yennefer.
  • spremenil: yayo ()
Božomir ::
Poljsko verzijo sam raje ponovno zavrtim kot pa netflxovo. Ma par slabosti za katere je sicer čas kriv za netflix je pa nedopustno kaj so spacal.
Enako velja za CDPR in prvi špil.
Zakaj so v Netflixovi TV seriji takko spreminjali zgodbo iz knjig...
Tomek Baginski, executive producer of The Witcher : "When a series is made for a huge mass of viewers, with different experiences, from different parts of the world, and a large part of them are Americans, these simplifications not only make sense, they are necessary."
"It's painful for us and for me too, but the higher level of nuance and complexity will have a smaller range, it won't reach people. Sometimes it may go too far, but we have to make these decisions and accept them."
"The audience changes; it's not like... It all changes. When it comes to shows, the younger the public is... the logic of the plot is less significant."
A je to res rekel, da so mladi neumni?>:D
svecka ::
Bolje je rekel da so mladi Američani neumni. Ker očitno je bil Witcher delal samo za USA screening. Ampak itak vemo da je Tomek Baginski idiot, se sprašujem če je svoje skocupalo sploh pogledal z confuznimi time jumpi in zanič predhodi med kadri, ki kar preskakujejo čas še ko ni time jumpov.
Andrzej Sapkowski piše novo Witcher knjigo katera naj bi bila zunaj že naslednje leto ?
Andrzej Sapkowski Confirms Work on a New Witcher Book
https://redanianintelligence.com/2023/0...
The Witcher: Sirens of The Deep | Announcement | Netflix
From the world of The Witcher comes Sirens of The Deep, starring Doug Cockle as the voice of Geralt. Coming to Netflix late 2024.
10 / 12
The Witcher 4 (nova trilogija) (strani: 1 2 3 4 5 6 7 )
Oddelek: Igre
33071192 (1054) Gregor459
The Witcher 3: Wild Hunt (strani: 1 2 3 4 … 28 29 30 31 )
Oddelek: Igre
1528345126 (6628) Zmajc
The Witcher
Oddelek: Igre
445412 (1547) oo7
Tom Hardy - Bond James Bond - 007 (strani: 1 2 3 )
Oddelek: Sedem umetnosti
14431843 (10873) Invictus
The Witcher 2: Assassins Of Kings (strani: 1 2 3 4 5 6 7 8 9 )
Oddelek: Igre
401113079 (82295) yoco
