Forum » Pomoč in nasveti » ram za amd ali intel
geodet MD ::
Pozdravljeni
Kupujem RAM in nekje pač prodajajo ram z določenimi specifikacijami, nekje pa piše RAM za AMD ali pa ram za intel. V čem je razlika?
Tomas 33 ::
To sem se že tudi jaz spraševal.
Za moj primer: ebay
Je opomba "This memory Module only support AMD CPU Chipset. does not work on All intel CPU chipset"
Po moje, da so težave z združljivostjo kakšnega chipseta za Intel, pa se prodajalci zavarujejo.
Še malo dodatnega opisa:
Buyer note:
This memory is high density,only fit for AMD cpu motherboard can't compatible with all intel cpu motherboard.
100% brand New&never used. High quality guarantee. Full tested before shipping to make sure in a good condiiton.
Not work on All Intel CPU G41 P43 P45 H55 H61 H67 B75 Z77 intel chipset motherboards
Not work with All DELL,IBM,Apple,HP,Compaq,Gateway,Acer.Lenovo,Emachines,Packbell Computers.
All high density 1GB modules are made with 16 chips (8 chips on each side) using 128MX4 device.
All low density 1GB modules are made with 16 chips (8 chips on each side) using 64MX8 device
The item is high density and it can not work in any intel cpu motherboard.It only support AMD chipset motherboard
Capacity:4GB DDR2
Type: 240-Pin Desktop DIMM.
Bus Speed: PC2-6400 800Mhz
Voltage:1.8v
Buffering/ECC: Non-ECC, Unbuffered
Za moj primer: ebay
Buyer note:
Capacity:4GB DDR2
Voltage:1.8v
- spremenilo: Tomas 33 ()
geodet MD ::
Zdravo
se opravičujem vendar sem bil zadržan te dni. to je link kjer gledam rame
http://www.aliexpress.com/item/Wholesal.... Je tudi razlika v ceni 2gb 800 mhz za intel 20eur, 2gb 800mhz za amd 10 eur.
Glede podatkov o računalniku še sporočim.
| » | kakšno grafično naj izberemOddelek: Pomoč in nasveti | 4850 (4461) | tikitoki |
| » | Kaj pomenijo številke pri RAM-ih?Oddelek: Pomoč in nasveti | 6863 (6247) | Hayabusa |
| » | AMD Athlon II X2 250 (strani: 1 2 )Oddelek: Strojna oprema | 5664 (4585) | DJ MartiNi |
| » | High-End računalnik (naveza amd/ati)!!! (strani: 1 2 )Oddelek: Navijanje | 8215 (6267) | Vuli |
| » | SDRAM 133-7,5 8chip in 133-8 16 ChipOddelek: Strojna oprema | 1425 (1363) | tiborrr |
