Dolocanje obrobe z CSS pri SELECT-u
matic ::
Kako se lahko poigram z obrobo pri SELECT-u s CSSjem!?
Primer:
 <select name="izbira" size="2">
<option value="1">Prvi</option>
<option value="2">Drugi</option>
</select>
To zgleda takole:
V CSS datoteki, ki je pripeta HTML dokumentu pa je napisano:
 input, textarea, select { background-color: #333333; border-width: 1px }
In barva ozadja se spremeni, obroba pa ne, med tem ko pri gumbih (inputih) itd. dela vse ok!
p.s.: probal sem tudi k selectu dodati style="border-width:1px" pa ni nic boljs...
podpis: _____________
  • spremenilo: matic ()
Ziga Dolhar ::
border-style: solid;
https://dolhar.si/
matic ::
Ni razlike... :\
glavic ::
napiš vse v enem =>
border: 1px solid BARVA;
Musselli bizi
matic ::
nope... tut to ne
alesrosina ::
lahko potrdim da to nikakor ne deluje in tud mene bega zakaj ne. Enostavno ne dela.
KatMai ::
Microsoft Syntax for borderColor
object.style.borderColor[ = color]
Remarks
Up to four different colors can be specified. If one color is supplied, it is used for all four sides. If two colors are supplied, the first is used for the top and bottom, and the second is used for left and right. If three colors are supplied, they are used for top, right and left, and bottom, respectively. For a list of supported color values, see Color Table.
The property has read/write permission. It is supported on block and replaced elements only.
Applies To
HTML Tags BLOCKQUOTE, BODY, CAPTION, CENTER, DD, DIR, DIV, DL, DT, EMBED, FIELDSET, FORM, H1, H2, H3, H4, H5, H6, HR, IMG, IFRAME, INPUT, LI, LISTING, MARQUEE, MENU, OBJECT, OL, P, PLAINTEXT, PRE, SPAN, TABLE, TD, TEXTAREA, TH, TR, UL, XMP
Tabela/razpredelnica v html kodi
Oddelek: Programiranje
61252 (1162) Yacked2
Prikaz strani na različni resoluciji-Joomla
Oddelek: Izdelava spletišč
152489 (2217) kr?en
HTML in CSS težava pri razporeditvi DIV elementov
141347 (1167) MisterR
google analytics
Oddelek: Slo-Tech
213611 (3081) roli
glow efekt s css v FF / dinamicen width s CSS v FF
181926 (1768) Lee_Nover
