Forum » Pomoč in nasveti » Katastrofalne Težave z High-End Računalnikom
--MiRaLdInJo ::
ST-777 ::
--MiRaLdInJo je izjavil:
Na servisu ti bodo povedali, ko bodo z merilno napravo izmerili porabo vseh komponent v tvojem računalniku.SEASONIC S12II-620 620W za 83 EURPa je dovolj močan az moj sistem?
The kernel power event ID 41 error occurs when the computer is shut down, or it restarts unexpectedly. When a computer that is running Windows starts, a check is performed to determine whether the computer was shut down cleanly. If the computer was not shut down cleanly, a Kernel Power Event 41 message is generated.
An event 41 is used to report that something unexpected happened that prevented Windows from shutting down correctly. There may be insufficient information to explicitly define what happened. To determine what may have happened and to identify a potential resolution, it is important to know what the computer was doing at the time just before the event occurred.
If event 41 is logged because power to the computer was interrupted, consider obtaining an uninterruptible power supply (UPS) such as a battery backup power supply. An underpowered or failing power supply may cause this behavior. For example, if you added RAM or additional devices or hard disks when this problem began, the power supply may cause the problem.
http://support.microsoft.com/kb/2028504
--MiRaLdInJo ::
PacificBlue je izjavil:
Potem je očitno res napajalni prešvoh :S
--MiRaLdInJo ::
Zdle sem malo pognal Far cry 4 in po desetih minutah je PC naredil restart :S
EDIT:
Ali je tale napajalnik vredu?
http://www.mlacom.si/xfx-ts-750-750w-80...
EDIT:
- spremenil: --MiRaLdInJo ()
--MiRaLdInJo ::
Evo pa sem dobil v torek napajalnik. Vzel sem Seasonic G-550 80Plus Gold. Do sedaj nobenih restartov, vse brez problema :)
Seljak ::
Enake težave sem imel tudi sam. Ko sem igral igre je vse delovalo normalno,ko pa sem brskal po spletu ali pa v Ps urejal slike pa je PC ugasnil Oz se restartal. Ko sem,dal plato na popravilo Oz na servis,kjer so ugotovili,da je z MB vse vredu sem se odločil za menjavo PSU-ja. Tako,da se lahko iz teh napak marsikdo kaj nauči ali pa vsaj poskusi izločiti krivca. Na forumu sem že večkrat zasledil podobne primere in vedno je bil na koncu kriv PSU.
Proc: AMD Ryzen 7 9800X3D
GIGABYTE GeForce RTX 5080
Ram: 32GB
Ram: 32GB
tilen006 ::
Zdravo
Kaks pa je splosno mnenje o XFX napajalnikih?
Si ok?ker sm si XFX omislu za moj nov sistem
Se link
http://www.hardwareversand.de/en/500+-+...
Se link
ST-777 ::
XFX Pro Series 550W Core Edition je glasen, čeprav je poceni, ga ne priporočam za nakup.
"... the noise production is far too high once we ramp up the load on the XFX Pro Series 550W, as it peaks at 54 dB(A) at 500W load and still reaches 47 dB(A) even at just 300W, which makes it the noisiest PSU in this test." http://www.bit-tech.net/hardware/psus/2...
tilen006 ::
In sm ga malo usr oz polomu tu...ker je ze narocen oz skoraj pri meni preko ups-a (predlagal mi ga je dodelavc) ga bom pa pac menjal ce bo preglasen
| » | Kateri napajalnik? (strani: 1 2 3 4 5 6 7 8 9 )Oddelek: Kaj kupiti | 118202 (1243) | Rias Gremory |
| » | Kaj je najbolj pogost razlog za sesuvanje računalnika? (strani: 1 2 )Oddelek: Pomoč in nasveti | 12636 (10997) | techuser |
| » | Reboot ?Oddelek: Pomoč in nasveti | 2623 (2117) | solatko |
| » | Random restart računalnika (strani: 1 2 )Oddelek: Strojna oprema | 17813 (15858) | Pero_SLO |
| » | Težave z Računalnikom!Oddelek: Pomoč in nasveti | 7024 (6651) | dogo |
