Forum » Strojna oprema » Nvidia GTX 900 series
PredatorX ::
980ti in 980 -60$
970 -40$
960 in 950 -20$
AMD in NVIDIA sta spustila cene za black friday...
http://www.newegg.com/Product/Product.a...
R9 380 2GB za 150$ ali 4Gb za 175$.
- spremenilo: PredatorX ()
Senitel ::
Nvidia GTX 780 zadnji driverji v control panel obkljukane vse opcije za DSR...ko pridem iz igre v 1440p...so vse ikone na namizju razcefukane...v splu (World of Warships), kjer uporabim 1440p na 1080p monitorju s se menijov ne da zadeti z misko, ker je vse zamaknjen...bravo Nvidia in neverjetni driverji..BTW...vmes je se Nvidia Geforce experience dvakrat zmrznil na full![]()
Well sure, ok... Sedaj pa nabavi še Radeona in povej kako ta dva primera delujeta tam.
DSR (ali VSR, nima veze) v vsakem primeru povzroči mode switch, okrog tega ne. Mode switch ti bo razmetal ikonce isto, kot če v display settingsih spremeniš ločljivost. Ta del dejansko nima nič z driverjem.
In zakaj je v World of Warships primeru kriv grafičen driver, če miš ne deluje pravilno?
trnvpeti ::
GTX 980 Original MSRP : $499
Down To $439, $409 After Rebate
to zastopim, da je za black fri se dodatni popust
GTX 970
Original MSRP : $329
Down To $289, $259 After Rebate
The GTX 970 is still one of Nvidia's most popular graphics cards & by far one of Nvidia's best selling. The GTX 970 first launched back in September of last year at $329 and iis still a good performer at that price point today. Despite the fair share of controversy which surrounded this graphics card earlier this year owing to its unconventionally segmented 3.5GB + 0.5GB graphics memory and a number of inaccurate specifications which Nvidia had published for the card which the company had to go back and correct later-on, the GTX 970 is still a decent contender.
You can grab it for as low as $259 from MSI after a $30 rebate or $269 after a $20 rebate from Asus.
GTX 970
- spremenil: trnvpeti ()
Alien123 ::
Spilam bf4 na vsr in ni nobenih problemov
Senitel ::
Kaj ima to veze, da ti špilaš BF4 na VSR brez problemov s tem, da nekdo špila World of Warships in ima probleme? Kaj je tukaj skupnega med tvojim in Buggyevim primerom? Ampak ja let's trol the crap out of this shit ane...
Buggy ::
8-O
Kaj sure?! Sej na R9 290 na 1080p60Hz in HD 7950 na 120Hz projektorju VSR konstantno uporabljam in zato se cudim kako so nedotakljivi lahko tako slampasti oz...kdo bi si mislu, da celo nekaj ne dela kar takoj po dveh klikih? Te rosade ikona na namizju na obeh AMD masinah pri uporabi VSR (v igrah) nisem opazil do zdej. Sem pa res po daljsem casu posodobil na zgornji (daily) masini z GTX 780 driverje, tako da lahko da je slo kaj pri instalaciji narobe, ker nisem delal DDDU clenaupa...sej menda ga superirorni SW kot je Geforce Experince menda ne potrebuje
Senitel ::
Sedaj boš še povedal, da imaš na R9 290 isto razporeditev ikonc na desktopu kot na daily mašini ane, ter da ti World Of Warships deluje tam čisto fenomenalno.
PredatorX ::
GenZNPC ::
Še kdo tle kupuje na newegg al samo predator?
Kok so pa spustil cene za nas EU to SLO ?
skibidi
Dami ::
Zakaj pa bi? V US so trgovine same spustile cene zarad blackfriday pač. Uradno nvidia in ati nista nič spreminjala.
Xserces ::
Ahhhh sem pa mislil da bojo končno malo spustili cene... mislim za oba tabora. Bila je neka novica oziroma je nekdo popal po forumu za NV.
Dami ::
Ja iz wcctech, ki so kot osnovo za novico vzeli kar cene iz newegga. Ta stran je kot 24ur za IT.
GenZNPC ::
Škoda, ker smo spet v EU:
This holiday, give yourself the gift of incredible gaming with a free GPU upgrade.
Just configure your rig with the GeForce GTX 750 Ti, and we'll step you up to the high-performance GeForce GTX 950.
skibidi
fr4nc ::
Zgolj informativno...kolikor sem slišal prihaja GTX 960 Ti. Kdaj? Januar 2016?
http://www.gamestar.de/hardware/grafikk...
D3m0r4l1z3d ::
verjetno imajo še preveliko zalogo 970 in se jim ne splača 960Ti
neverjetni99 ::
D3m0r4l1z3d je izjavil:
to res nima veze, saj bi bil čist drugi cenovni razred kot pa 970
Hja, sam zdej če hočeš nekaj bolšega od 960, vzameš 970ko, če bi bla pa 960Ti, bi vzel pa tisto :)
Oni že vedo, zakaj je še ni. afterall, 960Ti bi pomenl porezan GM104
D3m0r4l1z3d ::
je pa dosti takih, ki priporočajo potem 970, da bo bolj ziher :-)
GenZNPC ::
970 has greater user share than 7900 series, R9 290 series, R9 300 series, and Fury series *COMBINED*
http://store.steampowered.com/hwsurvey/...
970 = 4%
7900 series = 1.86%
R9 200 series = 1.22%
390 not listed = < .16%
Fury not listed = < .16%
skibidi
D3m0r4l1z3d ::
Tukaj se vidi kolk je 970 prepričala, navkljub aferi, kot VW, dobr to
GenZNPC ::
Prepričuje večinoma široka pisana paleta iger, kar za AMD ne morem trditi, ker so večina narjeni iz konzol (amdtech)
skibidi
- spremenil: GenZNPC ()
D3m0r4l1z3d ::
Te 7970 so verjetno že pri tretjem lastniku
GenZNPC ::
Ker ste bli poredni in off topic, poglejo sveži test FCAT, ki meri čas med slikami (po domače).
Prvo kot prvo, 4GB je bolše v obeh primerih, AMPAK
Zdaj mi je jasno, zakaj AMDjaši mislijo, da 3.5GB oz. 2GB pomeni tako velik problem,
saj njihove kartice imajo bistveno slabže upravljanje s pomnilnikom in bistveno večje težave s 2GB, kakor tudi 4GB pomnilnika.
Povrh tega ima AMDjeva 380 2x večji memory bus in sicer v tem primeru 380 ima 256bit, 960 pa 128bit.
Pričakovali bi rezultate v prid AMDju, pa je res tako?
Poglejmo:
Vir: http://www.computerbase.de/2015-12/2gb-...
Še preden se začnejo rdeči spet razburjat, uporabljeni so bili stabilni driverji 15.10 in ne Krimson, ker redakcija pravi, da tako ali tako ni bilo izmerljivih razlik pri meritvah:
Als Treiber kommen der Catalyst 15.10 beziehungsweise der GeForce 358.50 zum Einsatz. Nach Veröffentlichung der neuen Radeon Software Crimson Edition hat ComputerBase die Ergebnisse auf Abweichungen überprüft, konnte ABER keine relevanten Veränderungen in den getesteten Titeln feststellen.
Rezultati govorijo zase, Nvidijinih 2gb se veliko bolje odreže od AMDjevih 2gb. Pri 4 prit 4 se razlika zmanjša, ampak pri 380 je še vedno opaziti večje čase in nihanja, ne glede na 256bitno vodilo.
O tem smo že poročali tudi, ko se je debatiralo o 3.5GB rama na 970 v primerjavi z AMDjevih 4GB, ampak tudi takrat so testi pokazali, da Nvidia boljše upravlja z pomnilnikom in 3.5GB se lahko povsem, brez težav kosa z 4GB v večini aktualnih naslovih.
Tudi pri FPS, lahko opazimo:
- Assasins Creed Unity, da Nvidijinih 2GB in 4GB se zadržujeta nad 35fps območjem. Med tem, ko pa AMDjeva 2GB različica polovico časa pada pod 35 FPS.
- Pri Far Cry 4 so AVG, frejmi boljkone izenačeni, ampak NVidijina krivulja je bolj umirjena, medtem ko pa pri AMD lahko opazimo veliko večja nihanja (gor/do)
- Pri Dragon Age, ni kaj za komentirat. Zadevi sta si bok ob bok.
- Pri GTA V se dogaja enako, kot pri FC4. Nvidia ima umirjeno krivuljo in obe kartici lepo shajata in držita neko konstanto. AMD sicer ima sunke za kak FPS več kot Nvidija, ampak so nihanja spet zelo velika.
- Pri Shadow of Mordor, ni kaj posebnega za opaziti. Mogoče malenkost večji FPS na AMD 4GB različici, pri 2GB različici pa so FCAT rezultati za AMD katastrofalni.
Zadržite se določeni osebki raznih subjektivnih rant postov, zadeva je izmerjena in tu ni prodajanja pravljic.
Zaključek zgodbe je, da je pri AMD res potrebno več pomnilnika, ampak to še ni garancija za lepše čase med slikami.
Eno lepo torkovo jutro vsem,
Poglejmo:
skibidi
NightHawk ::
Zanimiv clanek. D3m si pa lahko prebere zakljucke original clanka preden podaja neprimerne komentarje.
Sedaj razumem zakaj nebi imel 380 2gb.
Sem prebral. Na obeh 2 GB od AMD in nvidie so igre igralne. Način kako je molnar prikazal članek pa ne odobravam.
- spremenil: D3m ()
AapocalypseE ::
AapocalypseE je izjavil:
Zgleda je nekaj na tem.
Poglejte BO III 1080p max. nastavitve kako 290X 4GB slabo poganja igro. 390X 8GB pa nima problemov.
970 s 3.5GB vrama je tudi dosti boljša od 290X 4GB.
Verjetno je to posledica počasnejšega GDDR5 rama. Opažam, da specifikacije niso enake, kot pri GTX 9xx.
AapocalypseE ::
390X 107-84-80
290X 86-38-28
To je definitivno pomanjkanje vrama in ne posledica počasnejšega vrama.
290X 86-38-28
390X 107-84-80
290X 86-38-28
Nope. Ker potlej bi 960 2 GB bremzalo. Pa jo ne.
NightHawk ::
Maxwell schlägt sich besser als Tonga
Der Test hat auch gezeigt, dass das Speichermanagement der GeForce GTX 960 und damit von Maxwell offenbar deutlich besser mit 2 GB zurecht kommt als das Pendant der Radeon R9 380 und damit von Tonga. Die GeForce GTX 960 leidet zwar in denselben Spielen unter dem zu geringen Speicherausbau, läuft aber dennoch spürbar besser.
Auf Basis der Erkenntnisse dieses Artikels wird ComputerBase dem Thema VRAM und dessen ausreichender Dimensionierung für aktuelle Titel in Zukunft noch mehr Aufmerksamkeit schenken. Nach diesem Ausflug in die Mittelklasse wird sich ein zukünftiger Artikel demselben Thema in der Oberklasse widmen.
Članek pravi, da ni več primerno kupiti 2GB, da obe kartici trpita izgube z 2GB konfiguracijo ampak da jo Nvidia prenaša "občutno bolje" kot AMD konkurent. Sepravi približno to kar je molnar povedal.
Očitno nisi razumel bistva članka. Brezveze se potem sploh oglašati, sploh z neprimernimi komentarji.
GenZNPC ::
Vprašanje je le, zakaj se 380 2GB tako veliko slabše odrezuje od 960 oz. ima tako velike framtime, pa ma 2x večje 256bitno vodilo.
Vsekakor pa dejstvo je, da je 4GB boljše v obeh taborih. Medtem, ko 2GB deluje veliko lepše na nvidiji, in 4gb mal lepše.
Manjša nihanja v FPS in veliko manjša pri FCAT.
Verjetno se ta izkušnja lahko aplicira tudi na druge kartice pri rdečih, zato pa je bil tak strah pred 970.
Bistvo članka je, da če imaš 2GB radeonko si v težavah. Medtem, ko pr NVidiji boš v težavah bolj malo in le v izbranih (požrešnih) igrah, namreč v testu so bile izbrane ravno te igre.
V drugih pa je izgleda, igranje veliko bolj smooth na zelenih predvsem 2GB.
skibidi
Bistvo članka je samo prikaz FCAT. In ne 380 ni v težavah, kot hočeš napeljati.
Še zmeraj je hitrejša od 960. Razlika je samo v prid pri FCAT.
- spremenil: D3m ()
Na papirju je boljsa. Papir pa ne laze, ane?
Se za 380x tezko recemo, da je omembe vredno hitrejsa od gtx960, kaj sele za obicno 380.
Zadnja slika tudi to potrjuje, da se motiš.
Menda je res hitrejša v dveh igrah.
Poster si lahko obesiš v sobo.
@Dr M ne skači vmes med nama, ker nimaš nič pametnega za pisati.
- spremenil: D3m ()
fr4nc ::
Kako si potem naj tole razložim?
Kako se računajo %? Če npr. vzamemo 2 igri (da bo lažje za razložit) in če sta v eni igri enako hitri (GTX 960 in R9 380X) in je na koncu razlika 25% (v prid R9 380X), potem to pomeni, da je v drugi igri (R9 380X) 50% hitrejša (od GTX 960)?
Štima matematika?
Nekako tako. Potlej nam to spet pove, da niso mature driverji za 380X. Kar pomeni spet čakanje.
gddr85 ::
lahko komot na techpowerup pogledaš npr. asus 380x v špilih, kolk sta si 960 in 380x podobni
pogledaš pa recmo gta5 pa ti kar slabo rata 960 11fps - 380x 43+fps, 1440p 10fps - 33+fps
GenZNPC ::
Smo že dali čez (malo si poglej posamezne igre al kak drug test):
Datum testa: 8.12.2015
Izbor:
+ FCAT in imaš obupno kartico.
Anyway, pusmo zdaj AMD pristaše, ki proizvajajo neke izgovore in primerjajo 200EUR karto z 250EUR karto...
Prišel je Anno 1.2 patch, prinaša velik performance boot:
AMDjaši sploh ne rabte gledat tole, zato pa raje objavim v Nvidia temi, da nebo spet flame war.
skibidi
AapocalypseE ::
390X 107-84-80
290X 86-38-28
Zgleda zna Nvidia dosti boljše izkoristit vram, ker ni šans, da bi bila 290X toliko slabša zaradi malenkost počasnejšega vrama.
- spremenil: AapocalypseE ()
Zakaj se pa ti sploh usajas v te debate, ce si pa upokojil desktop? Toliko da malo drek mesas. Drugega itak ne znas.
pogledaš pa recmo gta5 pa ti kar slabo rata 960 11fps - 380x 43+fps, 1440p 10fps - 33+fps![]()
To so obrobni primeri. So, ampak zelo redki. Ce ti je taka igra pomembna, potem je izbira jasna.
Po drugi strani je pa tista asuska navita. Stock je precej slabse. Pa ce ze gremo navijat, gre spet vse v prid 960.
Nekaj dni nazaj sem gledal en test (ga zal ne najdem), kjer je bila 380x od 10 igrer samo v dveh res zelo hitrejsa, v vseh drugih je bilo pa nekaj % razlike, enkrat v prid eni drugic v prid drugi.
gddr85 ::
no sej zato, lahko cel dan limamo vsak svoje grafe do onemoglosti
btw tisti je afaik stock, asus ima še 2+ fps več ;)
- spremenil: gddr85 ()
390X 107-84-80
290X 86-38-28
Malenkost? Razlika je 2000 MHz efektivnega ali 40%.
@ Dr M
Če sem upokojil še ne pomeni, da manj vem. Za razliko od tebe, ki jo imaš pa pišeš cvetke.
Izbor:
Torej kupiš AIB OC 380 pa je.
- spremenil: D3m ()
| » | AMD pokazal svojo najhitrejšo grafično kartico Radeon R9 Fury X2 (strani: 1 2 3 4 5 )Oddelek: Novice / Grafične kartice | 79996 (73175) | Napajalc |
| » | grafična kartica?katero kupiti (strani: 1 2 3 4 … 8 9 10 11 )Oddelek: Kaj kupiti | 113701 (43377) | PredatorX |
| ⊘ | R9 380 prenizka frekvenca... (strani: 1 2 )Oddelek: Strojna oprema | 14615 (12938) | D3m |
