Forum » Operacijski sistemi » win7/ run as administrator
BRBR ::
A bi tule moral bit kak pwd enter/confirmation ?
Ne dogodi se nič, razen, da se nek setup exe štarta kot normalno, na dbl click.
In potem znotraj setupa jamra da nimam administrator privileges.
- spremenil: BRBR ()
BRBR ::
Ja sem kar siguren da sem, ampak omenjeni setup v obeh primerih jamra da nimam administrator privileges.
Ter da naj 'run as administrator'.
Tudi če si, je vseeno dostikrat potrebno program pognati s to opcijo.
Če uporabljaš NC, se velikokrat zgodi, da teži in noče premikati oz. brisati fajlov, če ga poženeš z dvoklikom. Zapreš program, ga poženeš kot administrator (pri sedmici je v primeru enega uporabnika to itak privzet mode) in dela BP.
BRBR ::
CRIMC1018E: Administrator privileges are required.
You started the Installation Manager in administrator mode, but you do not have the required administrator privileges. On Microsoft Windows XP Professional, you must be a member of an administrator group. On Windows Vista, Windows 2008, Windows 7, and Windows 8, you must use the Run as administrator option. On Linux, UNIX, Mac OS X, IBM i, and z/OS, you must have root privileges.
To use the Run as administrator option on Windows:
1. Right-click the executable icon.
2. Select Run as administrator.
3. Enter an administrator password when prompted for either an administrator password or a confirmation.
4. Click Continue.
Sem v administrator mode (na navadenn dbl click), nimam pa admin privileges ?
Navaden win explorer.
Bejž na wiki.
Čeprav si prijavljen kot administrator, zaganjaš programe v user modu. Če želiš drugače ... imaš to opcijo.
Gre za varnost, administratorske pravice računa so v tvojem primeru potrebne v glavnem zato, da lahko upravljaš z uporabniškimi računi.
- spremenil: feryz ()
BRBR ::
Jo izberem (run as administrator). In je rezultat enak, dobim zgornji message.
| » | Šifriranje folderja/container na PC brez pravicOddelek: Pomoč in nasveti | 2972 (2687) | sodnicaN |
| » | Windows 8.1 network problemOddelek: Omrežja in internet | 2380 (2216) | Gogyto |
| » | Cod 2 problemOddelek: Igre | 2902 (2129) | __Devil__ |
| » | Ultimate USB Key - skrita particija (in nekaj dodatkov..)Oddelek: Pomoč in nasveti | 2429 (2316) | OmaDesala |
| » | Nero-Burning Rom in Win2000?Oddelek: Programska oprema | 1506 (1294) | Lime |
